POV-Ray : Newsgroups : povray.newusers : Trace with pigments Server Time
2 May 2026 06:09:55 EDT (-0400)
  Trace with pigments (Message 1 to 10 of 12)
Subject: Trace with pigments
Date: 5 Jul 2008 03:45:00
Message: <web.486f25958f0468281ba56a630@news.povray.org>
Hello !
Is there a way to use the trace function (or another one) to get the color
vector, and even maybe the texture value of an object in one point, a bit like
the trace function works ?
Subject: Re: Trace with pigments
Date: 5 Jul 2008 04:10:37
Message: <486f2c7d$1@news.povray.org>
> like
There's eval_pigment in functions.inc, but there's no way to get
a final textured color except to render the scene.
Date: 5 Jul 2008 04:40:00
Message: <web.486f32aec03ce0661ba56a630@news.povray.org>
But how would I do if I don't know the pigment of the object ?
I only have an object "Obj", with a texture that I don't know...
Date: 5 Jul 2008 05:13:40
Message: <486f3b44$1@news.povray.org>
"Gyscos" <gys### [at] gmailcom> wrote in message
news:web.486f32aec03ce0661ba56a630@news.povray.org...
I can't think of anything that would give you that.
The 'trace' function can give you a point on a the surface of an object and,
as Tim mentioned, the 'eval_pigment' function can give you the pigment's
colour value at that point. However, as you pointed out, you need to be able
to pass it a copy of the pigment or a pigment identifier (in the same way
that you need to pass the 'trace' function a copy of the object or an object
identifier).
As POV-Ray files are generally human-readable, can't you find the object
definition and extract a copy of the pigment component of that object's
texture? This could of course be difficult with layered textures.
Otherwise, what are you ultimately trying to achieve? It may be that someone
can recommend a different approach that works around this particular
problem.
Chris B.
Date: 5 Jul 2008 06:25:00
Message: <web.486f4b04c03ce0661ba56a630@news.povray.org>
Well, i was trying to do a macro that puts spheres on the surface of an object,
with many trace. And I w as trying to give the spheres the color of the object
in this point... But if that's not possible, well, too bad :(
Date: 5 Jul 2008 10:28:27
Message: <486f850b@news.povray.org>
news:web.486f4b04c03ce0661ba56a630@news.povray.org...
> object,
> object
Well here's my bestest smartass hack of the day:
If you use the inverse of the object and difference the spheres from it you
can use the 'cutaway_textures' keyword to give the spheres the same pigment,
normal and finish as the object (even if you don't know what they are). The
downside to this hack is that your camera ends up technically 'inside' the
object which will mess up interior features like media if you want to use
them in the same scene. The upside is that it should do what you asked.
The following example illustrates the technique using a simple CSG object,
but I think it should work with more complex objects.
Chris B.
camera {location <0,0,-4> look_at 0 }
light_source {<-1,0 ,-4>, rgb 3}
#declare MyObject = intersection {
  box {-1,1 pigment {agate scale 2} }
  sphere {0,1.25 pigment {agate scale 2}}
#declare MyObjectWithSpheres = difference {
  object {MyObject inverse}
  sphere {<0,-0.3,-1.04>,0.04}
  sphere {<0.5,0.5,-1.04>,0.04}
  cutaway_textures
object {MyObjectWithSpheres}
Date: 5 Jul 2008 10:35:04
Message: <486f8698$1@news.povray.org>
"Chris B" <nom### [at] nomailcom> wrote in message
news:486f850b@news.povray.org...
> The downside to this hack is that your camera ends up technically 'inside'
> the object which will mess up interior features like media if you want to
> use them in the same scene.
Actually I just realised that the following small change should remove or
minimalise the impact of that downside:
Chris B.
  cutaway_textures
intersection {
  sphere {0,1.33 pigment {rgbt 1}}
Date: 5 Jul 2008 11:05:04
Message: <web.486f8d6ec03ce0661ba56a630@news.povray.org>
Humm, on my PC it doens't work, the spheres are black (I use POV-ray v3.7 b27 so
maybe it doesn't support cutaway_textures...)
Are you sure the box stores the texture of every point of the space, not only on
its surface ?...
What I first wanted to do was to put spheres on the object without the object
itself (like a wireview with spheres instead of wires).
Would something like :
object {
  difference {
    union {
      object { MyObject }
      object { MyObject invert }
    sphere { TheSpheresToPut }
    cutaway_texture
invert
work ?
Date: 5 Jul 2008 11:41:55
Message: <486f9643@news.povray.org>
news:web.486f8d6ec03ce0661ba56a630@news.povray.org...
> b27 so
Oh that's a pity. I'm on 3.6 on Windows and it works for me. I found that
the spheres are black if they end up on the outside of the object, rather
than inside it, hence having to use the inverse of the object. Do you get an
error in the message stream saying that an there's a missing pigment?
> only on
> its surface ?...
When a ray hits a surface it evaluates the texture to find the appropriate
value for that point in 3D space using the texture that applies to that part
of the object. It shouldn't really care where that surface is on the object.
> object
That would be easy if you could isolate the texture used for the object.
Would that really be too difficult to do?
> object {
>  difference {
>    union {
>      object { MyObject }
>    cutaway_texture
> invert
> work ?
No. I think you'd end up with a degenerate object.
Chris B.
Date: 6 Jul 2008 12:00:33
Message: <4870ec21$1@news.povray.org>
Gyscos nous illumina en ce 2008-07-05 11:04 -->
> its surface ?...
The textures are defined in space. You can think of the objects as been carved
out of the texture.
If the object you defined and traced toward is not placed in the scene, it will
never show.
> object {
>   difference {
>     union {
>       object { MyObject }
>     cutaway_texture
> invert
> work ?
The difference of any object with it's inverse is empty.
The union of any object with it's inverse is the whole space.
In your example, the union is useless and the whole thing is the same as:
sphere { TheSpheresToPut hollow}
but more complicated, and slower as you get an unbound object.
If you want to get rid of the warning about the camera been inside an object
and/or use some media, just add the "hollow" keyword to your object.
A thing that you can do, is to define your object larger by the radius of your
spheres and allpy the pigment. As you trace, you use eval_pigment at the points
returned by the trace. This will return the pigment at the traced location.
Place your sphere there and apply the returned pigment to that sphere, repeat
for each sphere. This will give you spheres that are a solid colour. You need
all your spheres to have the same radius. It will require more memory as each
sphere will have it's own texture block. It will be fast as the bounding will be
effecient, one tight and distinct bounding box for each sphere.
Another way is to define a box that is the dimention of the bounding box of your
object plus the diameter of the largest sphere. Use an intersection of that box
and all your spheres. Apply your texture to the whole intersection. It will use
less memory, and the spheres will show some gradient. The rendering will be
slower as you will have many overlaping bounding boxes, each bounding box will
cover the whole thing and overlap every other.
Methodist: It's not so bad if shit happens, as long as you serve grape juice
with it.
