POV-Ray : Newsgroups : povray.newusers : Parse Error Server Time
21 Jan 2025 09:07:18 EST (-0500)
  Parse Error (Message 1 to 7 of 7)
Subject: Parse Error
Date: 29 Sep 2015 08:45:00
Message: <web.560a8720558a7cbac19665330@news.povray.org>
I use POV-RAY as it is supports rending of 3D model done on ZW3D 2014. I have
been using it and I could render the 3D models without any problem. But of late,
I do not know why, when ever I try to render using POV ray, an error message
appears stating"Possible Parse Error: Cannot find file
'C:\Users\Admin\AppData\Roaming\ZW3D 2014 Eng (x64)\MAP003.bmp', even after
trying to append file type extension.
Possible Parse Error: Cannot find image file. ". I have reinstalled POV ray, I
reinstalled ZW3D, but to no avail.
Please let me know, how to rectify this problem.
Subject: Re: Parse Error
Date: 30 Sep 2015 07:58:50
Message: <560bce7a$1@news.povray.org>
First thing jumping to my eyes: space in directory path.
Second thing: parenthesis in directoty path.
And then colon in pathname.
Did you add successfully with -L option that directory in the path to
search ?
Look at the message tab at the start of the rendering, it lists the
library paths.
And what is the current setting of script I/O restriction (in Option
sub-menu, it is both about script and I/O, not I/O of scripts) ?
Date: 2 Oct 2015 22:31:13
Message: <560f3df1@news.povray.org>
Have you checked whether this file actually exists?
Possibly there is a mixup of accounts, e.g. if data for ZW3D
was installed for different user than Admin.
Date: 3 Oct 2015 00:45:00
Message: <web.560f5c59e2a82aa7c19665330@news.povray.org>
To tell you the truth. I do not know anything about coding. There is a button in
ZZW3D called render, when I press that, POVray would open and a rendered image
would be created.
Message: <web.560f5cd4e2a82aa7c19665330@news.povray.org>
No it has been installed in the correct account. some parts still get rendered.
But some parts don't
Date: 3 Oct 2015 07:00:00
Message: <web.560fb43ee2a82aa7c19665330@news.povray.org>
No, apparently MAP003.bmp doesn't exist.
Date: 3 Oct 2015 11:34:29
Message: <560ff585$1@news.povray.org>
Am 03.10.2015 um 12:55 schrieb Madhav Shenoy:
That would indicate a problem on the ZW3D side: It generates a scene
file that tells POV-Ray to load a file named MAP003.bmp (presumably a
texture image of sorts), but fails to provide that MAP003.bmp.
So given that ZW3D is a commercial product, and the problem seems to be
on the ZW3D side, I definitely recommend contacting their customer
support on this issue.
