POV-Ray : Newsgroups : povray.newusers : How do I add color to "sphere_sweep"? Server Time
22 Jan 2025 21:40:40 EST (-0500)
  How do I add color to "sphere_sweep"? (Message 1 to 9 of 9)
Subject: How do I add color to "sphere_sweep"?
Date: 12 Aug 2009 03:55:00
Message: <web.4a82745d1c23c4f8db8ca50@news.povray.org>
How can I add 'true-indexed' RGB color to each point along a "sphere_sweep"
object? In other words, if this "sphere_sweep" object is defined by N points, I
would like to be able to specify N RGB colors.
Many thanks in advance for helping me out!
Cheers,
Alex
Subject: Re: How do I add color to "sphere_sweep"?
Date: 12 Aug 2009 04:34:40
Message: <4a827ea0@news.povray.org>
"Alex" <ale### [at] hotmailcom> wrote in message
news:web.4a82745d1c23c4f8db8ca50@news.povray.org...
> Hi,
> "sphere_sweep"
> points, I
> Cheers,
> Alex
I don't think there's an easy way of doing exactly that. OTOH you can do
something equivalent using splines and a #while loop quite easily. The
spline example below is taken straight from the spline section in the help
and illustrates using different colors along the length of an object created
using lots of spheres (in this case about 100). It shouldn't be too
difficult to adapt that to do something equivalent to what you ask.
camera {location <-1, 1,-1> look_at <0,0,0>}
light_source {<1,10,-1> color rgb 1}
#declare MySpline = spline {
  cubic_spline
  -.25, <0,0,-1>
  0.00, <1,0,0>
  0.25, <0,0,1>
  0.50, <-1,0,0>
  0.75, <0,0,-1>
  1.00, <1,0,0>
  1.25, <0,0,1>
#declare ctr = 0;
#while (ctr < 1)
  sphere {
    MySpline(ctr),.25
    pigment { rgb <1-ctr,ctr,0> }
  #declare ctr = ctr + 0.01;
Chris B.
Date: 12 Aug 2009 05:40:00
Message: <web.4a828deaff67402bdb8ca50@news.povray.org>
> > Hi,
> > "sphere_sweep"
> > points, I
> > Cheers,
> > Alex
>   cubic_spline
>   -.25, <0,0,-1>
>   0.00, <1,0,0>
>   0.25, <0,0,1>
>   0.50, <-1,0,0>
>   0.75, <0,0,-1>
>   1.00, <1,0,0>
>   1.25, <0,0,1>
> #declare ctr = 0;
> #while (ctr < 1)
>   sphere {
>     MySpline(ctr),.25
> #end
> Regards,
> Chris B.
Thanks Chris,
Some follow up questions:
* In the documentation, I cannot really find any info on the first parameter of
the spline function (-.25, 0.00, etc.). What does is do? With sphere_sweep I
don't need to define these values...
* I already have predefined matrices (N x 3) of colors and of "sphere widths".
How do I add them to the scene (instead of calculating them on the fly)?
* I am also worried about efficiency, as I am modelling many objects of this
kind: let's say 10000 "hyperstreamtubes" (a sphere_sweep object with variable
width), with each these consisting of 100 points. Here you can see an example:
http://www.exploredti.com/gallery/gof_2.htm
Cheers,
-A
Date: 12 Aug 2009 06:42:44
Message: <IDs45ZEaypgKFwCp@econym.demon.co.uk>
>parameter of the spline function (-.25, 0.00, etc.). What does is do?
>With sphere_sweep I don't need to define these values...
You do if you're using cubic_spline mode of sphere_sweep.
A cubic spline can only be calculated between the second and
next-to-last of the control points, so a phantom point needs to be added
at each end.
If you really don't have such extra points in your sphere_sweep, then I
guess that means that you're using linear_spline mode. In that case
using cones and cylinders, with spheres at the nodes for neat joins, is
more efficient than hundreds of spheres.
>this kind: let's say 10000 "hyperstreamtubes" (a sphere_sweep object
>with variable width), with each these consisting of 100 points. Here
>you can see an example: http://www.exploredti.com/gallery/gof_2.htm
Sphere_sweeps are inherently not very efficient, because the algorithm
is quite complicated. You may well find that lots of simpler objects
render faster. Lots of simpler objects will bound better when you have
long strings like in that example.
