POV-Ray : Newsgroups : povray.newusers : Draw powerline wire on image background Server Time
24 Mar 2026 10:38:44 EDT (-0400)
  Draw powerline wire on image background (Message 11 to 13 of 13)
Subject: Re: Draw powerline wire on image background
Date: 25 Oct 2019 03:42:32
Message: <5db2a768$1@news.povray.org>
Op 24/10/2019 om 14:57 schreef ale### [at] gmailcom:
>> Op 22/10/2019 om 12:05 schreef ale### [at] gmailcom:
>>> Hello Everybody ,i'm new to Pov Ray engine.
>>> I need to draw powerline wire on a background png image that i've in my pc.
>>> I have tried using sphere_sweep but the result are not really encouraging.
>> I think you may be helped with one or both attached applications. One is
>> by Lance Purple, the other by PM 2Ring. They show how to model catenaries.
>> Thomas
> In catenary.zip is used torus as connecting elements ,is it possibile to use
> other object to make something like a power line wires ? i think cylinder is the
> right choice but i don't know who to insert it in che catenary
It is not said explicitly in catenary.txt, but you can use any object
you want as a link. The torus is of course the most adapted for a chain
object.
So, you can use cylinders instead. you just have to be careful that the
initial object (i.e. the cylinder) is declared at the origin, and at the
proper scale.
As a test use the P2R_Catenary.pov scene file for experimenting. Under
the line where the Torus object is declared, insert:
#declare Cylinder = cylinder {<-1, 0, 0>, <1, 0, 0>, 0.25 scale 0.1
texture{T_Gold_3D}}
Then, in the Chain parameters section a few lines lower, replace:
#declare Link = Torus;
by:
#declare Link = Cylinder;
Now, render the scene and you will see what you wanted. ;-)
By replacing the torus by a cylinder, you can play with the other
parameters. So, for instance, Alternate and AltPhase can be switched
"off" (=0) instead of "on" (=1)
Play also with the scale of the original link element. Make it fatter or
slimmer, longer or shorter, and see what happens.
Date: 27 Oct 2019 16:55:01
Message: <web.5db6034bcf776ee04eec112d0@news.povray.org>
> object.
Chain-maker   :)
https://www.youtube.com/watch?v=TGIUbpMFeas
Date: 28 Oct 2019 03:46:29
Message: <5db69cd5$1@news.povray.org>
Op 27/10/2019 om 21:51 schreef Bald Eagle:
>> object.
> Chain-maker   :)
Oh! LOL! Now, I suppose, we are expected to model this hellish
contraption?!? It would be a proper Steam Punk project indeed.
Well spotted. Going from cylinder to torus...
In a distant past (before I saw the light with POV-Ray) I composed
music. The sound track of this video would have been inspirational ;-)
