POV-Ray : Newsgroups : povray.newusers : Beginners code doesn't run Server Time
21 Jan 2025 05:49:29 EST (-0500)
  Beginners code doesn't run (Message 1 to 3 of 3)
Subject: Beginners code doesn't run
Date: 1 Sep 2016 15:55:00
Message: <web.57c88751cc9c34c2412d2b10@news.povray.org>
I try to calculate a mesh2 with math functions. I can't get the code to run. It
stops at the bracket } of the vertex_vectors statement (after the #debug
statement). Probably I do a beginners error. Can you help me?
Here the code:
// Meash2test
#version 3.7;
#include "colors.inc"    // The include files contain
#include "stones.inc"    // pre-defined scene elements
  background { color Cyan }
  light_source { <2, 4, -3> color White}
#declare r = 7;
#declare phi = -1.5;
    location <r*cos(phi), 1, r*sin(phi)>
    look_at  <0, 1,  2>
#declare n = 3;
#declare m = 3;
#declare vec = n * m;
#declare f = 2 * (n - 1) * (m - 1);
#declare r = 0.2;
#declare phi = 3.14 / 10;
mesh2 {
    vertex_vectors {
        vec
#declare i = 0;
#declare j = 0;
#while(i<n)
    #while(j<m)
        #declare x1 = pow(i*r,5) * cos(5 * j * phi) - i * r * cos(j * phi);
        #declare y1 = pow(i * r,5) * sin(5 * j * phi) - i * r * sin(j * phi);
        #declare z1 = i*r + j*phi;
        ,<x1,y1,z1>
        #declare j = j + 1;
    #declare i = i + 1;
#debug concat("i=",str(i,0,0), "  j=",str(j,0,0))
    face_indices {
        f
#declare i = 1;
#declare j = 0;
#while(i < n)
    #while(j < m)
        #declare k = i * n + j;
        #declare k1 = k - m;
        #declare k2 = k - m + 1;
        #declare k3 = k + 1;
        ,<k,k1,k2>, <k, k2, k3>
        #declare j = j + 1;
    #declare i = i + 1;
    pigment {rgb 1}
Subject: Re: Beginners code doesn't run
Date: 1 Sep 2016 16:02:12
Message: <57c88944$1@news.povray.org>
Am 01.09.2016 um 21:54 schrieb Markus:
>     vertex_vectors {
>         vec
> #declare i = 0;
> #declare j = 0;
> #while(i<n)
you want to move the "#declare j = 0" into the outer loop.
>     #while(j<m)
>         ,<x1,y1,z1>
>         #declare j = j + 1;
>     #end
>     #declare i = i + 1;
> #end
Also, presuming you are using POV-Ray 3.7, to avoid such mistakes you
can instead use the `#for` statement, which initializes and increments
the variable automatically.
#for(i,0,n-1)
  #for(j,0,m-1)
Date: 2 Sep 2016 02:30:00
Message: <web.57c91c64786d177f4066f2170@news.povray.org>
> >     vertex_vectors {
> >         vec
> > #declare i = 0;
> > #declare j = 0;
> > #while(i<n)
> >     #while(j<m)
> >         ,<x1,y1,z1>
> >         #declare j = j + 1;
> >     #end
> >     #declare i = i + 1;
> > #end
> #for(i,0,n-1)
>   #for(j,0,m-1)
>   #end
> #end
Thanks, this helped :-)
