POV-Ray : Newsgroups : povray.newusers : Waterfall Server Time
22 Jan 2025 21:45:17 EST (-0500)
  Waterfall (Message 1 to 3 of 3)
Subject: Waterfall
Date: 16 Jul 2009 15:05:00
Message: <web.4a5f78bcf563415a99c7231c0@news.povray.org>
Which object/effects would I use to create waterfall?
I am thinking spline-based object with slight transparency.
Thanks
Subject: Re: Waterfall
Date: 16 Jul 2009 18:37:59
Message: <4a5fabc7$1@news.povray.org>
one possibility for the geometry would be to use a blob
object with a larger number of semi-random components.
As regards the water itself, you should usually do it
almost fully transparent: its appearance is mostly dominated
by refraction and reflection (especially sky is important here,
as well as some surface structure, typically normals). However,
or areas with foam something whitish and not too transparent
is probably better.
Date: 17 Jul 2009 16:05:00
Message: <web.4a60d84940a19a1c851799000@news.povray.org>
> Thanks
I think you can get away with using simple geometry and a good looking texture
for more distant views.  For closer shots, I would also think about making
heavy use of scattering media for the foam and spray.
I think I might have to try making a water fall.
-Reactor
