POV-Ray : Newsgroups : povray.newusers : povray output as a film/CCD Server Time
22 Jan 2025 03:12:34 EST (-0500)
  povray output as a film/CCD (Message 1 to 10 of 10)
Subject: povray output as a film/CCD
Date: 3 Jul 2012 15:15:01
Message: <web.4ff343d84f92bc799b0928190@news.povray.org>
I'm just wondering if there has been any updates to POV-ray since this 2004
thread in regards to acting as a film/CCD screen...?
http://news.povray.org/povray.newusers/thread/%3C41ab944a@news.povray.org%3E/
Instead of using povray's predefined camera's I would like to use my own stack
of lenses to play with focus and depth of field. Any examples would be extremely
helpful.
Subject: Re: povray output as a film/CCD
Date: 3 Jul 2012 17:58:51
Message: <4ff36b1b$1@news.povray.org>
Am 03.07.2012 21:11, schrieb spitz:
Have a look at the new mesh camera feature; it might be of use in such a
context.
Date: 5 Jul 2012 10:30:00
Message: <web.4ff5a44cfaf6826b9b0928190@news.povray.org>
Are there any examples using this feature? Maybe a lens projecting the image of
an illuminated 3D scene on the mesh(film/CCD) showing depth of field.
> context.
Date: 6 Jul 2012 05:06:58
Message: <4ff6aab2$1@news.povray.org>
Am 05.07.2012 16:28, schrieb spitz:
 > [mesh camera]
I have to hand that question over to the people who have more experience
with the feature; I only know it does exist, with a gut feeling that it
might be relevant for your task.
Date: 6 Jul 2012 07:32:43
Message: <4ff6ccdb$1@news.povray.org>
>> [mesh camera] Are there any examples using this feature? Maybe a
>> lens projecting the image of an illuminated 3D scene on the
> experience with the feature; I only know it does exist, with a gut
> feeling that it might be relevant for your task.
   As one of the few who played with it, I'm not sure it could serve
for his purpose, that is, to play with depth of field and focus. At
least in a realistic way... In any case, here are the results of my
tests with this feature:
http://www.ignorancia.org/en/index.php?page=mesh-camera
   As you see at the end, I'm guessing that some sort of "custom focal
blur" could be achieved, but I didn't figure a way to do it.
   I'm not at all an expert on optics (in fact I know next to nothing
about the topic), but I think that just modeling the lenses as meshes
and using these as mesh-cameras will not do the trick... standard focal
blur doesn't work with mesh cameras (and anyhow it's not related to real
world f-stops).
   Again just guessing, but I have the feeling that what he needs is
something like the camera implementation on the Lux renderer.
Jaime
Date: 6 Jul 2012 15:15:01
Message: <web.4ff73843faf6826b9b0928190@news.povray.org>
There was a nice thread on LuxRender about this
http://www.luxrender.net/forum/viewtopic.php?f=14&t=4766
In this case the CCD sensor or image plane simply is a plane with translucent
material with transmission set to 1 and reflection set to 0. An orthographic
camera was used to sample this image plane.
Would this be possible in POV-Ray...?
> world f-stops).
> Jaime
Date: 6 Jul 2012 19:39:26
Message: <4ff7772e@news.povray.org>
Am 06.07.2012 21:11, schrieb spitz:
In this quality? Pretty likely so.
The key issue here is how to model the sensor; I can think of two
approaches:
(A) Use a non-solid object (e.g. a disc, or a union of two triangles);
give it a perfectly white pigment, no highlights, no reflection, and
"diffuse 0.0, 1.0" (sic!); this syntax introduced in POV-Ray 3.7
specifies that 0% of incident illumination should be scattered /back/
diffusely (first parameter), while 100% should be scattered /through/
the surface instead (second parameter); this makes sure your sensor does
not scatter light back into the scene.
