POV-Ray : Newsgroups : povray.newusers : A cube with different bitmap images on each side. Server Time
30 Mar 2026 03:56:55 EDT (-0400)
  A cube with different bitmap images on each side. (Message 1 to 5 of 5)
Subject: A cube with different bitmap images on each side.
Date: 12 Nov 2017 16:40:00
Message: <web.5a08bea16ca4d5d9d8de543f0@news.povray.org>
Hello everyone,
I am trying to use different bitmap images on each side of a cube, but some
faces show only shadows. If I rotate the cube the problem changes as well - The
prior visible face turns shadowed and the shadowed image turns ok. What am I
doing wrong? Thanks in advance!
Subject: Re: A cube with different bitmap images on each side.
Date: 12 Nov 2017 17:35:01
Message: <web.5a08cc0514546e2c5cafe28e0@news.povray.org>
"Lagipavi" <lag### [at] gmailcom> wrote:
> Hello everyone,
Without seeing your specific code, it's hard to say exactly what you're doing
wrong, but perhaps looking over the details of the cubic pattern will help you
out.
3.6.2.1.6 Cubic Pattern
The cubic pattern takes six texture elements and maps each one to each of the
six pyramids centered at each half-axis, effectively mapping each texture
element to each side of a origin-centered cube.
The cubic pattern and the order of texture elements
The first group of elements map to the positive half-axis, in the X, Y and Z
axes respectively. The same order is applied to the last group of elements,
except on the negative half-axis.
The syntax is:
  cubic
    TEXTURE_ELEMENT_1
    TEXTURE_ELEMENT_6
also:
http://www.f-lohmueller.de/pov_tut/tex/tex_750e.htm
Date: 12 Nov 2017 18:30:39
Message: <5a08d99f$1@news.povray.org>
On 11/12/2017 04:35 PM, Lagipavi wrote:
> Hello everyone,
I would build 6 cubes, each with its own image, and then squish and
union the cubes together.
It also sounds like you're applying the texture/image after rotating.
dik
Date: 12 Nov 2017 18:53:45
Message: <5a08df09$1@news.povray.org>
Am 12.11.2017 um 22:35 schrieb Lagipavi:
> Hello everyone,
Maybe have a look at UV mapping.
Date: 18 Nov 2017 09:00:01
Message: <web.5a103c3214546e2c990be8aa0@news.povray.org>
> > Hello everyone,
Hmmm this is interesting. I would have done what dick balaska suggested ie:
"I would build 6 cubes, each with its own image, and then squish and
It also sounds like you're applying the texture/image after rotating."
I had no idea that you could do what bald eagle suggested ie:
"3.6.2.1.6 Cubic Pattern
element to each side of a origin-centered cube."
Thanks for this tip. ;)
