POV-Ray : Newsgroups : povray.newusers : Make part of an object transparent Server Time
1 May 2026 17:22:24 EDT (-0400)
  Make part of an object transparent (Message 1 to 10 of 11)
Subject: Make part of an object transparent
Date: 7 Nov 2012 08:10:01
Message: <web.509a5ce37ca5486aeef78c9e0@news.povray.org>
Hi guys,
I am working on a project where I am trying to render an impossible cube. The
final stage is to animate it but initially, I would only like to see if I can
make a part of the cube invisible. The logic I'm following is that, every time
part of the cube skeleton is hidden by some other part of it that's in front,
make that part invisible so that the part on the back is still shown. this will
give the illusion of an impossible cube. Is there any way you could suggest I
can do this?
Thank you in advance.
Alex
Subject: Re: Make part of an object transparent
Date: 7 Nov 2012 08:29:40
Message: <509a6244$1@news.povray.org>
On 7-11-2012 14:06, Encore wrote:
> Hi guys,
> can do this?
> Alex
Yes, you could use interior_texture.
Example (not tried):
box {
  -1, 1
  texture {pigment {rgbt 1}}
  interior_texture {pigment {rgb 1}}
Date: 7 Nov 2012 09:54:44
Message: <509a7634$1@news.povray.org>
On 07/11/2012 1:06 PM, Encore wrote:
> Hi guys,
> can do this?
I think that you will need to use some clever maths and use differences.
I had a quick try with that method and it might work.
Regards
Date: 7 Nov 2012 10:35:01
Message: <web.509a7f4bf48acc75eef78c9e0@news.povray.org>
> > Hi guys,
> > can do this?
> Regards
>      Stephen
The code block for my cube wireframe construction is this:
sphere{<0,0,0>,1 hollow
       texture{pigment{gradient <0,1,0>
                       color_map{[0    color Blue]
                  [0.45 color White]
                  [0.55 color White]
                  [1.0  color Blue]}
       scale 2 translate<0,-1,0>}
               finish {ambient 1 diffuse 0} }
       scale 10000}
// ground-----------------------------------------------------------
/*plane{ <0,1,0>, 0
       texture{ pigment { checker color Gray65 color Gray30}
                normal  { bumps 0.5 scale 0.05  }
                finish  { phong 0.1 }
              } // end of texture
#declare R = 0.25;   //radius of the tubes
#declare r = 0.375;  //radius of the spheres
#declare BigCube1 = merge{
sphere{<-1,-1,-1>,r}  sphere{< 1,-1,-1>,r}
sphere{<-1,-1, 1>,r}  sphere{< 1,-1, 1>,r}
sphere{<-1, 1,-1>,r}  sphere{< 1, 1,-1>,r}
sphere{<-1, 1, 1>,r}  sphere{< 1, 1, 1>,r}
cylinder {<-1,-1,-1>,< 1,-1,-1>,R}// 4 in x direction
cylinder {<-1,-1, 1>,< 1,-1, 1>,R}
cylinder {<-1, 1,-1>,< 1, 1,-1>,R}
cylinder {<-1, 1, 1>,< 1, 1, 1>,R}
cylinder {<-1,-1,-1>,<-1, 1,-1>,R}// 4 in y direction
cylinder {<-1,-1, 1>,<-1, 1, 1>,R}
cylinder {< 1,-1,-1>,< 1, 1,-1>,R}
cylinder {< 1,-1, 1>,< 1, 1, 1>,R}
cylinder {<-1,-1,-1>,<-1,-1, 1>,R}// 4 in z direction
cylinder {<-1, 1,-1>,<-1, 1, 1>,R}
cylinder {< 1,-1,-1>,< 1,-1, 1>,R}
cylinder {< 1, 1,-1>,< 1, 1, 1>,R}
       T_Gold_1B// pigment{Red filter .98}
      finish { ambient 0.2 diffuse 0.7 }
object{ BigCube1 scale 0.7
        rotate<0,60,0> translate<0,1.2,0>}
Other than that, I just can't figure out how to "scan" a piece on the back and
make the front part that's hiding it transparent. After all, I can't make a
completely automated method for this as there are several edges which should not
be hidden at all. (If you render this code with some camera settings like
global_settings{ assumed_gamma 1.0 }
#default{ finish{ ambient 0.1 diffuse 0.9 }}
#include "textures.inc"
#include "golds.inc"
#declare Cam0 =camera {ultra_wide_angle angle 60
                       location  <0.0 , 3.0 ,-3.5>
                       look_at   <0.0 , 1.0 , 0.0>}
/*#declare Cam1 =camera {ultra_wide_angle angle 250
                       location  <0.0 , 0.5 ,-2.5>
                       look_at   <0.2 , 1.0 , 0.0>}*/
camera{Cam0}
light_source{<1500,2000,-2500> color White*0.7}
you will see exactly what I mean.)
