POV-Ray : Newsgroups : povray.newusers : Using POV-Ray to compute lightmaps Server Time
1 May 2026 17:22:33 EDT (-0400)
  Using POV-Ray to compute lightmaps (Message 1 to 2 of 2)
Subject: Using POV-Ray to compute lightmaps
Date: 22 Jun 2012 02:45:01
Message: <web.4fe413c8145927416fc3bf760@news.povray.org>
Hello! I'm newbie at POV-Ray.
I have successfully tried mesh_camera demo to bake textures. But I have one
question. How can I bake to textures only lightmaps? Only shadows and radiosity
without diffuse texture of mesh.
Subject: Re: Using POV-Ray to compute lightmaps
Date: 22 Jun 2012 11:13:07
Message: <4fe48b83$1@news.povray.org>
Am 22.06.2012 08:42, schrieb C.Rivlaldo:
Use a plain white texture (pigment rgb 1, diffuse 1).
Note however that this will distort radiosity results; you /need/ the
final pigment & finish settings for proper computations (unless your
object happens to be convex, you're using recursion_limit 1, and there
are no reflective objects in your scene).
If you have an approximation of the final pigment & finish, you can use
two copies of your object: One plain white one with "no_radiosity
no_reflection no_shadow", and one with the approximated texture and
"no_image".
