POV-Ray : Newsgroups : povray.newusers : Starfield appears random? Server Time
23 Jan 2025 04:50:41 EST (-0500)
  Starfield appears random? (Message 1 to 3 of 3)
Subject: Starfield appears random?
Date: 17 Jun 2008 23:35:00
Message: <web.4858813814a93abfd4dec990@news.povray.org>
Hello:
I am using the jslstarfield (below) to generate a space scene background.  The
problem is that whenever I move the camera, or the starfield itself, the
resulting starfield background appears to randomly re-generate with each frame.
 This gives the animation a bizarre appearance (even when I move the camera a
very small distance, say 0.00001*clock).
What can I do to fix this?
#declare jslStarfield =
    granite
    color_map {
      [0.00 0.76 color Black  color Black]
      [0.80 0.82 color Gray20 color Gray40]
      [0.82 0.84 color Gray40 color Gray60]
      [0.84 0.86 color Gray60 color Gray80]
      [0.86 0.88 color Gray80 color Gray95]
      [0.88 0.91 color Gray95 color White]
      [0.91 1.00 color Black  color Black]
    scale .015
  finish { ambient 1 diffuse 0 }
#declare StarSphere = sphere { <0,0,0>, 100000
  inverse
  texture { jslStarfield scale 1  }
Subject: Re: Starfield appears random?
Date: 18 Jun 2008 11:46:07
Message: <48592dbf$1@news.povray.org>
james lake nous illumina en ce 2008-06-17 23:30 -->
> Hello:
> texture {
>   pigment {
>     granite
>     color_map {
>     scale .015
>   inverse
The pigment used relies on sub-pixel details to simulate the apearance of a star
field. An extremely small movement will cause a ray that hit a bright spot to
completely miss it after the move.
The solution would be to keep the camera stationary and move the rest the scene.
You can do this by binding the whole scene, exept the camera and the world
sphere, in an union and apply the translation to the union.
While that will work for translations, it will not for rotations where the
visible part of the star field change.
EVERYTHING HAS A GENDER
You may not know this but many nonliving things have a gender...
A Hot Air Balloon is Male, because, to get it to go anywhere, you have to light
a fire under it, and of course, there's the hot air part.
Date: 18 Jun 2008 15:15:00
Message: <web.48595d15ee34b043265dec890@news.povray.org>
Or: Render the background with a spherical camera and use the rendered image as
a background (with sky_sphere) for the actual animation.
Depending on the resolution of your final animation and the camera angle you're
using the background image should be rendered with a width of approx
2*final_image_width*360/horizontal_viewing_angle in order to prevent both
blurry appearance (resolution too low) and flickering (resolution to high).
Hope that helps!
Regards Roman
> > Hello:
> > texture {
> >   pigment {
> >     granite
> >     color_map {
> >     scale .015
> >   inverse
> Alain