Date: 7 Nov 2012 13:54:53
Message: <509aae7d@news.povray.org>
Sorry, I am so busy in RL that it might/will take me a while to get
round to it. :-(
Most optical illusions rely on a fixed viewpoint and I think that this
would be very difficult to create in an animation.
But it would be very worthwhile if it can be done.
One of the reasons that I think that you would need differences is that
not all the surfaces that hide the back of the object are invisible. For
instances at the corners.
If I have the time at the weekend I will look into it further.
Regards
Date: 7 Nov 2012 14:45:00
Message: <web.509ab954f48acc75eef78c9e0@news.povray.org>
> round to it. :-(
> Regards
>      Stephen
Thanks Steve I really appreciate it. But put animation aside (I'll try and deal
with this later on), how can I make a fixed part of this object invisible? I
mean a way is to make a difference as you are saying, another is to trace and
return a transparent value for a specific part of an edge. Do you have any code
for achieving this in a static state like the one I'm dealing with here?
Date: 7 Nov 2012 16:07:13
Message: <509acd81$1@news.povray.org>
Okay, I did make an attempt and the code is below. But be aware that I
use a modeller (Bishop3d) and the code is not good Pov-Ray code. (I have
to put single objects in a union to get the desired effect. Nor is it
optimised. (machine written code sucks ;-) )
This I would say is more of a general or advanced topic.
#version 3.6;
background { colour rgb <0.000,0.000,0.000> }
// referenced scene items and forced visible scene items declaration begin
#declare Default_Texture0 =
       colour rgbft <1.000,0.000,1.000,0.000,0.000>
    finish {
       ambient     rgb <1.000,1.000,1.000>
       brilliance  1.000
       crand       0.000
       diffuse     0.600
       metallic    0.000
       phong       0.000
       phong_size  40.000
       specular    0.000
       roughness   0.050
#default{ texture{ Default_Texture0 } }
#declare Shadow_Clouds_Top =
    colour rgbft <0.196,0.600,0.800,0.000,0.000>
#declare Shadow_Clouds_Bot =
    bozo
    colour_map {
       [0.000 rgbft <0.850,0.850,0.850,0.000,0.000>]
       [0.100 rgbft <0.750,0.750,0.750,0.000,0.000>]
       [0.500 rgbft <1.000,1.000,1.000,0.000,1.000>]
    rotate    <0.0,0.0,90.000>
    rotate    <180.000,0.0,0.0>
    scale     <0.200,1.200,1.200>
    rotate    <-180.000,0.000,-90.000>
    rotate    <0.000,355.000,0.000>
    translate <0.000,-0.150,-0.000>
    turbulence <0.650,0.650,0.650>
    octaves 6
    lambda 2.000
    omega 0.700
#declare Shadow_Clouds_Mid =
    bozo
    colour_map {
    octaves 6
    lambda 2.000
    omega 0.700
#declare Blue_White_Tiles1 =
    checker
          colour rgbft <1.000,1.000,1.000,0.000,0.000>
       normal {
          agate, 0.100
          agate_turb 0.500
       finish {
          ambient     rgb <0.100,0.100,0.100>
          brilliance  1.000
          crand       0.000
          diffuse     0.600
          metallic    0.000
          phong       0.000
          phong_size  40.000
          specular    0.000
          roughness   0.249
          reflection {
             rgb <0.100,0.100,0.100>, rgb <0.000,0.000,0.000>
             fresnel   0
             falloff   0.000
             exponent  1.000
             metallic  0.000
          colour rgbft <0.000,0.502,1.000,0.000,0.000>
       normal {
          agate, 0.100
          agate_turb 0.500
       finish {
          brilliance  1.000
          crand       0.000
          diffuse     0.600
          metallic    0.000
          phong       0.000
          phong_size  40.000
          specular    0.000
          roughness   0.249
          reflection {
             fresnel   0
             falloff   0.000
             exponent  1.000
             metallic  0.000
