POV-Ray : Newsgroups : povray.newusers : Spheres in a sphere Server Time
18 Apr 2026 13:35:35 EDT (-0400)
  Spheres in a sphere (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: Spheres in a sphere
Date: 17 Mar 2014 14:50:00
Message: <web.532742e39f83cd6812fd452f0@news.povray.org>
> > Hello,
> > i want to make spheres in a sphere. I know there is a function for that :
> > VRand_In_Obj.
> > But i want to prevent the intersection of spheres between them.
> > How can i do proceed to do that ?
> > Thanks for your help
> A common and simple solution for equaly sized spheres:
> Create an array large enough to contain the locations of all your spheres.
> Randomly place about 10 to 100 spheres. Make sure that the new spheres
> are located at twice the individual radius. Each acceptable location is
> placed in the array.
> Make an union of test spheres, each having twice the radius of your
> intended spheres.
> Now, for the next spheres, start with an insideness test against that
> union. There is an is_inside function that return 0 if outside an object
> and 1 if inside.
> Continue for another batch of spheres that will also be used to create
> another union.
> Repeat untill you have all yours spheres, or you need to many tries to
> find a suitable location.
> Finaly, using the locations from your array, place the actual spheres.
> Using a bunch of unions of double sized spheres is much faster than
> testing for every previous spheres.
> This don't ensure the most optimum packing, but ensure that all spheres
> are non-intersecting.
> If you search in povray.binaries.scene-files, you can find some working
> code made exactly for that purpose.
> Alain
Thanks for these answers.
I will try to do it step by step with time because i am a new user on this
software.
i inform you.
Date: 23 Mar 2014 16:05:01
Message: <web.532f3e029f83cd6812fd452f0@news.povray.org>
"nonostar" <nomail@nomail> wrote:
> Alain <kua### [at] videotronca> wrote:
> > > Hello,
> > > VRand_In_Obj.
> > intended spheres.
> > and 1 if inside.
> > another union.
> > Alain
> software.
> i inform you.
Hello
This is that i did. But some sphere are again to gether.
Where is the problem?
I use the function : inside.
#include "rand.inc"
#declare Random_1 = seed (12433);
#declare Tableau=array[3000]
#declare Tableau2=array[3000]
#declare Variable=0;
#while (Variable<3000)
#declare Tableau[Variable]= VRand_In_Sphere(Random_1);
#declare Variable=Variable+1;
#declare VariableX=0;
#declare Variable=1;
#declare S1=Tableau[0];
#declare B1=sphere{S1 0.05 pigment {rgb <1,1,0>}}
#declare Point=Tableau[1]  ;
    #while (VariableX<=Variable)
        #if (inside(B1,  Point))
        #declare Tableau2[Variable]=0 ;
        #declare VariableX=VariableX+1;
        #declare S1=Tableau[VariableX];
        #else
        #declare Tableau2[Variable]=0.05;
#declare Variable2=1;
#declare S2=Tableau[Variable];
#declare S3=Tableau2[Variable];
sphere{S2 S3 pigment{rgb<1,1,0>}}
#declare Variable2=Variable2+1;
Can you help me?
Thanks
Date: 24 Mar 2014 10:05:01
Message: <web.53303aad9f83cd68419a77410@news.povray.org>
I tried to improve this.
But i get a problem.
When i ran i had this message : "Attempt to access unitialized array elemement"
for this line :
 #declare Point=ArrayPosition[Variable2];
i give you my code.
#include "rand.inc"
#declare ArrayPosition=array[3000]
#declare ArrayRayon=array[3000]
#while (Variable<30)
        #declare ArrayPosition[Variable]=VRand_In_Sphere(Random_1);
        #declare ArrayRayon[Variable]=0.05;
#declare Variable1=0;
#declare Object=sphere{ArrayPosition[Variable1] ArrayRayon[Variable1] pigment
{rgb <1,1,0>}};
#while (Variable2<3000)
        #while (Variable1<Variable2)
                #if(inside(Object,Point))
                #declare ArrayRayon[Variable2]=0;
                #declare Variable1=Variable2;
                #else
                #declare Variable1=Variable1+1;
ArrayRayon[Variable1] pigment {rgb <1,1,0>}};
        #declare Variable2=(Variable2+1);
sphere{ArrayPosition[Variable] ArrayRayon[Variable] pigment {rgb <1,1,0>}}
where is the mistake ?
