POV-Ray : Newsgroups : povray.newusers : Objects interacting with photons / Laser Server Time
13 Jul 2025 00:39:15 EDT (-0400)
  Objects interacting with photons / Laser (Message 1 to 9 of 9)
Subject: Objects interacting with photons / Laser
Date: 26 May 2009 06:35:01
Message: <web.4a1bc48ea9dd582089e1bd650@news.povray.org>
Hello There,
I am trying to render a scene, whrere a laser beam is refracted by some objects,
but it just does not work. I found a similar question here
web.487989b0797036a91a8107a20@news.povray.org
and the scene mentioned there actually works. Mine still won't, so what is wrong
with it? Thank you in advance for your help!
#include "textures.inc"
global_settings {
 assumed_gamma 1.0
 max_trace_level 10
 photons {
  count 100000
  autostop 0
  media 1000
  max_trace_level 10
  location  <0,20,-20>
  look_at   <0,0,0>
// scatterbox
box {
 <-10,0,-40>, <10,5,40>
 hollow
  color transmit 1
 interior {
  media {
   scattering {
    1, 1 extinction 0
  samples 30,100
// interacting box
box {
 <2,4,-10>, 0
 translate <0,0,4>
 rotate <0, 45, 0>
 hollow
  color transmit 0.9
 interior {
  media {
   scattering {
    1, 1 extinction 0
   samples 30,100
 ior 1.5
 photons {
  target
  refraction on
  reflection on
// laser
light_source {
 <0,1,-50>
 color red 1.0
 cylinder
 point_at <0,1,10>
 radius 0.2
 falloff 0.2
 tightness 0.1
 photons {
   refraction on
   reflection on
// ambient light
light_source {
 <100,100,150>
 color rgb 1.3
 media_interaction off
 photons {
   refraction off
   reflection off
// floor
plane {
 y, 0
  checker color White color Black
Subject: Re: Objects interacting with photons / Laser
Date: 27 May 2009 07:43:22
Message: <4a1d275a$1@news.povray.org>
"Nurwodah" <nomail@nomail> wrote in message
news:web.4a1bc48ea9dd582089e1bd650@news.povray.org...
> objects,
Didn't look at the other but try this in your global_settings instead:
 photons {
  //count 100000
  spacing 0.02
  autostop 0
  media 50,5
//  max_trace_level 10
I think spacing helps in this case where the photons are in a narrow beam.
And... this is the important part... use a photons block in your scattering
box:
 photons {
  target
  refraction on
  reflection on
  collect off
  pass_through
Now, I should say, I haven't done this particular kind of render in recent
times so don't take it as perfection (or even the right way) but I did get a
good laser beam by doing that. Also to make it faster than what you were
doing I put the media samples down to only 10,30. I even added some
reflection (in finish{}) to the refracting glass and it was still fairly
quick.
Date: 27 May 2009 09:40:00
Message: <web.4a1d416d84c0b6cb7e13cce0@news.povray.org>
Hello Bob,
thank you for your help! Indeed, the missing photon block in the scattering box
was the problem. I did not expect this to be necessary if the refracting glass
block contained a photon block, but obviously I was wrong.
But:
If I use the following source for rendering, I get a rather strange image:
After passing the glass block and being refracted/reflected/absorbed correctly,
the laser beam changes into a dotted line, that looks very much like some
interference pattern. As far as I understand (I mean, almost 99.99% sure!)
POV-ray is of course not capable of calculating phase interactions of light, so
any idea what could have happened here?
global_settings {
 assumed_gamma 1.0
 max_trace_level 10
 photons {
  spacing 0.02
  autostop 0
  media 50,5
  location  <0,20,0>
  look_at   <0,0,0>
// scatterbox
box {
 hollow
  color transmit 1
 interior {
  media {
   scattering {
    1, 1 extinction 0
  samples 10,30
 photons {
  target on
  refraction on
  reflection on
  collect off
  pass_through
// interacting box
box {
 <2,4,-10>, 0
 translate <0,0,4>
 rotate <0, 45, 0>
 hollow
  color transmit 0.9
 interior {
 ior 1.5
 finish {
  diffuse 0.3
 photons {
  target
  refraction on
  reflection on
// laser
light_source {
 <0,1,-50>
 color red 1.0
 cylinder
 point_at <0,1,100>
 radius 0.2
 falloff 0.2
 tightness 0.1
 photons {
   refraction on
   reflection on
// ambient light
light_source {
 <100,100,150>
 color rgb 1.3
 photons {
   refraction off
   reflection off
// floor
plane {
 y, 0
  checker color White color White
Date: 27 May 2009 10:26:49
Message: <4a1d4da9@news.povray.org>
"Nurwodah" <Nur### [at] webde> wrote in message
news:web.4a1d416d84c0b6cb7e13cce0@news.povray.org...
> correctly,
Just got a look at this before going out the door.
I see, yeah, try something like media 200,10 for the global photons and
maybe that will be okay.
You might also need to make 'spacing' a fraction smaller, the exit beam is
fuzzy.
Checking that, I had to use media 300,10 with spacing 0.005 or else the
fragmenting occurs again.
Funny thing, I hadn't realized the two medias (both boxes) wouldn't be
needed-- unless you were going to have different ones, of course.
Date: 27 May 2009 11:20:01
Message: <web.4a1d58a384c0b6cb7e13cce0@news.povray.org>
> fuzzy.
ok, so this is about trial & error.
Yeah, I figured out that when I realized the beam inside the glass thing
appearing about twice as bright as in the surrounding area, the scattering
values probably just sum.
thanks again
Nurwodah
Date: 27 May 2009 21:19:50
Message: <4a1de6b6$1@news.povray.org>
news:web.4a1d58a384c0b6cb7e13cce0@news.povray.org...
>> is
>> fuzzy.
Usually is for me. Moreso with photons. I have enough trouble getting media
alone to look the way I want.
Mixing media containers can be a real challenge. I thought maybe you were
wanting a different kind of substance eventually for the refractive object.
I just ignored the fact it didn't need to have anything but the one
room-filling media until you posted that second time without it. Otherwise I
might have suggested removing that, and possibly thought wrong by doing so.
> thanks again
Glad I could help!
Date: 28 May 2009 10:07:24
Message: <4a1e9a9c$1@news.povray.org>
Maybe you've had better luck than me, I went back to this trying for a good
render because I'm using the new version 3.6.2.
There's some kind of artifact (or artefact) making a line parallel to the
beam of light, divides the part inside the glass.
Changed the light falloff to 0.25 thinking it was radius=falloff causing it,
and adding 'parallel' to the light made no difference.
I didn't try every possibility but increasing media samples some and upping
the global photons media to 1000,10 sure didn't fix that. Removed the
fragmenting you had seen when I used higher numbers anyway (I was doing
small quick renders before).
Just thought I'd mention the strange line in the glass. Maybe it just needs
extreme tweaking on the numbers...?
Date: 28 May 2009 12:35:01
Message: <web.4a1ebcd284c0b6cf708085d0@news.povray.org>
Got a shot for us to see?
Maybe it's just a reflection of the beam in the glass?
Date: 28 May 2009 13:28:03
Message: <4a1ec9a3$1@news.povray.org>
"clipka" <nomail@nomail> wrote in message
news:web.4a1ebcd284c0b6cf708085d0@news.povray.org...
No reflection used. Posting a cropped image to p.b.i. subject light beam
artifact.
