POV-Ray : Newsgroups : povray.newusers : Tilt/Shift lens Server Time
14 Jul 2025 05:19:40 EDT (-0400)
  Tilt/Shift lens (Message 1 to 7 of 7)
Subject: Tilt/Shift lens
Date: 27 May 2008 06:20:00
Message: <web.483be008996acb542d5f88720@news.povray.org>
Hi all,
is it possible to simulate a tilt/shift lens in POV-Ray?
I'm after the non-parallel plane-of-focus effect.
I browsed around in the docs, but I couldn't find anything related to.
Subject: Re: Tilt/Shift lens
Date: 27 May 2008 09:56:21
Message: <483c1305$1@news.povray.org>
alex nous illumina en ce 2008-05-27 06:18 -->
> Hi all,
You can use non-perpendicular direction, right and sky vectors.
You know you've been raytracing too long when you're starting to find these
quotes more unsettling than funny.
     -- Alex McLeod a.k.a. Giant Robot Messiah
Date: 27 May 2008 11:05:03
Message: <web.483c22faa19f761b2d5f88720@news.povray.org>
> > Hi all,
> Alain
I don't think so...
I tried to modify focalblur.pov from the examples:
I removed the angle keyword and I added a direction vector, but whatever the
direction vector is, the rendering is the same as if the direction vector is
not specified (as long as the vector is normalized).
Could it be that the focal blur ignores the director vector's direction?
Date: 28 May 2008 02:57:08
Message: <483d0244$1@news.povray.org>
That is how it is documented ;-)
http://www.povray.org/documentation/view/3.6.1/248/
	Thorsten
Date: 28 May 2008 12:25:00
Message: <web.483d8702a19f761b2d5f88720@news.povray.org>
>  Thorsten
I think that you cannot specify a non-perpendicular direction vector using
look_at *and* direction (I don't have sources handy to check that), but using
transform you do and that's why I didn't get different result varying the
direction vector.
The camera specification I was using was:
        perspective //keyword is facultative in this case
        location <50,10,30>
        direction vnormalize(Direction)
        look_at <0,10,0>
        blur_samples 120 //add samples if you got a fast computer
        aperture 10
        focal_point <5,10,5>
(from focalblur.pov)
whatever Direction is, the plane of focus does not change.
But if I use this specification:
#declare S_angle=(CamLook.y-CamLoc.y)/CamLoc.z;
#declare Shear= transform {
   matrix <  1,  0,  0,
             0,  1,  -S_angle,
             0,  0,  1,
             0,  0,  0 >
        location CamLoc
        angle 90
        transform Shear // comment out to see 'falling buildings'
        rotate <0,45,0>
        look_at CamLook
        aperture 10
        focal_point CamLook
(from shear.pov)
the focal plane is *not* parallel to the image plane.
Just add focal blur to the shear.pov example scene and see for yourself.
I think that the focal plane is (correctly) parallel to the image plane only
when the camera vectors are perpendicular.
Exactly what I was looking for. :)
Now, all I need is a ton of help in working out the transormations needed to
emulate a tilt/shift lens....any volunteers?
--alex
Date: 28 May 2008 14:51:14
Message: <483da9a2$1@news.povray.org>
alex nous illumina en ce 2008-05-27 11:04 -->
>>> Hi all,
>> Alain
> I don't think so...
Try this camera:
camera{location 0 direction<0.2,0,1> sky<0.1,1,0.1> right<1.5,0,0.01>}
Date: 30 May 2008 09:34:15
Message: <48400257$1@news.povray.org>
> direction vector.
> camera {
>         location <50,10,30>
>         look_at <0,10,0>
>         aperture 10
>    matrix <  1,  0,  0,
>              0,  1,  -S_angle,
>              0,  0,  1,
>              0,  0,  0 >
> camera {
>         location CamLoc
>         angle 90
>         rotate <0,45,0>
>         look_at CamLook
>         aperture 10
>         focal_point CamLook
> (from shear.pov)
> --alex
Greetings, all. I have a macro that simulates a shifted lens which may
help you. I will repost it in p.b.s-f. as FieldCam.zip. In the zip are
three folders; one for Mac users, one for Unix users and one for M$
users. Hope it helps
John
I will be brief but not nearly so brief as Salvador Dali, who gave the
world's shortest speech. He said, "I will be so brief I am already
finished," then he sat down.
