POV-Ray : Newsgroups : povray.newusers : Expected 'operator', ? found instead Server Time
13 Jul 2025 21:21:45 EDT (-0400)
  Expected 'operator', ? found instead (Message 1 to 5 of 5)
Subject: Expected 'operator', ? found instead
Date: 5 Oct 2008 03:10:01
Message: <web.48e867521f7a504fd8a103ef0@news.povray.org>
I'm trying to use the conditional expression in a function and get the following
error message:
Parse Error: Expected 'operator', ? found instead
Here's my function:
#local ScoreStone = function(x) { (x=1) ? white_stone : black_stone }
What am I doing wrong?  I thought ? was an operator -- that's what the docs say.
 It happens on Windows with both 3.7 beta 28 and 3.6 as well as on Unix with
3.6.  Thanks!
Subject: Re: Expected 'operator', ? found instead
Date: 5 Oct 2008 03:37:46
Message: <se+0giAG7G6IFwPV@econym.demon.co.uk>
>following
>error message:
>Here's my function:
>docs say.
>3.6.  Thanks!
The syntax inside functions is different from that of the main SDL. It
doesn't have "?" but it does have "select".
Mike Williams
Gentleman of Leisure
Date: 5 Oct 2008 04:40:00
Message: <web.48e87d0f38f591c7d8a103ef0@news.povray.org>
Mike Williams <nos### [at] econymdemoncouk> wrote:
\> The syntax inside functions is different from that of the main SDL. It
I ended up making a macro instead of a function.
'white_stone' is 'stone(1, 1, 1)' and 'black_stone' is 'stone(0, 0, 0)' so I
have this which works:
#macro ScoreStone(i)
stone(i ? 1 : 0, i ? 1 : 0, i ? 1 : 0)
#end // macro ScoreStone(i)
It's kinda ugly, but it definitely works.
Thank you for the pointer to select() -- I will use that in the future.
> Mike Williams
Date: 5 Oct 2008 06:40:00
Message: <web.48e8990438f591c7d8a103ef0@news.povray.org>
I have since changed this to:
stone(i, i, i)
as i is either 0 or 1.  Whee.  Thank you again. :-P :-)
> > Mike Williams
Date: 9 Oct 2008 13:10:56
Message: <48ee3b20@news.povray.org>
Mathuin nous illumina en ce 2008-10-05 06:37 -->
> stone(i, i, i)
>>> Mike Williams
Your final solution does have an advantage, beside simplicity: you are no longer
limited to only white or black, you can now have any shade of gray.
"The fact that windows is one of the most popular ways to operate a computer
means that evolution has made a general fuckup and our race is doomed."
            -- Anon.
