POV-Ray : Newsgroups : povray.newusers : White comes out grey Server Time
1 May 2026 20:15:38 EDT (-0400)
  White comes out grey (Message 1 to 5 of 5)
Subject: White comes out grey
Date: 4 Jun 2011 06:55:01
Message: <web.4dea0ec46ddba0116731f09e0@news.povray.org>
I have found discovered that applying a color to an object renders it black,
while if I apply a texture, it gets rendered in that texture's basic color.
But I cannot get the object to render in white, it remains a dullish grey even
if I define my own White texture (called Wit, Dutch for White). Here's the
scene: http://home.ooijer.com/povray/color-test.zip (pov and jpg) The difference
can't be caused the lighting, not in this scene, can it?
BTW this is with povwin 3.6.
Please help?
Subject: Re: White comes out grey
Date: 4 Jun 2011 07:09:30
Message: <4dea126a@news.povray.org>
The first thing I notice is you have #version 3.5;
I would change that to #version 3.6; for a start.
Then your Finish is
		finish {
			ambient 0.0
			specular 0.0
			roughness 0.2
Which means that the colour of your sphere is only that of the light
reflected off it.
Read the help 3.5.3 Finish
And maybe add some ambient and diffuse.
Sorry I can't actually render your scene but I'm running a long
animation just now.
Regards
Date: 4 Jun 2011 07:14:03
Message: <4dea137b$1@news.povray.org>
Am 04.06.2011 12:53, schrieb Marco:
And yet it is.
Your only light in the scene is the parallel one (the other doesn't have
any effect as it is inside the black sphere), which has a brightness of 0.8.
Your "Wit" texture uses a pigment of brightness 1.0, but as you don't
specify a "diffuse" value, it uses the default of 0.6 for that. You also
don't use any specular or ambient term.
The resulting maximum brightness (at the point on the sphere directly
facing the light source) is therefore
     0.8 * 1.0 * 0.6 = 0.48
which, obviously, is far from 1.0, which would be a fully white pixel color.
Note that a "diffuse" value of <<1.0 is indeed realistic, even for
"white" materials, as only few materials come even close to this value;
strictly speaking, a sheet of white paper would have to be called
"bright grey". The problem, therefore, must indeed be attributed to a
lack of lighting.
Date: 4 Jun 2011 07:35:35
Message: <4dea1887$1@news.povray.org>
> black, while if I apply a texture, it gets rendered in that texture's
> basic color.
   Didn't you see the warning when rendering that scene? :
>> File 'color-test.pov' line 72: Parse Warning: Quick color belongs
>> in texture. Color ignored.
   You cannot use the color keyword alone, you need to at least enclose
it on a pigment{}.
>  grey even if I define my own White texture (called Wit, Dutch for
> White). Here's the scene:
> difference can't be caused the lighting, not in this scene, can it?
   Read clipka response... lighting is everything! (at least if you don't
use full ambient/emission). It's a mystery to me why do you think
lighting should not affect the perceived color of an object...
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 8 Jun 2011 17:05:00
Message: <web.4defe2eafcf0f40e6731f09e0@news.povray.org>
Hi guys,
Thanks so much for the replies, I learned so much from your posts! I had already
been using poray for quite some time (and quite succesfully as well), so I
consider myself to not be a noob, but you made it clear that I have so much to
learn still. Time to ge back on gthe learning curve I guess... And I've been
working on this scene on and off for such a long time, I lost track of the
changes I made. Big bad omy part, need to focus on 1 thing at a time.
 (p.s. I knew about the light inside the sphere, originally I intended to make a
cutout and make a light shine from inside of it, I just forgot to remove the
light)
And yes, I missed that parse warning, thanks for the heads-up.
