POV-Ray : Newsgroups : povray.newusers : ?? Parse Error: Keyword 'point_at' cannot be used with standard light sourc= Server Time
22 Jan 2025 11:51:51 EST (-0500)
  ?? Parse Error: Keyword 'point_at' cannot be used with standard light sourc= (Message 1 to 3 of 3)
Subject: ?? Parse Error: Keyword 'point_at' cannot be used with standard light sourc=
Date: 18 Nov 2010 16:10:00
Message: <web.4ce595936e6e92f6731f09e0@news.povray.org>
So I'm making a free-floating clock (without face-background surface) And I
wanted to have the 4 big hour markers shine light to the centre of the object,
so I used point_at. But this yields this weird error:
Parse Error: Keyword 'point_at' cannot be used with standard light source.
aI don't know how to solve this, so I'd like some help please.
Source:
#while (counter<12)
  object
  hourmark
  rotate z*(counter*30)
 #declare counter=counter+1;
#declare fourmark=light_source
 <0,3.7,0>, rgb <0,0,0>
 point_at <0,0,0> SPOTLIGHT_ITEM
looks_like
cone
 <0,3.7,0>,2, <0,4.5,0>,0.5
#declare counter=0;
#while counter<4
 object
 fourmark
Subject: Re: ?? Parse Error: Keyword 'point_at' cannot be used with standard light sourc=
Date: 18 Nov 2010 17:41:31
Message: <op.vmd1bomkq4w9ih@whitebishop>
> And I
> object,
> source.
You are using a point light; a point light source irradiates equally in
all directions and therefore the point_at keyword makes no sense. Either
remove the point_at statement or add the spotlight keyword before it.
Hugo.
 From a certain point onward there is no longer any turning back.
That is the point that must be reached.
Franz Kafka
Date: 18 Nov 2010 22:17:27
Message: <4ce5ec47$1@news.povray.org>
point_at only make sense when using a spot_light, a parallel light or a
cylindrical light.
When applyed to a point_light, it just don't make any sense.
You can use a spot_light.
You can remove the looks_like and use a regular cone with the open
keyword to remove it's end cap and place the light_source inside it
slightly off the summit. Or, in the case of a truncated cone, clip one
end using clipped_by{object}
#declare Fourmark=
union{
cone{<0,3.70001,0>,2, <0,4.5,0>,0.5
//Extend the cone very slightly...
  clipped_by{box{<2,3.7,2>,<-2,4.501,-2>}}
//...and clip off the extended part
light_source{<0,4.4,0> rgb 1}
#while(Counter < 12)
object{
//use the modulo function to switch between the two marks
#if(mod(Counter/3)=0)
  Fourmark
#else
  Hourmark
rotate z*(Counter*30)
#declare Counter = Counter +1;
Some advises:
Don't #declare tour Fourmark inside the loop but before the #while.
A light_source with rgb 0, rgb<0,0,0>, is useless as it don't illuminate
anything at all.
Good practice: Always begin user identifiers with an UPPER CASE letter.
All reserved keywords start with a lower case letter. Using an upper
case as the first character ensure that you'll never have a conflict
with those reserved keywords.
