POV-Ray : Newsgroups : povray.newusers : Rendering ran out of memory Server Time
12 Jul 2025 08:14:13 EDT (-0400)
  Rendering ran out of memory (Message 1 to 6 of 6)
Subject: Rendering ran out of memory
Date: 24 Jan 2010 13:50:01
Message: <web.4b5c961a5a9b58596f805b290@news.povray.org>
Hi
I used an algorithm that consists of sines, cosines, and polar coordinates, to
construct 'Rose' objects that consist of 360 cylinders.
I then used nested while loops to create an array 180 x 180 of 'Roses' with
various parameters.
When I ran it, it got to ->
parsed 315000000+ tokens
and gave a message to the effect, "ran out of memory' , basically slowed down my
computer and almost crash my computer.
Question.
Is there a way to connect my computer via Internet to a server type renderer to
run my pov file?
Or, is my file just an example of poor programming?
pseudocode looks something like
while y <= 180     // creates a 180 x 180 array
   while x <= 180
     while Rose_object <= 360 cylinders
       rose has parameters (a, b)
             find all roses for ->
             a <= 180    // start a = 1 and increment
             b <= 180    // start b = 1 and increment
            some values return errors,  skip those
            algorithm has about 14 variables that change for each loop.
      end
   end
end
Can I connect to a more powerful computer to render?
thanks
Subject: Re: Rendering ran out of memory
Date: 24 Jan 2010 22:58:46
Message: <4b5d16f6$1@news.povray.org>
It's tough to tell just from the pseudo-code, but
you may not have incremented the counters.
#declare c=0;
#while (c<100)
   // foo
   #declare c=c+1;
Date: 26 Jan 2010 00:05:00
Message: <web.4b5e77c6efff664b6f805b290@news.povray.org>
> #declare c=0;
> #while (c<100)
>    // foo
>    #declare c=c+1;
> #end
yes, the counters were incremented
   while x <= 180
      end
  x = x + 1
a = a + 1
b = b + 1
   end
y = y+1
end
I reran the file
for x < 50
    y < 50
the file creates 900000  cylinders
parse time 42 minutes
render time 7 minutes
anything larger, will of course take more time.
And it is impossible to run for x < 180 and y < 180 without more memory.
Unfortunately , I can't upload an attachment.
Date: 29 Jan 2010 20:11:58
Message: <4b63875e$1@news.povray.org>
> I reran the file
> for x < 50
>    y < 50
Ah, it's just too many objects then.
I think POV will run on Amazon, but I've never used it
personally to know the ins and outs.
http://aws.amazon.com/ec2/
You could redesign the scene to use less memory...
make a few dozen copies of your object, then place
them randomly rotated...
Date: 30 Jan 2010 19:51:36
Message: <4b64d418@news.povray.org>
>> I reran the file
>> for x < 50
>> y < 50
The first place to look: remove the texture from the individual objects,
put them in an union, and apply the texture to the union.
You only use textures for the components IF AND ONLY IF it's texture is
different than that of the majority of the components.
The more numerous component are probably the petals, so, you give the
petals texture to the union.
At 50x50, you get 900 000 cylinders.
180 is 3.6 times 50.
At 180x180, you get 900 000 * 3.6 * 3.6 = 900 000 * 12.96 = 11 664 000
11 millions, 664 thousand cylinders!
Each cylinder uses 2 end coordinates, one radius, a transform matrix
and, if individualy textured, a texture.
The texture can easily be the part that uses the most memory.
Date: 4 Feb 2010 16:25:01
Message: <web.4b6b3a3eefff664bd7d043ea0@news.povray.org>
Yes
All the cylinders have the same texture, so I did as you said, and created a
union, and added only one instance of the texture at the end.
This was a more advanced feature that I have yet to reach.
Also, I modified one of the while loops to calculate the minimum number of
cylinders (lines) for each object.
There are now less than half the number of cylinders from my first version, more
unique objects, and by adding the same texture to all cylinders, it took about
two minutes to parse and about two hours to render 1280x1024, AA .3
