POV-Ray : Newsgroups : povray.newusers : image_map > solid object Server Time
1 May 2026 15:57:14 EDT (-0400)
  image_map > solid object (Message 11 to 16 of 16)
Subject: Re: image_map > solid object
Date: 3 May 2016 10:31:18
Message: <5728b636@news.povray.org>
Am 03.05.2016 um 15:41 schrieb Stephen:
> I would use CSG. The way I would try it is to use heightfields.
Height fields are pretty lame for this purpose, as they would create
very jagged sides.
Date: 3 May 2016 10:33:38
Message: <5728b6c2$1@news.povray.org>
> Like I said, this example PNG is very simple, 2 colors indeed.
> But I have others with many colors, more complicated shapes, not so easy to
> separate colors/shapes.
> Also, heightfield does not produce the quality I need, I used them a long time
> ago and they are not very smooth and sharp.
You can increase the resolution of the image used in the height_field to
get smoother edges. Also, slightly bluring the inage used can help in
this case.
To have sharper results, scale the hight_field verticaly by something
like 100 (scale<1,100,1>), and clip it using a box of the desired height
in an intersection.
Date: 3 May 2016 22:35:01
Message: <web.57295e912da27c2333c457550@news.povray.org>
> very jagged sides.
That's generally true; but if your artwork is very 'clean' with sharp edges, a
height_field might work, as the HF's sides would be completely vertical. Not
perfect though, I admit, as the triangles on the sides can still be somewhat
visible, and not perfectly smooth.
Some years ago, I used *media* to try to get this effect (a method that Clipka
already mentioned.) The results were reasonably good (depending on how DENSE I
could make the scattering media.) But the code for doing it was quite complex--
involving the image's three RBG colors first being converted into three separate
functions...
If I can find my old POV-Ray file and/or image, I'll post it, to give you an
idea of what it looks like.
Date: 3 May 2016 22:55:01
Message: <web.572963922da27c2333c457550@news.povray.org>
I found my original newsgroup post about this, which has some detail as to the
various tricks I used...
http://news.povray.org/povray.binaries.images/message/%3Cweb.4436e54a72fe66658ad7a9060%40news.povray.org%3E/#%3Cweb.443
I think *your* artwork would probably look better than the 'dinosaur skeleton'
image I used there.
Date: 3 May 2016 23:15:00
Message: <web.572968232da27c2333c457550@news.povray.org>
Oops, sorry, that was just my initial post there. Here's the full discussion...
http://news.povray.org/povray.binaries.images/thread/%3Cweb.4436e54a72fe66658ad7a9060%40news.povray.org%3E/
Date: 4 May 2016 01:54:25
Message: <57298e91$1@news.povray.org>
Le 03/05/2016 16:25, Paul a écrit :
> "Bill Pragnell" <bil### [at] hotmailcom> wrote:
>> "Paul" <nomail@nomail> wrote:
>>> I need a solid object, the 2 surfaces joined - the transparent yellow things > on
the right side.
>> Where do your images come from? If they were generated by a vector drawing
>> program you may be able to do it another way. Inkscape (https://inkscape.org/)
>> can export paths as POV-Ray prism objects, which would do exactly what you want.
>> If you only have the images, it may still be possible to use Inkscape to trace
>> over the images, creating equivalent paths that could then be exported.
>> Bill
> Images are coming from clients.
> No other formats are available, only PNG (if I'm lucky) or JPG.
> I don't think tracing will work, probably not that good definition of resulting
> objects.
> Well, looks like this is one tricky operation, thank you for all your help.
What you are trying to do is called "extrusion".
One additional solution to the ones already provided could be to convert
the picture into a ttf font, one glyph per colour and then use povray
text objects. (one text per colour).
There is a bit of utilities which can be useful in font-generation from
pictures, and search engines are more verbose on that subject ("create
font from picture")
