POV-Ray : Newsgroups : povray.newusers : Generating cut-aways Server Time
13 Jul 2025 21:51:24 EDT (-0400)
  Generating cut-aways (Message 1 to 4 of 4)
Subject: Generating cut-aways
Date: 14 Feb 2009 07:55:05
Message: <web.4996becdd7a07582a386ad060@news.povray.org>
Hello,
I've researched this problem a bit. It doesn't look like povray can do things
the way I hoped it would.
Basically I want to generate a "cut away" of a complex assembly. I routinely use
povray as a modeling tool to render mechanical designs before I fabricate them.
As one might imagine generating a cut-away of the design is quite useful.
The logical choice here would be to use the "difference" command. The problem
is that although it is *claimed* that objects are assumed to be solid, in
reality it seems "difference" puts a *cap* on the (hollow) object its
differencing. Evidence of this can be seen when using the pigment "Clear" on
the object being differenced.
ie.,
difference
  cylinder
    <0.0, 0.0, 1.0>
    <0.0, 0.0,-1.0>
    1.0
    pigment{Yellow}
  box
    <0.0, 2.0, 2.0>
    <2.0,-2.0,-2.0>
    pigment{Clear}
()Produces a hollow cylinder cut in half.
The idea that after something is *subtracted* from another thing, leaves
something of itself behind in the result
(ie., 7-3 = 4 + (bits of "3" sprinkled on it) doesn't seem consistent with the
idea of a *difference* to me.
Anyway, the only answer I can see is to live with a *single* pigment bounding
the cutaway regions (unfortunate since I'd loose all the pigments of the various
sub-components) or meticulously cut away each sub-component separately to
produce a combined cut-away object with the pigments of the various
sub-components preserved.
Suggestions appreciated.
Thanks.
Robert W.
Subject: Re: Generating cut-aways
Date: 14 Feb 2009 08:30:01
Message: <4996c759$1@news.povray.org>
"rtwas" <nomail@nomail> wrote in message
news:web.4996becdd7a07582a386ad060@news.povray.org...
> Hello,
> things
> ... snip ...
> Thanks.
> Robert W.
The 'cutaway_textures' keyword can be added to the CSG object to tell
POV-Ray to use textures from the surfaces that have been cut into, rather
than from the object used to cut them.
Chris B.
Date: 14 Feb 2009 12:16:28
Message: <4996fc6c@news.povray.org>
  Or use cutaway_textures.
Date: 14 Feb 2009 13:59:14
Message: <49971482$1@news.povray.org>
rtwas nous illumina en ce 2009-02-14 07:54 -->
> Hello,
> ie.,
  difference
    cylinder
      <0.0, 0.0, 1.0>
      <0.0, 0.0,-1.0>
      1.0
      pigment{Yellow}
    box
      <0.0, 2.0, 2.0>
      <2.0,-2.0,-2.0>
      //pigment{Clear} remove this pigment
cutaway_textures // add this.
> Thanks.
> Robert W.
Any society that would give up a little liberty to gain a little security will
deserve neither and lose both.
Benjamin Franklin
