POV-Ray : Newsgroups : povray.newusers : Pov-Ray assumptions, and missing Utilities Server Time
2 May 2026 04:51:02 EDT (-0400)
  Pov-Ray assumptions, and missing Utilities (Message 1 to 7 of 7)
Subject: Pov-Ray assumptions, and missing Utilities
Date: 29 Apr 2009 06:35:00
Message: <web.49f82d1b7aff840a118f58ca0@news.povray.org>
Maybe I've jumped off the deep end in my using POV...
I'm trying to create some animations, depicting antenna radiation patterns.
Ideal spherical radiators were simple, and dipoles weren't to hard (torus).
Modifying the toroid with a cardioid was an exercise in isosurfaces. But my
problems started when I combined image_maps and animation!
I have a basic 640x480 black and white grid as the image. I want the "white" to
fade as the object expands, revealing a series of nested "wave fronts". Simple,
right? just change the transmit value for the "white" component of the image map
palette.
Which one?
I'm stuck with minimal resources here- the .gif was created using MS-Windows
Paint. Someone, somewhere, has assumed everyone has access to a basic Palette
Editor. I'm blessed if I can find one, however!
So- how do YOU manage .gif (and .png) palettes?
Subject: Re: Pov-Ray assumptions, and missing Utilities
Date: 29 Apr 2009 07:12:35
Message: <49f83623$1@news.povray.org>
> palette.
> Which one?
   If the image only has black and white, most likely black will be index 0
and white will be 1.
   I don't know what are your limitations, but if you can download and
install The Gimp, it has a palette editor.
Jaime
Date: 29 Apr 2009 13:26:32
Message: <49f88dc8$1@news.povray.org>
Jaime Vives Piqueres wrote:
>> Which one?
> 0 and white will be 1.
I was curious enough to try what "Paint" actually writes
when only painting some black on white on (xp sp2):
png:               0 /   1
bmp (monochrome):  0 /   1
bmp (256 colors):  0 / 255
gif:              40 / 255   (why not 42???)
Date: 29 Apr 2009 13:33:43
Message: <49f88f77$1@news.povray.org>
> png:               0 /   1
actually that's also 0 / 255, I just screwed up the
measurements by saving as monochrome bmp first ;) on the
other hand, the values for gif are independent of this.
Date: 29 Apr 2009 13:34:12
Message: <49f88f94$1@news.povray.org>
> I was curious enough to try what "Paint" actually writes when only
> png:               0 /   1
   That's why I assumed it: I always use png for indexed images.
   This sounds also logical...
   ..but that seems totally arbitrary!
Jaime
Date: 29 Apr 2009 14:21:12
Message: <49f89a98@news.povray.org>
actually, this is probably an artefact of the lzw compression,
which assigns its own bit patterns to input values. When modifying
the image and resaving it was suddenly 0 / 15. Better not rely on
GIF color indexes (although transparency probably works as GIF
supports it directly).
Date: 30 Apr 2009 12:11:17
Message: <49f9cda5$1@news.povray.org>
SA_Penguin nous illumina en ce 2009-04-29 06:34 -->
> palette.
> Which one?
If you are on windows, you can use IrfanView. Free, lightweight, effecient. One
of it's options allows you to edit a palette.