    rotate    <0.0,0.0,180.000>
    rotate    <-90.000,0.0,0.0>
    scale     <-300.000,-300.000,-1000.000>
    rotate    <90.000,0.000,-180.000>
    rotate    <0.000,-180.000,0.000>
    scale     <0.010,0.010,0.010>
#declare Maple =
material{
       #declare BISHOP3D_TEMPORARY_IDENTIFIER =
                wood
                colour_map {
                   [0.000 rgbft <0.796,0.796,0.384,0.000,0.000>]
                   [0.133 rgbft <0.706,0.518,0.235,0.000,0.000>]
                   [0.230 rgbft <0.796,0.796,0.384,0.000,0.000>]
                   [0.336 rgbft <0.706,0.518,0.235,0.000,0.000>]
                   [0.442 rgbft <0.796,0.796,0.384,0.000,0.000>]
                   [0.549 rgbft <0.706,0.518,0.235,0.000,0.000>]
                   [0.646 rgbft <0.796,0.796,0.384,0.000,0.000>]
                   [0.743 rgbft <0.706,0.518,0.235,0.000,0.000>]
                   [0.850 rgbft <0.796,0.796,0.384,0.000,0.000>]
                   [0.947 rgbft <0.706,0.518,0.235,0.000,0.000>]
                   [1.000 rgbft <0.796,0.796,0.384,0.000,0.000>]
                frequency 1.000
                phase 0.000
                ramp_wave
                noise_generator 1
                scale     <2.000,2.000,15.000>
                rotate    <0.000,0.000,-180.000>
                rotate    <0.000,0.000,90.000>
                translate <-8.000,80.000,0.000>
                turbulence <0.100,0.100,0.100>
                octaves 6
                lambda 2.000
                omega 0.500
             finish {
                ambient     rgb <0.200,0.200,0.200>
                brilliance  1.000
                crand       0.000
                diffuse     0.800
                metallic    0.000
                phong       0.000
                phong_size  40.000
                specular    0.000
                roughness   0.050
                bozo
                colour_map {
                   [0.000 rgbft <1.000,1.000,0.439,1.000,0.000>]
                   [0.008 rgbft <1.000,1.000,0.439,1.000,0.000>]
                   [0.508 rgbft <1.000,1.000,0.439,0.400,0.000>]
                   [1.000 rgbft <1.000,1.000,0.439,1.000,0.000>]
                scale     <1.500,1.500,0.375>
             finish {
                brilliance  1.000
                crand       0.000
                diffuse     0.800
                metallic    0.000
                phong       0.000
                phong_size  40.000
                specular    0.000
                roughness   0.050
       ;// the semicolon is necessary or POV-Ray will not figure out
that the declarations has ended
#declare Camera0 =
    perspective
    location <18.112,45.490,-94.622>
    up y
    right 1.333*x
    angle 33.000
    sky <-0.061,0.944,0.325>
    look_at < 0.334, 11.721, -0.011 >
}  // end Camera0
#declare Box5 =
box {
    < -0.5000000, -0.5000000, -0.5000000 >, < 0.5000000, 0.5000000,
0.5000000 >
    material{ Maple }
    scale     <12.000000,2.000000,2.000000>
}  // end Box5
// referenced scene items and forced visible scene items declaration end
union {  // Lights
    light_source {  // Shadowless_Light_Source0
       < 0.000000, 0.000000, 0.000000 >, colour rgb <1.000,1.000,1.000>
       fade_power 0.000
       fade_distance 100.000
       media_attenuation off
       media_interaction on
       shadowless
       translate <15.811000,100.000000,-200.977356>
    }  // end Shadowless_Light_Source0
    light_source {  // Light_Source0
       fade_power 0.000
       translate <-24.636320,55.859425,-195.075000>
    }  // end Light_Source0
}  // end Lights
sky_sphere {  // SkySphere1
    pigment{ Shadow_Clouds_Top }
    pigment{ Shadow_Clouds_Mid }
    pigment{ Shadow_Clouds_Bot }
}  // end SkySphere1
plane {  // Plane1
    y , 0
    texture{ Blue_White_Tiles1 }
}  // end Plane1
union {  // Centre_0
