POV-Ray : Newsgroups : povray.newusers : rotate object around its center Server Time
14 Jul 2025 04:59:21 EDT (-0400)
  rotate object around its center (Message 1 to 3 of 3)
Subject: rotate object around its center
Date: 19 May 2008 12:55:00
Message: <web.4831b0126dd87b108d9dd5710@news.povray.org>
Hello!
How can I rotate an object around its center?
I currently use
Rotate_Around_Trans( < 0, 90 , 0 >, < x1, 0.4, y1 > )
with
#include "transforms.inc"
but I don't think it's working.
Does the expression
< 0, 90 , 0 >
mean rotate around y for 90 degrees (and leave x and z as is)?
Because that's what I want to do.
Please tell me whete my current code is wrong or
how to do it.
Thanks!
Greetings,
Chris
Subject: Re: rotate object around its center
Date: 19 May 2008 13:10:51
Message: <4831b49b@news.povray.org>
"Chrisir" <nomail@nomail> wrote in message
news:web.4831b0126dd87b108d9dd5710@news.povray.org...
i think it's fairly common practice to build an object centered at <0,0,0>
from the camera's point of view you'd prefer a view of let's say the
opposite side of the object without moving the camera. i'd first rotate the
object using rotate y*180 then translate to the position in the scene ....
does that answer your question?
Jim
Date: 19 May 2008 15:13:40
Message: <4831d164$1@news.povray.org>
Chrisir nous illumina en ce 2008-05-19 12:51 -->
> Hello!
> I currently use
> with
> Does the expression
> < 0, 90 , 0 >
> how to do it.
> Thanks!
> Greetings,
> Chris
Acording to the documentation, you are correct.
That macro operate by translating the object by -1*< x1, 0.4, y1 >, rotate it by
the amount wanted, then translate it back to it's original location.
If the point provided is outside the object, then the object will orbit that point.
As Jim mentioned, it's usualy way easier to create all your objects around the
origin, apply any desired scaling and rotation, then to translate them to the
desired location.
Depending on the orientation of the camera and the location of your object(s),
it's possible that the applied rotation don't look like what you expect, even if
it did exactly what it should.
I hope our wisdom will grow with our power, and teach us, that the less we
use our power the greater it will be.
Thomas Jefferson