However, lots of simple objects will always give you rounded edges. If
you want spiky edges like in that example, you might consider something
like the SweepSpline macro
See the bottom section of http://www.econym.demon.co.uk/isotut/more.htm
SweepSpline produces a mesh2 object which renders very quickly, but if
you've got lots of detail it may take a while to parse. You can save the
parsed mesh2 object to a file (see comments at the top of
sweepspline.inc) and skip the parse phase next time.
To colour a sweepspline along its length, use uv_mapping, like this:
object {
  SweepSpline(USpline, VSpline, WSpline, Upoints, Vpoints, Filename)
    pigment { uv_mapping
      function{u}
      colour_map {...}
where the colour_map specifies the colours to be used along the length.
Mike Williams
Gentleman of Leisure
Date: 12 Aug 2009 09:26:13
Message: <4a82c2f5@news.povray.org>
"Mike Williams" <nos### [at] econymdemoncouk> wrote in message
news:IDs### [at] econymdemoncouk...
I think Alex was referring to the 'val_1', 'val_2' parameters on the spline
function. As Mike says, you will still need all of the same coordinates for
points on the curve and for the control points for 'curved' curves, but the
'val_n' settings are a feature specific to the spline function.
The best way I can explain it is that this value represents how far through
the spline the point is and is usually defined so that the visible points
lie from 0 to 1. Any additional control points that aren't on the curve
(used at the start or end of a curve) can be defined using values less than
0 or greater than 1, so the initial control point for the cubic spline was
defined with a 'val_n' value of -0.25. You can more or less define whatever
spacing you want with these values, but the example #while loop that I
posted before assumed that the points were more or less evenly spaced
distance-wise, so it simply incremented it's way along the spline using this
value (The example below removes this assumption).
When you come to use a spline function you specify a number from 0 to 1 as a
parameter and it returns the coordinate on the curve based on how the number
you specify relates to the 'val_n' settings that the spline was defined
with.
Mike's macro looks like it will give you by far the best performance,
especially with the option to store the generated mesh to disk to cut down
on parse times. The mesh2 object is very efficient and a uv_mapped color_map
is likely to be the easiest way of using the N*3 color matrices that you
mentioned. Using 1000 spheres for each of 10,000 "hyperstreamtubes" would
probably be slow, particularly if your machine starts paging. Nevertheless
I've pasted a short example using the "lots of spheres" approach below my
signature in case this is of any interest.
Chris B.
camera {location <-1, 1,-2> look_at <1,0.3,0>}
#declare PointCount = 6;
#declare SeparationRatio = 0.01;
#declare Segments = PointCount-1;
#declare Spline = spline {
  cubic_spline
  -0.25, <0   ,-1  ,0>
   0.0 , <0   , 0  ,0>
   0.18, <1.4 , 0.6,0>
   0.2 , <1.45, 0.6,0>
   0.4 , <1.5 , 0.6,0>
   0.6 , <1.55, 0.6,0>
   0.62, <1.6 , 0.6,0>
   0.8 , <2.5 , 0.5,0>
   1.0 , <3.5 , 0.5,0>
   1.25, <5   , 1  ,0>
#declare Colors = array [PointCount] {
  <1,0,0>, <1,1,0>,
  <0,1,0>, <0,1,1>,
  <0,0,1>, <1,0,1>
#declare Widths = array [PointCount] {
  0.02,0.01,0.08,0.02,0.005,0.02
// Loop through the spline
#declare Ctr = 0;
#declare Last_Point = Spline(-0.2);
#declare TargetSeparation = 0;
#while (Ctr < 1)
  // Work out distance from the previous point.
  #declare This_Point = Spline(Ctr);
  #declare Separation = vlength(This_Point-Last_Point);
  #if (Separation > TargetSeparation)
    // Work out relative distance between control point.
    #declare Proportions    = mod(Ctr*Segments,1);
    // Work out the color at this point
    #declare Previous_Color = Colors[floor(Ctr*Segments)];
    #declare Next_Color     = Colors[floor(Ctr*Segments)+1];
    #declare This_Color     = Previous_Color*(1-Proportions) +
Next_Color*Proportions;
    // Work out the radius at this point
    #declare Previous_Size = Widths[floor(Ctr*Segments)];
    #declare Next_Size     = Widths[floor(Ctr*Segments)+1];
    #declare This_Size     = Previous_Size*(1-Proportions) +
Next_Size*Proportions;
    // Add a sphere the right color and size
    sphere {
      This_Point,This_Size
      pigment { rgb This_Color}
    #declare TargetSeparation = SeparationRatio*This_Size;
    #declare Last_Point = This_Point;
  #declare Ctr = Ctr + 0.0001;
// Axes
cylinder {-10*x,10*x,0.01 pigment {rgb <1,0,1>}}
cylinder {-10*y,10*y,0.01 pigment {rgb <1,1,0>}}
cylinder {-10*z,10*z,0.01 pigment {rgb <0,1,1>}}
Date: 12 Aug 2009 10:55:00
Message: <web.4a82d669ff67402be81b49cc0@news.povray.org>
Dear Mike and Chris,
Chris, I tried your script, but the transition between points with different
widths seems too abrupt (but thanks anyway!).
