POV-Ray : Newsgroups : povray.newusers : mirrored parametric object Server Time
2 May 2026 03:06:06 EDT (-0400)
  mirrored parametric object (Message 1 to 3 of 3)
Subject: mirrored parametric object
Date: 23 May 2009 05:05:01
Message: <web.4a17bb7c93b529b6821ef8770@news.povray.org>
I'm completely new to POVRAY, intention was to use it to quickly explore the
optical effects of a mirror defined using some equations. In the process of
setting things up, I find myself unable to obtain a correctly reflecting sphere
given as a parametric object. Staying close to published examples, I find that
this
camera { location <-1,3,-6> look_at <0,0,0> angle 35 }
light_source { <100,200,-200> color 1 }
// The floor
plane { <0,1,0>,-1 pigment { checker rgb <1,0,0>, rgb <1,1,0> } }
// A mirror sphere
sphere
{ <0,0,0>,1
  pigment { rgb <0,0,0> } // A perfect mirror with no color
  finish { reflection 1 } // It reflects all
renders a mirrored sphere with correct reflections of the checkerboard while
this
// The floor
// the sphere
parametric {
 function { sin(u)*cos(v) }
 function { sin(u)*sin(v) }
 function { cos(u) }
 <0,0>, <2*pi, pi>
 contained_by { sphere{0, 1.1} }
 accuracy 0.0001
 precompute 10 x,y,z
       rgb <0,0,0>
    finish {
      reflection 1
gives a sphere, but with incorrect reflections (only a few colored
points/stripes)...
Any hints much appreciated!
Thanks,
Sven
Subject: Re: mirrored parametric object
Date: 23 May 2009 14:40:00
Message: <web.4a1842ce27440a0befff66860@news.povray.org>
> points/stripes)...
Having just tested this with POV-Ray 3.6 (actually MegaPOV 1.2.1, but that
shouldn't change a thing here), I agree that this really looks bogus (well, the
comparison with a sphere shows that it definitely *is* bogus), and I'm quite
sure that this is a bug.
The good news is that POV-Ray 3.7.0.beta.32 does not seem to have it. With that
version, I found virtually no difference between the sphere and the parametric
(except for some slight jitter effects).
So you may want to try the current 3.7 beta for your experiments. POV-Ray 3.6,
at any rate, obviously isn't a reliable tool for your purposes.
Date: 24 May 2009 16:00:01
Message: <web.4a19a6f027440a0bf098e2190@news.povray.org>
> > points/stripes)...
Hi clipka,
thanks for your help, so at least this issue isn't due to some misunderstanding
on my side...
I tried building the 3.7 beta on my laptop (SuSE 10.3 64bit), but wasn't able to
out of the box (using Boost 1.37 + devel packages from the Packman repos, I get
some linking errors apparently connected to either Boost threads or
libpthread). Currently have no time to look into this in detail, so this'll
have to wait till I get around to trying it on my OpenSuse 11.1 workstation,
hopefully with better luck).
Again, thanks a lot for your help!
-Sven
