POV-Ray : Newsgroups : povray.newusers : How to use #Macro like a function ? Server Time
22 Jan 2025 15:01:24 EST (-0500)
  How to use #Macro like a function ? (Message 1 to 7 of 7)
Subject: How to use #Macro like a function ?
Date: 29 Jun 2010 14:35:00
Message: <web.4c2a3bf6d73f9cb9e3006550@news.povray.org>
Hi !
I would like to make some functions. But I found POV-Ray's functions very
limited : it seems it is not possible to use directives inside.
So I decided to use macro instead, since I want to use them once at parse time
only.
From what I had understood, the #macro works pretty much as if it replaced the
call with the content of the macro.
However, I'm trying to make macro that return a float value, so I tried
something like :
#macro MyMacro(arg)
  #if (arg > 1)
    5
  #else
    10
But it doesn't work...
I saw some exemples like that :
#macro MyMacro(arg)
  #if (arg > 1)
    #declare X=5
  #else
    #declare X=10
But it doesn't seem right, I don't like toying with global var from inside
functions like this, I feel like I could overwrite some previous val...
Is there a clean way to do this kind of things ?
Subject: Re: How to use #Macro like a function ?
Date: 29 Jun 2010 14:45:07
Message: <4c2a3f33$1@news.povray.org>
> Thanks :)
You might want to try the documentation: "2.2.2.8.4 Returning a Value Like a
Function" <http://www.povray.org/documentation/view/3.6.1/243/>
Also, check the sample files and includes provided with POV-Ray, they
contain lots and lots of examples.
	Thorsten
Date: 29 Jun 2010 15:40:00
Message: <web.4c2a4b875abfbec8e3006550@news.povray.org>
Wow, I understand what didn't work...
Well, partly...
I used the macro in a declare :
#declare MyVar = MyMacro(MyStuff);
But POV-Ray parsed the macro and found some #if and #else BEFORE the expected
semi-colon...
So I have to put the semi-colon IN the macro, and not in the #declare line...
I think I'll use extra arguments to return the value instead...
Date: 29 Jun 2010 16:09:49
Message: <4c2a530d$1@news.povray.org>
Am 29.06.2010 21:37, schrieb Gyscos:
> Well, partly...
> semi-colon...
This one will do:
   #macro MyMacro(arg)
     #if (arg > 1)
       #local RetVal = 5;
     #else
       #local RetVal = 10;
     RetVal
Note that the value to be returned is stored in a local variable first,
which is then "returned" at the very end of the macro.
Extra arguments as return values are pretty cumbersome, as you'll always
have to make sure that the respective variable is defined properly
before being passed to (and back from) the macro.
Date: 30 Jun 2010 01:25:00
Message: <web.4c2ad3fd5abfbec8e3006550@news.povray.org>
Wow, cool :)
Date: 2 Jul 2010 08:35:32
Message: <4c2ddd14@news.povray.org>
news:4c2a530d$1@news.povray.org...
> ... #macro MyMacro(arg)
>     #if (arg > 1)
>       #local RetVal = 5;
>     #else
>       #local RetVal = 10;
>     #end
>     RetVal
>   #end
#macro MyMacro(arg)
    (arg>1)?5:10
klp
Date: 3 Jul 2010 02:40:19
Message: <kurtzlepirate-7D45E3.08401803072010@news.povray.org>
In article <4c2ddd14@news.povray.org>,
 "kurtz_le_pirate" <kur### [at] yahoofr> wrote:
> #macro MyMacro(arg)
>     (arg>1)?5:10
> #end
ooops...
  #macro MyMacro(arg)
    ((arg>1)?5:10)
klp
