POV-Ray : Newsgroups : povray.newusers : POV-Ray cannot read ini file Server Time
1 May 2026 23:42:40 EDT (-0400)
  POV-Ray cannot read ini file (Message 1 to 8 of 8)
Subject: POV-Ray cannot read ini file
Date: 10 Aug 2010 15:50:00
Message: <web.4c61ac90e98d40de519590f00@news.povray.org>
"Cannot open INI file 'C:Documents and Settings/Owner/My
Documents/POV_Ray/v3.6/ini/povray.ini'
I have the INI file in My Documents as well as the POV-Ray folder.  The
povray.ini is in both folders.
I do not understand why the program can't read it.
Any help would be appreciated.
Karen
Subject: Re: POV-Ray cannot read ini file
Date: 10 Aug 2010 17:20:00
Message: <web.4c61c17f1a8155a8fd54cae30@news.povray.org>
> Karen
Hi, Karen! I noticed a missing / after C: , maybe that is the problem? Take a
look in the Render-menu, option Edit Settings/Render - what path do you see in
the INI file-section?
Cheers,
Haakon
Date: 11 Aug 2010 07:45:01
Message: <web.4c628cf01a8155a8519590f00@news.povray.org>
> > Karen
> Cheers,
> Haakon
Thank you for responding Haakon.  That was my typing, I left it out.
The additional error message is "Failed to start render: failed to parse INI
file"
Date: 11 Aug 2010 08:32:54
Message: <4c629876$1@news.povray.org>
Hi Karen and welcome.
Tools > Edit master POVRAY.INI?
If so I would uninstall PovRay and reinstall it.
Best Regards,
Date: 11 Aug 2010 10:45:01
Message: <web.4c62b7561a8155a8519590f00@news.povray.org>
> Best Regards,
>  Stephen
Hello Stephen,
When I follow that path, the Tools menu only gives me "Help On this Menu" and
"Re-load Tool Menu."
I've tried moving the INI file and rerouting the path, with no luck.
I have uninstalled it and reinstalled it.  I have 3.6 and 3.7 and they both have
trouble with the INI file.  that's why I'm so frustrated with it.
Date: 11 Aug 2010 12:05:02
Message: <4c62ca2e$1@news.povray.org>
On 11/08/2010 3:44 PM, kbogoski wrote:
> Hello Stephen,
Would it be too inconvenient to System Restore your system to before you
installed PovRay?
Are you confident enough to edit the registry?
I would be tempted to uninstall both versions of PovRay run Regedit and
remove all the entries that refer to PovRay. Then reinstall PovRay 3.6.2
and see if that runs.
Best Regards,
Date: 12 Aug 2010 08:30:00
Message: <web.4c63e8351a8155a8a903812a0@news.povray.org>
> > Hello Stephen,
> installed PovRay?
> Best Regards,
>  Stephen
I was thinking it was a computer thing.  I'll give it a try.
Karen
Date: 12 Aug 2010 08:54:44
Message: <4c63ef14$1@news.povray.org>
Don't forget to make a restore point first. :-D
Best Regards,