So I think I will use Mike's tool. However, I found a few things that 'bothered'
me here:
1) The spline that handles the width does not seem to correspond with the real
width (as obtained, for instance, with the 'sphere' object). Some spline issue?
2) The end point seems to be off (not at the right position) and varies, for
instance, according to the 'number-of-Upoints' parameter. Again, spline
related?
3) How do I close the tubes, i.e., put end-caps on it? I guess a sphere or
cylinder does the job, but it is not trivial, given point 1).
I added a toy example below - any suggestions on how to fine-tune the result
that tackles the issues above?
Again - much appreciated!
Alex
camera {orthographic  location  <3, 4, 10> look_at <3, 4, 0> angle 50}
light_source {<3,4,1000> colour rgb <1,1,1>}
#declare tube_width=0.3;
#declare USpline =
   spline {
     natural_spline  // using 'cubic_spline' gives an error?!
    0,    < 5, 6, 0>,
    0.25, < 4, 5, 0>,
    0.5,  < 3, 4, 0>,
    0.75, < 2, 3, 0>,
    1,    < 1, 2, 0>,
// I added a few extra points to make it look more 'circular'...
#declare VSpline =
  spline {
    cubic_spline
   -0.125,  <0.7071,-0.7071,0>,
    0,     < 1, 0,0>,
    0.125,       <0.7071,0.7071,0>,
    0.25,  < 0, 1,0>,
    0.375,       <-0.7071,0.7071,0>,
    0.5,   <-1, 0,0>,
    0.625,       <-0.7071,-0.7071,0>,
    0.75,  < 0,-1,0>,
    0.875,       <0.7071,-0.7071,0>,
    1,     < 1, 0,0>,
    1.125,  <0.7071,0.7071,0>,
#declare WSpline = spline {
  cubic_spline
    0,  tube_width,
    0.25,  tube_width,
    0.5,   5*tube_width,
    0.75,  tube_width,
    1,    tube_width,
#declare Upoints = 50;  // change this to 10 and something strange happens (why
does it get shorter?)
#declare Vpoints = 50;  // Number of points around
#declare Filename = ""
#include "SweepSpline.inc"
object {
           function{u}
           colour_map {[0   rgb<1,0,0>]
                       [0.25 rgb<0,1,0>]
                       [0.5   rgb<1,0,1>]
                       [0.75   rgb<0,1,1>]
                       [1   rgb<1,1,0>]}}
           finish {phong 0.5 phong_size 10}
sphere {<5,6,0> ,tube_width  pigment { rgb <1,1,1> }}
sphere {<1, 2, 0> ,tube_width  pigment { rgb <1,1,1> }}
Date: 12 Aug 2009 13:17:24
Message: <4a82f924@news.povray.org>
news:web.4a82d669ff67402be81b49cc0@news.povray.org...
> different
Actually only the one change is abrupt and that's because I put 3 points
close together and added a very large width change to demonstrate that it
was possible to do abrupt changes. This was because the image you linked to
contained some quite abrupt changes and I didn't want you to think it
couldn't do 'abrupt'. Looks like I overemphasized this capability  :-).
Anyhow I think Mike's is the better way to go for what you want to do.
Chris B.
Date: 12 Aug 2009 15:20:00
Message: <web.4a831561ff67402be81b49cc0@news.povray.org>
> > different
> Regards,
> Chris B.
Hi Chris,
You are right - sorry! And you do not seem to have these strange things
happening as mentioned earlier. So I might end up using your way. But how would
I adjust your tool for multiple "hyperstreamtubes"?
Cheers,
-A
Date: 12 Aug 2009 17:10:00
Message: <web.4a832f0cff67402be81b49cc0@news.povray.org>
I figured it out - *macro's* !
Thanks again for the support!
Cheers,
-A