To actually make use of this approach, you'll need to use radiosity, and
you need to use special settings that make sure that you get a lot of
radiosity samples; "maximum_reuse" is of particular importance in this
context and should be very low. Radiosity sample density will be a
problem though (as it limits the resolution of your sensor), and you
might actually end up with a high memory footprint.
(B) Actually, the "sensor" used in the Luxrender example does nothing
but apply pretty random perturbations to the rays going through it. It
so happens that POV-Ray has a dedicated feature to perturb camera rays,
aptly referred to as "Camera Ray Perturbation" in the docs, which works
by adding a "normal" statement to the camera statement. If the specified
perturbation is fine enough and has a suitable distribution, and you
make generous use of anti-aliasing, it'll make the /perfect/
sensor-imitation screen for your camera: It'll cause no backscatter at
all, you don't have to worry about positioning it relative to the
camera, you don't need to use radiosity if you don't like it, and so on.
That said, I'm not yet sure what formula is used for the perturbation
effect (whether it is equivalent to looking at a correspondingly
perturbed mirror, or whether the ray directions are modified directly as
if they were the normals), nor what kind of angular dependency is
realistic for a CCD's response to incoming light (lambertian law might
be a first approximation, but I guess it's not that simple), let alone
what pattern would most faithfully model the scattering effect. But for
starters I'd try with "normal { bumps 0.5 }" or something along these
lines. There's always the possibility of changing the pattern later to
make it more realistic once you're convinced that it's worth the effort
and have figured out what actually /is/ realistic anyway.
As another alternative, you could try with very out-of-focus focal blur,
setting the focal point maybe halfway between the camera and the lens,
and "aperture" to the difference between the camera diagonal size and
the lens' diameter. I don't know whether this is a suitable model for
the anular dependency of a CCD's response though, and you can't just
tweak it very much as you can do with the camera perturbation approach.
Oh, and then I just read about the mesh camera: You /can/ use it for
your purposes, using distribution type 0. Use multiple meshes, each
defining the same points from which to shoot a ray, but use different
randomized surface normals for each mesh to jitter the directions in
which rays are shot (you can use the very same normal for all triangles
in a mesh, or randomize them even within one mesh). This gives you more
direct control over the sample directions as compared to the perturbed
camera approach. See the docs or the wiki for more details on mesh cameras.
Date: 13 Jul 2012 18:15:01
Message: <web.50009d33faf6826b9b0928190@news.povray.org>
I'll look more into the mesh camera. My goal is to simulate the Lytro camera
which consists of a lens and a micro lens array in front of the CCD. Once I get
the simulated CCD image I plan to use matlab for performing digital refocusing.
Do you think this is feasible using POV-Ray...?
> approaches:
Date: 13 Jul 2012 18:30:10
Message: <5000a172$1@news.povray.org>
Am 14.07.2012 00:12, schrieb spitz:
Quite possible.
Subject: Re: Plenoptic camera (was: povray output as a film/CCD)
Date: 28 Dec 2012 11:30:23
Message: <50ddc91f$1@news.povray.org>
   Well, at the time I didn't know what the $%&$& you were talking
about... and surely I was busy enough to get interested on "yet another
POV-Ray experiment" that sounded like too difficult. :)
   But now, I recently received a personal request to help with this
very same subject, and the fact is that this time I got interested...
I'm not sure why. So, I did a bit of my usual chaotic research, and
finally figured out something that looks like a solution, using the mesh
camera of course.
   See the result on p.b.images, which I think simulates the raw output
of a plenoptic camera (like the Lytro), or so I think... because I can't
say for sure: the info on plenoptic cameras is either very dense or too
superficial, and seems there is no available software to try myself that
"refocusing" thing on my images.
   In case anyone is interested, here are the sources:
http://www.ignorancia.org/en/uploads/experiments/plenoptic/plenoptic-camera-2.zip
   I would appreciate if someone with real knowledge on the matter could
tell me if I got it right, or at least not totally wrong...
Jaime
