POV-Ray : Newsgroups : povray.newusers : General transformation of an object Server Time
12 Jul 2025 11:05:06 EDT (-0400)
  General transformation of an object (Message 1 to 7 of 7)
Subject: General transformation of an object
Date: 30 Oct 2009 12:05:01
Message: <web.4aeb0d65636728607fab4e430@news.povray.org>
Hi! Is it possible to make a genetral transformation of an object in Povray in
the way that I assign a new values (x',y',z') to the existing x,y,z coordinates
of the object, according to some rule? E.g. I have the following: x'=x; y'=
y+0.8*z*(y*z)/(300-z); z'=0.8*z . I was trying to play around with matrix, but
it doesn't seem to be the way.
Subject: Re: General transformation of an object
Date: 30 Oct 2009 12:59:05
Message: <4aeb1b59$1@news.povray.org>
No, POV-Ray only supports affine transformations, i.e. any
transformations where each new coordinate is some linear combination of
the original coordinates and some constant.
Some people have experimented with "slicing" the object to be
transformed, and transforming each slice with a different matrix.
Another approach would be to convert the object to an isosurface (much
work has been done in this direction recently), and then use that to
define another arbitrarily-transformed variant of the object.
Date: 30 Oct 2009 16:16:17
Message: <AgzCGfCck06KFwBM@econym.demon.co.uk>
You can't perform non-linear transformations on general POV objects, but
if you can express your object as an isosurface function you can perform
non-linear variable substitution on that function.
http://www.econym.demon.co.uk/isotut/substitute.htm#nls
Mike Williams
Gentleman of Leisure
Date: 1 Nov 2009 23:48:54
Message: <4AEE650C.1080209@joplin.com>
What are you trying to do with this? There maybe other things you could do
other than use 'matrix'. You might be able to use a macro to deform and
then place your object.
Date: 2 Nov 2009 06:45:01
Message: <web.4aeec54aeee70a117fab4e430@news.povray.org>
In fact the result of the transformation is kind of uneven shearing. The shear
is along the y axis, but the value is proportional to the y coordinate. (If you
imagine a cube, the angle formed by upper side and the z axis is about twice of
the angle formed by the bottom side and the z axis. So the sheared box becomes
wider on one side and narrower on the other side. All the faces remain planar).
I need to use this transformation to compensate a distortion involved by an
optical system while projecting the rendered images. Since the models are of
arbitrary and real sceneries, I doubt being able to convert it to isosurfaces.
Date: 2 Nov 2009 07:38:32
Message: <4aeed2c8$1@news.povray.org>
If the faces really remain planar, you can create the desiered shape
using...
(a) an intersection of planes (Warning: Does not bound properly!)
(b) an intersection of well-sized boxes
(c) a prism object
to name just the first three ideas that cross my mind.
Date: 2 Nov 2009 08:44:16
Message: <4aeee230$1@news.povray.org>
"houmr" <nomail@nomail> wrote in message
news:web.4aeec54aeee70a117fab4e430@news.povray.org...
>> do
>> other than use 'matrix'. ...
> In fact the result of the transformation is kind of uneven shearing...
> an
> of
> isosurfaces.
If it's to address real-world projection issues then it may be possible to
do what you want in two passes:
Pass 1 - Render the scene as normal (or use a scanned photo).
Pass 2 - Apply the image to a surface within a scene that emulates the
physical screen, projector and potentially any strange optics. The camera or
cameras can be positioned where the projector would be in the equivalent
real-world environment, using appropriate lens settings so that you get
images that are appropriately distorted.
I recall that someone was using this sort of technique a few years back to
adjust images projected from 4 projectors onto a cylindrical screen so that
they could mesh the images together correctly into a full 360 degree image.
Chris B.
