POV-Ray : Newsgroups : povray.newusers : Light without light source? Server Time
23 Jan 2025 04:28:50 EST (-0500)
  Light without light source? (Message 1 to 9 of 9)
Subject: Light without light source?
Date: 27 Jul 2008 18:20:01
Message: <web.488cf38ffb56fa1cbc347d080@news.povray.org>
First of all i'm a complete newbie, but i've searched a lot and didn't find
anything similar. (I'm using the windows version 3.6)
The problem i'm having is that whether i've defined a light source or not, any
plane and/or object is always illuminated. For example the following renders a
blue/red checkered plane thats a little dark, but illuminated all the way to
the horizon and a yellow sphere(also a little dark, but still illuminated):
  #include "stones.inc"
    location <0, 2, -3>
    look_at  <0, 1,  2>
  sphere {
    <0, 1, 2>, 2
      pigment { color Yellow }
    plane { <0, 1, 0>, -1
      checker color Red, color Blue
Now the "Messages" part of Pov-ray even states that no light sources were
in the scene, only 1 finite and 1 infinite object. So why isn't my rendering
completely black? There is no light source, so how can i possibly see
anything/how could it possibly render anything?
Thanks in advance,
Triple
Subject: Re: Light without light source?
Date: 27 Jul 2008 18:38:40
Message: <488cf8f0@news.povray.org>
it's the ambient light. Add
   #default {finish {ambient 0}}
at the beginning of your scene file.
However, this means all shadows cast will be pitch
black, so you need to use fill lights or radiosity
to avoid that.
Date: 28 Jul 2008 09:10:01
Message: <web.488dc4274e32c40ebc347d080@news.povray.org>
> to avoid that.
Thanx a lot. I was following the beginner tutorials for pov-ray and came to
this: http://www.povray.org/documentation/view/3.6.1/36/ when i realised that
my render did not match what was being discribed. There is no mention of the
ambient light that is on by default, yet it expected me to have no ambient
light, sharp shadows and an unlit plane when using a spotlight. Maybe someone
should report this to someone?(I don't know who to contact.)
Date: 1 Aug 2008 12:21:47
Message: <4893381b@news.povray.org>
The problem is that you're writing textures without finishes.  According
to Help, the default value for ambient is 0.1 (look under "finish").
Try using something like this:
sphere {
   <0, 1, 2>, 2
       color Yellow
     finish {
       ambient 0
plane {
   <0, 1, 0>, -1
       checker
     finish {
       ambient 0
You can, of course, make the ambient light go away by changing the
default texture.  You can also shut off ambient light in global_settings
(my personal preference, as I don't care for falling back on the default
texture).  This can be useful for doing quick preliminary renders of a
scene that's going to be using radiosity or complex lighting
arrangements (which slow things down):  use an ambient value in your
finishes somewhere in the neighborhood of 0.3, and then add
ambient_light 0 to global_settings when you're ready to do radiosity
renders.  The actual ambient value will then be 0 x 0.3 = 0.
Hope this helps.
--Sherry Shaw
#macro T(E,N)sphere{x,.4rotate z*E*60translate y*N pigment{wrinkles scale
.3}finish{ambient 1}}#end#local I=0;#while(I<5)T(I,1)T(1-I,-1)#local I=I+
1;#end camera{location-5*z}plane{z,37 pigment{granite color_map{[.7rgb 0]
[1rgb 1]}}finish{ambient 2}}//                                   TenMoons
Date: 1 Aug 2008 14:36:49
Message: <489357c1$1@news.povray.org>
Sherry Shaw nous illumina en ce 2008-08-01 12:21 -->
> Hope this helps.
> --Sherry Shaw
A bad solution, as it preclude the use of high ambient object to illuminate your
scene. ambient_lights is multiplied with the ambient component of your finishes.
Set it to zero, and no object can shed light whatever ambient value you set.
It's goal it to tint the ambient by using a non-white value.
I prefer to use this:
#declare Use_Rad = on;
#default{finish{#if(Use_Rad)diffuse 0.8 ambient 0#else diffuse 0.6 ambient 0.2#end}}
I also edit the various includes to remove some absurd and useless ambient values.
   A girl phoned me and said, "Come on over. There's nobody home." I Went over.
Nobody was home!
	Rodney Dangerfield
Date: 2 Aug 2008 14:49:44
Message: <4894ac48@news.povray.org>
> illuminate your scene.
In that case, set ambient_light to a tiny value, effectively killing the
ambient value in ordinary finishes, and set the ambient value of the
high-ambient object high enough to offset it.  (For example,
ambient_light 0.001 * ambient 10000 = 10)
--Sherry Shaw
Date: 2 Aug 2008 19:12:25
Message: <4894e9d9@news.povray.org>
  IMO a cleaner solution is to use #default { finish { ambient 0 } }
Date: 2 Aug 2008 21:50:00
Message: <web.48950ead4e32c40ec90c6aa70@news.povray.org>
What I prefer to do is have some variables at the top of my scene and reference
them throughout:
#declare use_radiosity = on; // off
#if( use_radiosity )
    #declare scene_diffuse = 0.95;
    #declare scene_ambient = 0.00;
#else
    #declare scene_diffuse = 0.85;
    #declare scene_ambient = 0.15;
then, inside of the finish block of a texture:
finish
    specular 0 roughness 1
    ambient scene_ambient
    diffuse scene_diffuse
Sometimes I'll add another variable for light intensity, too.
-Reactor
Date: 3 Aug 2008 06:32:28
Message: <4895893c@news.povray.org>
> them throughout:
> #else
> #end
> finish
  It's just easier and less trouble to use #default. That way you don't
have to add those 'ambient' and 'diffuse' lines to each single texture
you write. And it will work with pre-existing textures/objects as well
(assuming they don't explicitly define an ambient/diffuse).
