POV-Ray : Newsgroups : povray.newusers : Rendering 3D mesh Server Time
28 Sep 2024 19:00:18 EDT (-0400)
  Rendering 3D mesh (Message 1 to 10 of 20)
Subject: Rendering 3D mesh
Date: 17 Oct 2012 01:50:07
Message: <web.507e4659dc26c95e97c1fbff0@news.povray.org>
I have a 3D mesh .inc file, including thousands of triangles like this:
  smooth_triangle { // #763945
    <1.35632e-019, 1.35632e-019, 1.35632e-019>, <0.0147179, 0.999892,
0.000199087>,
0.000199087>,
    <0.000173748, 1.35632e-019, 3.35076e+012>, <1.93994e-005, 0.992192,
0.124723>
, I know what should I expect by rendering it in POV-ray, but somthing strange
is observed, maybe just 2 or3 triangles.
Could anybody please show me how I can render a mesh in povray?
Do I need to use Mesh in the script in povray?
How I have to decide about the position of camera and light source??
Thanks!
Vincent
Subject: Re: Rendering 3D mesh
Date: 17 Oct 2012 02:55:01
Message: <web.507e55451e176d50d97ee2b90@news.povray.org>
"Vincent" <nomail@nomail> wrote:
> Hi,
> 0.000199087>,
> 0.000199087>,
> 0.124723>
> Thanks!
> Vincent
I won't say RTFM... because that would be rude...
I also wish I could be more helpful than just directing you to the
documentation, but I haven't used any mesh objects.
It might help people understand your problem if you posted an image in
povray.binaries.images...
http://www.povray.org/documentation/view/3.6.0/292/
http://www.povray.org/documentation/view/3.6.2/67/
http://wiki.povray.org/content/Reference:Mesh
Happy rendering.
A.D.B.
Date: 17 Oct 2012 19:45:01
Message: <web.507f41a11e176d5097c1fbff0@news.povray.org>
> > Hi,
> > 0.000199087>,
> > 0.000199087>,
> > 0.124723>
> > Thanks!
> > Vincent
> Happy rendering.
> Regards,
> A.D.B.
Thanks, at least now i know that i have to look for the answer in no place but
the manual (though i already had read the manual). But, the problem is that i
can not add all the triangles in the script (and I think it wouldn't be
necessary), so instead of using the mesh command, I use the #include and then
address the inc file(whihc is converted from STL data set). I think, maybe the
whole object is rendered but the position of the camera and look_at vector are
not correctly choosed. I don't have any idea on chosing the correct place for
the camera.
I used the Poseray, it dosn't give a preview (I recived and error about FLOATING
NUMBER...).
Something is wrong but i don't know what is it.
Date: 17 Oct 2012 19:55:02
Message: <web.507f443f1e176d50d97ee2b90@news.povray.org>
> the camera.
> NUMBER...).
you might try posting your question in povray.general, but you can't attach
files there either, so you would have to copy the scene file in - I don't
recommend that given that you said it was pretty big - but you could post the
scene files in p.b.s.f and direct people there in your question.
I really do wish I could be more helpful.
A.D.B.
Date: 17 Oct 2012 20:52:44
Message: <507f52dc@news.povray.org>
for testing purposes: Wrap all triangles in a union { ... }
give them a texture with ambient finish (and render without radiosity
so you can see the geometry even if lighting is not yet good)
try adding "scale 0.1, scale 0.01, ..." to the union to see if
you can get an overview of where you are in the geometry.
the camera should be looking at the origin from outward for this.
Date: 18 Oct 2012 03:30:26
Message: <507fb012@news.povray.org>
> NUMBER...).
Hint: If Poseray does not show a preview and gives an error, I am afraid
something is wrong with some of the triangles somewhere...
Try what Christian suggests and see where that gets you.
Date: 18 Oct 2012 04:45:00
Message: <web.507fc1041e176d5097c1fbff0@news.povray.org>
> > NUMBER...).
> Thomas
It's crazy (the mesh)!
I tried the Chrisitan suggestion, but nothing happened, at least not a something
obvious, in some cases I lost the scene.
and I don't think that there would be something wrong with triangles (though I
prefer this one)becuase the STL file is generated by a 3D modeller software.
But interestingly, when i check the scene statisitics, my object has been
recognized as an INFINITE object not a FINITE object, dose it seems rational????
By the way, many thanks for suggestions guys so far.
If I find the solution will inform you.
Date: 18 Oct 2012 14:42:37
Message: <50804d9d$1@news.povray.org>
Looking a bit closer I think something is *seriously* wrong with
your triangles
  <0.0147179, 0.999892, 0.000199087>,
You don't want vertexs anywhere near z= e+012 ... ;)
And the e-019 is also suspicious although it might just
be a 0 with numerical errors.
Date: 18 Oct 2012 22:34:30
Message: <5080bc36$1@news.povray.org>
> Hi,
> 0.000199087>,
> 0.000199087>,
> 0.124723>
> Thanks!
> Vincent
The format for a smooth triangle is vertex1, normal1, vertex2, normal2,
vertex3, normal3.
If the inc file start with mesh{ and have a } at it's end, there should
be no problem.
Let see, this triangle have 2 identical points making it a degenerate
triangle. Degenerate triangles are not rendered. If I remenmber
correctly, 1e-19 is smaller than the epsilon value, whitch is a
thresshold value to truncate to zero.
Next, you have a point at 3.35e12, whitch is an extremely large value
(3.35 millions of millions). This can cause the mesh to appear as been
infinite even if it's not the case, and most of it's triangle degenerate
and not rendered.
If even one point of a triangle is to far away, it will probably not be
rendered. Christian proposed scaling your mesh down by 10, 100,... In
this particular case, you may need to scale down by 1e-7 to 1e-9 to have
anything... This will make many triangles become sub-pixel in size, even
if rendered at 16000 by 12000 pixels.
Your range of values going from 1e-19 to 1e12 is extreeme with a
variation of 31 orders of magnitude. You just can't render such a scene
without busting the floating point precision limits. Try keeping the
range of values in your scene within 6 orders of magnitude or less.
Next, when a finite object surround the camera, it often register as
infinite, as in unboundable. Try rendering this and look at the statistics:
sphere{0, 30 pigment{bozo} finish{ambient 1}}
//no camera so use the default one siting at the origin pointing toward +Z.
Try rendering with +q0 on the command line. This will make all texture
ambient 1 and turn off any light. It's a good debuging tool and rather
fast. It will make any part shadowed by other to become visible.
Date: 19 Oct 2012 01:25:09
Message: <web.5080e35c1e176d5097c1fbff0@news.povray.org>
> > Hi,
> > 0.000199087>,
> > 0.000199087>,
> > 0.124723>
> vertex3, normal3.
> be no problem.
> and not rendered.
> Alain
Thanks a lot Alian, you and Christian are saying the same thing, and it seems
that it should be the only solution to this problem. I'm working on it...