I don't understand.
Date: 24 Mar 2014 11:45:00
Message: <web.533052679f83cd68419a77410@news.povray.org>
> > > > Hello,
> > > > VRand_In_Obj.
> > > intended spheres.
> > > and 1 if inside.
> > > another union.
> > > Alain
> > software.
> > i inform you.
> Hello
> #include "rand.inc"
> #end
>         #else
>         #end
>     #end
> #end
> #end
> Can you help me?
> Thanks
I improve my code but spheres stay together.
This is the new code :
#include "rand.inc"
{rgb <1,0,0>}};
#while (Variable2<2999)
                #else
ArrayRayon[Variable1] pigment {rgb <1,0,0>}};
#while (Variable<2999)
<0.85,0.85,0.85>}}
Any suggestions about my error ?
Thanks
Date: 24 Mar 2014 13:36:47
Message: <53306d2f$1@news.povray.org>
> for this line :
This mean that you try to access an element of ArrayPosition that have
never been set to any value.
> i give you my code.
> #include "rand.inc"
Add:
#declare Rayon = 0.05;
Comment out the line above.
> #end
> {rgb <1,1,0>}};
As you have constant radius, it would be beter to use a simple variable
here. This become this:
#declare Object=sphere{ArrayPosition[Variable1] Rayon pigment{rgb <1,1,0>}}
Note: In this case, the ";" is not needed. It's mandatory when declaring
a simple numerical variable or a vector. It's never needed when
declaring an object.
Try replacing this by:
#if(inside(Object, ArrayPosition[Variable2] ))
>                  #else
>                  #end
>          #end
> #end
It's here that you create the spheres to be visible. The previous ones
are only used for the placement.
Change this:
To this:
sphere{ArrayPosition[Variable] Rayon/2 pigment {rgb <1,1,0>}}
> #end
> I don't understand.
The spheres that you use to test the placement MUST be twice as large as
the ones you intend to be visible.
Date: 24 Mar 2014 13:51:26
Message: <5330709e@news.povray.org>
> #include "rand.inc"
ALL your spheres have the exact same radius. This mean that the above
array is superfluous. Replace it with a simple scalar variable.
Remove the following line.
> #end
> {rgb <1,0,0>}}
Use your simple Rayon variable MULTIPLIED by 2!
Also, as this object will NEVER show, it don't need to have any pigment,
giving you this:
#declare Object=sphere{ArrayPosition[Variable1] Rayon*2}
Doubling "Rayon" ensure that the points you find are far enough from the
others to prevent any spheres from overlapping.
Make the same change in the loop below:
>                  #else
> Rayon*2 }
>                  #end
>          #end
> #end
The following spheres are those that ARE visible and need the pigment.
> sphere{ArrayPosition[Variable] Rayon pigment {rgb
> <0.85,0.85,0.85>}}
> #end
> Thanks
PS.: If you have trouble in english, send me your e-mail address. French
is my native language, and your naming suggest that it's the same for you.
Date: 24 Mar 2014 14:40:00
Message: <web.53307b699f83cd6812fd452f0@news.povray.org>
In fact i found my error. The radius of my object has to have a radius*2. But
now  i have wholes in my sphere. How can i improve it ?
Thanks
Date: 24 Mar 2014 15:30:01
Message: <web.533087339f83cd6812fd452f0@news.povray.org>
> Thanks
I didn't see your message. I am sorry about this. Indeed i speak french. How can
i send you a private message ? I didn't found the option in this forum.
Thanks again
Date: 24 Mar 2014 16:54:10
Message: <53309b72@news.povray.org>
There are no PM's on this forum. It is old fashioned, it is a news group.
There is an international forum, where non-English threads are.
Regards
I solemnly promise to kick the next angle, I see.
Date: 24 Mar 2014 16:56:04
Message: <53309be4@news.povray.org>
Sorry, I forgot the link. :-(
http://news.povray.org/povray.international/
Regards
