POV-Ray : Newsgroups : povray.newusers : Newbie gets lots of black pixels on nested spheres Server Time
2 May 2026 06:09:02 EDT (-0400)
  Newbie gets lots of black pixels on nested spheres (Message 1 to 7 of 7)
Subject: Newbie gets lots of black pixels on nested spheres
Date: 1 Jul 2008 17:05:01
Message: <web.486a9b1613f6a9318a187d850@news.povray.org>
As the Subject says, I'm very new at this, and not sure what I'm doing wrong.
The image I am trying to render is one of a sphere of nested multi colored
spheres with a wedge removed to reveal the inner layers. I get what I think I'm
suppose to get, except the inner spheres are speckled with lots of black pixels.
I read the piece about coincident surfaces causing this effect, but if that is
what the problem is, I don't know what surface needs moving.
Can anyone tell me what I've done wrong?
Jonathan
Here's my .pov file contents:
  camera
    location <0, 10, -20>
    look_at 0
  light_source
    <30, 20, -30>
    color White
    spotlight
    radius 15
    falloff 20
    tightness 10
    point_at <0, 0, 0>
  #declare Crust = difference
    sphere
      <0, 0, 0>, 10
      pigment {Blue}
    box
      <0, 0, 0>, <10, 10, -10>
      pigment {Blue}
  #declare Mantle = difference
    sphere
      <0, 0, 0>, 9.5
      pigment {Brown}
    box
      <0, 0, 0>, <9.5, 9.5, -9.5>
      pigment {Brown}
  #declare OuterCore = difference
    sphere
      <0, 0, 0>, 6
      pigment {Yellow}
    box
      <0, 0, 0>, <6, 6, -6>
      pigment {Yellow}
  #declare InnerCore = difference
    sphere
      <0, 0, 0>, 3
      pigment {Red}
    box
      <0, 0, 0>, <3, 3, -3>
      pigment {Red }
  #declare NestedSpheres  = merge
    object {InnerCore}
    object {OuterCore}
    object {Mantle}
    object {Crust}
  object
    NestedSpheres
    rotate y*30
    rotate x*-10
Subject: Re: Newbie gets lots of black pixels on nested spheres
Date: 1 Jul 2008 17:34:08
Message: <486aa2d0$1@news.povray.org>
"JEofVA" <jce### [at] attglobalnet> wrote in message
news:web.486a9b1613f6a9318a187d850@news.povray.org...
> wrong.
Welcome to the newsgroup.
> think I'm
> pixels.
This sounds like a very similar problem to the one discussed a couple of
weeks ago in the thread
http://news.povray.org/povray.newusers/thread/%3Cweb.48513efe78241c82b979a58c0%40news.povray.org%3E/
> that is
I think it is indeed coincident surfaces. The cut surfaces of your Crust,
Mantle, OuterCore and InnerCore all align exactly.
Two alternative solutions are mentioned in the thread above. One is to
'difference' the next smaller sphere from each larger sphere (Subtract the
Mantle sphere from the Crust, the OuterCore sphere from the Mantle and the
InnerCore sphere from the OuterCore). The second is to just have one sphere
and use a color_map to give the shells different colours.
In this case there is also a simple third option and that is to move the
corner of the box that you are using to slice out the segments. If the Crust
box starts at <0,0,0> you can use 0.00001*<1,1,-1> for the Mantle box,
0.00002*<1,1,-1> for the OuterCore box and 0.00003*<1,1,-1> for the
InnerCore box. This tiny difference is enough to make sure that the cut
surfaces are no longer coincident.
Chris B.
Date: 1 Jul 2008 17:40:31
Message: <4r8l64l98b3ku8p7m3hraho2rq982u26hh@4ax.com>
On Tue,  1 Jul 2008 17:01:10 EDT, "JEofVA" <jce### [at] attglobalnet>
Increase the max_trace_level in global settings
 global_settings { max_trace_level NN}
Read 3.3.3.7  Max_Trace_Level in the help
Regards
Date: 1 Jul 2008 18:03:01
Message: <486aa995$1@news.povray.org>
"Stephen" <mcavoysAT@aolDOTcom> wrote in message
news:4r8l64l98b3ku8p7m3hraho2rq982u26hh@4ax.com...
I don't think it's that because there are no reflective or transparent
surfaces in the SDL that Jonathan listed.
Jonathan, for future reference, if you add anything important below your
signature it's a good idea to refer to it above your signature, otherwise
people are likely to stop reading once they hit your signature.
Chris B.
See! There's nothing down here worth reading :-)
Date: 1 Jul 2008 18:23:24
Message: <7hbl64pp9bstji9ttlegs18j0pj594l9sa@4ax.com>
On Tue, 1 Jul 2008 23:03:00 +0100, "Chris B" <nom### [at] nomailcom>
Well this one did :)
>Regards,
>Chris B.
I don't know about that ;)
Regards
Date: 1 Jul 2008 21:35:00
Message: <web.486ada99de595f198a187d850@news.povray.org>
> > wrong.
> > think I'm
> > pixels.
> > that is
> Regards,
> Chris B.
Chris,
I tried your "simple third option" and it worked.  I'm still not precisely sure
why it worked, but I will mull it over until I get it.  I understand what you
did, just not how it made a difference.  I guess I'm not fully understanding
this coincident surface thing.
But, thank for the help... oh, and I'll try to remember not to write below my
signature from now on.
Jonathan
Date: 2 Jul 2008 03:07:59
Message: <486b294f$1@news.povray.org>
news:web.486ada99de595f198a187d850@news.povray.org...
Yes. It's one of those things where, if you read enough different
explanations it can suddenly all make sense.
If you have two objects (or in this case two components of the
'NestedSpheres' object) where some of the overlapping surfaces align
perfectly, then, when a ray that POV-Ray traces out from the camera hits
this overlapping surface it sometimes hits one of them first and sometimes
the other, giving an unpredictable mixture of their colours. In this
instance the box shaped cutout caused the exposed internal surfaces of your
spheres to align perfectly. Indeed the entire cutout surface of the
innermost sphere aligned with the cut surfaces of all of the other 3
spheres.
In real life this wouldn't happen because you'd have to carve a hollow out
from inside the first sphere to be able to get the second one in, so by the
time you sliced a corner out you'd only be cutting down through one of the
two spheres at a time. Otherwise it's as if the crust could continue all the
way to the centre of the earth with the inner layers also occupying the same
3D space which would be impossible.
By moving the corner of the box that's doing the cutting slightly when
cutting away the different spheres, you avoid the coincident surfaces. In
this instance you need to move it away from the origin towards the opposite
corner of the box as you cut into the progressively smaller spheres so that
the cut surfaces of the smaller spheres stand proud of the cut surfaces of
all larger spheres. If you expand the corner in the opposite direction you'd
also avoid coincident surfaces, but the cut surfaces of the smaller spheres
would be burried inside the larger one so you'd only see the crust.
I hope that helps, otherwise a google on "povray coincident surfaces":
http://www.google.com/search?q=povray+coincident+surfaces gives links to
various slightly different explanations and discussions that may help.
Chris B.