    difference {  // CSG12
       union {  // Front0
          union {  // CSG3
             box {  // Box3
0.5000000, 0.5000000 >
                material{ Maple }
             }  // end Box3
             rotate    <1.000000,0.000000,90.000000>
             translate <7.000000,0.000000,0.000000>
          }  // end CSG3
          union {  // CSG2
             box {  // Box2
                material{ Maple }
             }  // end Box2
             translate <-7.000000,0.000000,0.000000>
          }  // end CSG2
          union {  // CSG1
             box {  // Box1
                material{ Maple }
                scale     <16.000000,2.000000,2.000000>
             }  // end Box1
             translate <0.000000,7.000000,0.000000>
          }  // end CSG1
          union {  // CSG0
             box {  // Box0
                material{ Maple }
             }  // end Box0
             translate <0.000000,-7.000000,0.000000>
          }  // end CSG0
          translate <0.000000,0.000000,-7.000000>
       }  // end Front0
       union {  // CSG13
          object {  // Reference0
             Box5
             scale     <1.052000,1.300000,13.719000>
             rotate    <-34.824000,0.000000,90.000000>
             translate <5.262000,1.848000,-7.674000>
          }  // end Reference0
          rotate    <0.000000,-1.223000,0.000000>
          translate <-6.886000,0.000000,7.050000>
       }  // end CSG13
    }  // end CSG12
    union {  // Side1
       union {  // CSG10
          box {  // Box10
             material{ Maple }
          }  // end Box10
       }  // end CSG10
       union {  // CSG11
          box {  // Box11
             material{ Maple }
          }  // end Box11
       }  // end CSG11
       rotate    <90.000000,0.000000,0.000000>
    }  // end Side1
    union {  // Side0
       union {  // CSG8
          box {  // Box8
             material{ Maple }
          }  // end Box8
       }  // end CSG8
       union {  // CSG9
          box {  // Box9
             material{ Maple }
          }  // end Box9
       }  // end CSG9
    }  // end Side0
    union {  // Back0
       union {  // CSG4
          box {  // Box4
             material{ Maple }
          }  // end Box4
       }  // end CSG4
       union {  // CSG5
          object{ Box5 }
       }  // end CSG5
       union {  // CSG6
          box {  // Box6
             material{ Maple }
          }  // end Box6
       }  // end CSG6
       union {  // CSG7
          box {  // Box7
             material{ Maple }
          }  // end Box7
       }  // end CSG7
       translate <0.000000,0.000000,7.000000>
    }  // end Back0
    rotate    <0.000000,24.200000,0.000000>
    translate <0.000000,8.000000,0.000000>
}  // end Centre_0
camera{ Camera0 }
Regards
Date: 7 Nov 2012 17:00:00
Message: <web.509ad972f48acc75eef78c9e0@news.povray.org>
Wow man this looks really awesome for an initial state of what I'm trying to
achieve! A few modification needed to be made in the rotation and scale values
for the difference box (and still having a small gap there that's visible), but
other than that this looks great! Thanks a lot
Date: 7 Nov 2012 18:15:01
Message: <web.509aeb17f48acc75eef78c9e0@news.povray.org>
Date: 8 Nov 2012 14:25:29
Message: <509c0729@news.povray.org>
Encore wrote:
> Hi guys,
> The final stage is to animate it but initially, I would only like to see
> if I can make a part of the cube invisible. The logic I'm following is
> that, every time part of the cube skeleton is hidden by some other part of
> it that's in front, make that part invisible so that the part on the back
> is still shown. this will give the illusion of an impossible cube. Is
> there any way you could suggest I can do this?
> Alex
Check out p.b.images.
I still need to clean up the code before I can post it.
Ger
