POV-Ray : Newsgroups : povray.newusers : User-defined vector functions Server Time
13 Jul 2025 21:23:19 EDT (-0400)
  User-defined vector functions (Message 1 to 10 of 18)
Subject: User-defined vector functions
Date: 5 Oct 2008 12:50:00
Message: <web.48e8ef33ae5e4190d8a103ef0@news.povray.org>
I used to think I knew more about POV-Ray than I apparently do.  Either that, or
this new project is introducing me to new corners of SDL and other interesting
things.
I find myself making sets of user-defined float functions because I can't figure
out how to make a user-defined vector function.  I end up with stuff like this:
#declare LocX = function(x) { x + 1 }
#declare LocY = function(y) { y * 2 }
#declare LocZ = function(z) { z / 3 }
I'd *much* rather have this:
#declare LocXYZ = function(x, y, z) { <x + 1, y * 2, z / 3> }
Any chance there's an easy way to do this?  Will I have to use a macro?
Subject: Re: User-defined vector functions
Date: 5 Oct 2008 13:20:47
Message: <48e8f76f$1@news.povray.org>
> things.
Judging from your previous posts, you seem to have some serious
misconceptions about the use(fulness) of functions. You may want to review
the documentation to learn more about macros.
	Thorsten
Date: 5 Oct 2008 14:28:22
Message: <48E90794.2050602@hotmail.com>
On 05-Oct-08 19:20, Thorsten Froehlich wrote:
>> Either that, or
>> interesting
>> things.
>> can't figure
>> like this:
> review the documentation to learn more about macros.
So your answers are: no and yes in that order? If so, why don't you just
tell him that and perhaps explain when to use and not to use macros and
functions? This is povray.newusers you know.
Anyway, there is apparently a feeling on what would be a logical
approach. There may be reasons why it is hard to implement now. Yet,
this kind of information is very important when designing POV4. If you
had though about it, you would have realized that povray.newusers is a
goldmine to find out how to change SDL4 to be more in line of what
'naive' people are expecting.
I know your style and I realise that you probably do not mean to sound
so arrogant and hostile. Newusers on the other hand may be scared away
from asking questions because of you. Even though most people here are
actually very friendly and helpful.
Date: 5 Oct 2008 16:49:50
Message: <48e9286e$1@news.povray.org>
Yes, but this topic is huge and well covered in the docs, so starting there
is a very good idea for any new user ;-)
	Thorsten
Date: 5 Oct 2008 17:30:34
Message: <1dcie4td34d95fg7nhr2oge4a46sn1iuld@4ax.com>
On Sun, 05 Oct 2008 22:49:54 +0200, Thorsten Froehlich <tho### [at] trfde> wrote:
Even if it is well covered in the docs a few hints and examples from someone who
knows how to do it is worth a lot. It is said that "a picture is worth a
thousand words". Or in this case an example is worth a thousand words ;)
I would if I could but I can't so I don't. :)
And RTFM is so bad mannered, especially in povray.newusers. The manual is
information dense and it can be difficult to find what you need or to know that
you have found it when you do.
Regards
Date: 5 Oct 2008 17:45:32
Message: <48E935CA.80902@hotmail.com>
>> and functions? This is povray.newusers you know.
> there is a very good idea for any new user ;-)
I know, but docs are only good if you know what to look for. For an
average person it may take weeks or months to get a feeling for what a
program does and what you may have to look for in the documentation.
Small example from p.o-t: somebody referred to the ??( and ??) as
alternatives for [ and ]. I tried to find that with google and failed. I
am guessing because of not indexing punctuation. You need to know that
these things are called trigraphs to find them. Second example: what
does p.o-t stands for? If you know it is obvious, otherwise you won't
find out until *someone* tells you. (newsgroup povray.off-topic is the
answer in case anyone still wonders ;) ).
I haven't looked into the docs for macros and functions recently (and if
I did I would not be able to judge anymore anyway), but if they behave
like ordinary docs, you can not read them unless you know what is in
there. Mathuin first posted in this group 3 days ago. In general people
wait for at least one or two weeks before posting, so I guess he*
discovered POV about 2-3 weeks ago. There will be a lot of trivial
things he does not know yet, like reading the examples in the source
directories and looking in p.t.s-f and p.t.t for inspiration. You can
blame him for not knowing these things, you can blame him for not even
trying, but that is simply not fair. Friendly point him in the right
direction and he'll study the docs before asking the next question and
he'll be back within two months with a stunning picture. Attack his lack
of knowledge and he won't come back ever again because he'll get the
impression that POV is too difficult for him. We don't want that, do we?
* or she
Date: 6 Oct 2008 21:55:01
Message: <web.48eac00c17cb998cd8a103ef0@news.povray.org>
>  Thorsten
This isn't quite as bad as telling someone use the dictionary to find the
correct spelling of a word, but it was close.  I did look at macros (my
original message pointed out that I thought they might be the right solution)
but I wasn't sure and that's why I asked here.  I had previously used macros as
a way to replace repetitive bits of code and functions as a way to perform
repetitive calculations as that's how I've used them in other languages.  After
tinkering with macros I was able to solve this particular problem and now I
realize that I can do a lot with macros that I can't do with functions.
I have another problem/annoyance/what-have-you but that deserves its own thread
if I can't find the answer in the newuser archives.
Date: 7 Oct 2008 01:55:00
Message: <web.48eaf96a17cb998c3639c5980@news.povray.org>
> things.
I tend to use functions only for pigments, isosurfaces, and the like.  If you
are using a vector function, then I presume you are describing a position/path,
color, etc.  Both splines and macros are better suited for this in my opinion,
splines if you have a series of points to pass through, macros if you have a
set function (or functions).
Remember that a function of three variables as you have listed will generate a
surface/solid, whereas it seems that you are looking for a single vector at a
given value for the independent variable t (or whatever you use).
-Reactor
Date: 7 Oct 2008 11:25:00
Message: <web.48eb7f1617cb998c81c811d20@news.povray.org>
> things.
A macro is best suited for this:
#macro LocXYZ (x0,y0,z0)
  #local x1=x0+1;
  #local y1=y0*2;
  #local z1=z0/3;
  <x1,y1,z1>
evaluate using:
#declare A=LocXYZ(1,2,3);
-tgq
Date: 8 Oct 2008 13:32:31
Message: <48eceeaf@news.povray.org>
My post was no RTFM. But I guess you just want to flame me, so by all means,
have your fun - assholes.
	Thorsten
