POV-Ray : Newsgroups : povray.newusers : halo command error Server Time
2 May 2026 07:36:12 EDT (-0400)
  halo command error (Message 1 to 10 of 14)
Subject: halo command error
Date: 11 May 2008 16:05:00
Message: <web.482750f51d068561d4dec990@news.povray.org>
Hello:
I'm a new user and am trying to model the Earth with an atmosphere using a
downloaded file, but when I run the file this part:
// A thin blue halo, becoming lighter as it approaches the planet's
// surface.
#declare PlanetAtmosphere = sphere { <0,0,0>, 1
  pigment { colour rgbt <1,1,1,1> }
  halo {
    glowing
    spherical_mapping
    linear
    colour_map {
      [0.00 colour rgbt <0,0,2,1>]
      [0.05 colour rgbt <2,2,2,0>]
      [1.00 colour rgbt <2,2,2,0>]
    samples 10
  hollow
  scale 1.05
Gives me this error:
Parse Error: No matching } in 'sphere', undeclared identifier 'halo' found
instead
I know the halo command has been replaced, but I don't know how to fix this.
HELP!
James
Subject: Re: halo command error
Date: 11 May 2008 19:55:01
Message: <web.48278627fa7c99c2bd1b3ad10@news.povray.org>
You'll need to replace the halo with media, you can read about it in the docs
at:
http://www.povray.org/documentation/view/3.6.1/419/
Also, there are some examples at:
http://www.povray.org/documentation/view/3.6.1/97/
-Rob
"There is no spoon."
Date: 12 May 2008 20:58:55
Message: <4828e7cf@news.povray.org>
// A thin blue media, becoming lighter as it approaches
// the planet's surface.
   hollow
   material {
         pigment { rgbt <1,1,1,1> }
      interior {
         media {
            emission <0,0,2>
            density {
               spherical
               color_map {
                  [0 rgb 0]
                  [0.05 rgb 1]
                  [1 rgb 1]
         media {
            emission <2,2,0>
            density {
               spherical
               color_map {
                  [0 rgb 0]
                  [0.05 rgb 0.25]
                  [1 rgb 1]
   scale 1.05
Date: 14 May 2008 19:45:00
Message: <web.482b78a7fa7c99c2d4dec990@news.povray.org>
>    hollow
>    material {
>       texture {
>       interior {
>          media {
>             emission <0,0,2>
>             density {
>                spherical
>                color_map {
>                   [0 rgb 0]
>                   [0.05 rgb 1]
>                   [1 rgb 1]
>          media {
>             emission <2,2,0>
>             density {
>                spherical
>                color_map {
>                   [0 rgb 0]
>                   [0.05 rgb 0.25]
>                   [1 rgb 1]
>    scale 1.05
I tried this and it works, but now the Earth is a solid white sphere.  Is there
another command that must accompany these?  Or should I change the settings?
Thanks for the help!
James Lake
Date: 15 May 2008 12:56:31
Message: <482c6b3f$1@news.povray.org>
james lake nous illumina en ce 2008-05-14 19:41 -->
>>    hollow
>>    material {
>>       texture {
>>       interior {
>>          media {
>>             emission <0,0,2>
>>             density {
>>                spherical
>>                color_map {
>>                   [0 rgb 0]
>>                   [0.05 rgb 1]
>>                   [1 rgb 1]
>>          media {
>>             emission <2,2,0>
>>             density {
>>                spherical
>>                color_map {
>>                   [0 rgb 0]
>>                   [0.05 rgb 0.25]
>>                   [1 rgb 1]
>>    scale 1.05
> James Lake
You put that object around your earth, scaled 5% larger than the size of the
earth sphere.
You know you've been raytracing too long when you've ever "lost" a Julia fractal
because you're not quite sure how to align things in four dimensions.
Dylan Beattie
Date: 15 May 2008 22:25:00
Message: <web.482cef5ffa7c99c2d4dec990@news.povray.org>
> >>    hollow
> >>    material {
> >>       texture {
> >>       interior {
> >>          media {
> >>             emission <0,0,2>
> >>             density {
> >>                spherical
> >>                color_map {
> >>                   [0 rgb 0]
> >>                   [0.05 rgb 1]
> >>                   [1 rgb 1]
> >>          media {
> >>             emission <2,2,0>
> >>             density {
> >>                spherical
> >>                color_map {
> >>                   [0 rgb 0]
> >>                   [0.05 rgb 0.25]
> >>                   [1 rgb 1]
> >>    scale 1.05
> > James Lake
> earth sphere.
> Alain
> Dylan Beattie
I did that but it still generates a solid white sphere.  It is not transparent,
and does not fade at the edges.  There must be another setting or command that
has to change.  The planet and the atmosphere get put together with this:
#declare Planet = union {
  object { PlanetSphere }
  #ifndef (Quick)
    object { PlanetCloudSphere0 }
    object { PlanetAtmosphere }
Is this a good way to do it?
Thanks,
James
Date: 15 May 2008 23:41:45
Message: <482d0279$1@news.povray.org>
james lake napsal(a):
>>>>    hollow
>>>>    material {
>>>>       texture {
>>>>       interior {
>>>>          media {
>>>>             emission <0,0,2>
>>>>             density {
>>>>                spherical
>>>>                color_map {
>>>>                   [0 rgb 0]
>>>>                   [0.05 rgb 1]
>>>>                   [1 rgb 1]
>>>>          media {
>>>>             emission <2,2,0>
>>>>             density {
>>>>                spherical
>>>>                color_map {
>>>>                   [0 rgb 0]
>>>>                   [0.05 rgb 0.25]
>>>>                   [1 rgb 1]
>>>>    scale 1.05
>>> James Lake
>> earth sphere.
>> Alain
>> Dylan Beattie
>   #ifndef (Quick)
>   #end
> Thanks,
> James
Try greatly reducing the media density. The density required is very
dependent on your earth size.
Simply add another density block inside the media, like:
density{
density{
  rgb 1e-5
You know you've been raytracing too long when...
you ever saw a beautiful scenery and regretted not to take your 6"
reflective ball and a digital camera, thinking "this would have been a
perfect light probe"
		-Johnny D
Johnny D
Date: 16 May 2008 13:15:32
Message: <482dc134@news.povray.org>
james lake nous illumina en ce 2008-05-15 22:20 -->
>>>>    hollow
>>>>    material {
>>>>       texture {
>>>>       interior {
>>>>          media {
>>>>             emission <0,0,2>
>>>>             density {
>>>>                spherical
>>>>                color_map {
>>>>                   [0 rgb 0]
>>>>                   [0.05 rgb 1]
>>>>                   [1 rgb 1]
>>>>          media {
>>>>             emission <2,2,0>
>>>>             density {
>>>>                spherical
>>>>                color_map {
>>>>                   [0 rgb 0]
>>>>                   [0.05 rgb 0.25]
>>>>                   [1 rgb 1]
>>>>    scale 1.05
>>> James Lake
>> earth sphere.
>> Alain
>> Dylan Beattie
>   #ifndef (Quick)
>   #end
> Thanks,
> James
The sample use a 1 unit radius "planet", and it's density is set acordingly.
What is the dimention of your planet? If it's 100 units radius, you need to
reduce the media's density by 100, it the radius is 1000, reduce the density by
1000.
What is the quality setting? If set to low, it ignore the transparency and the
rgbt 1 (totaly transparent) becomes rgb 1 (white).
Any society that would give up a little liberty to gain a little security will
deserve neither and lose both.
Benjamin Franklin
Date: 16 May 2008 20:34:50
Message: <482e282a@news.povray.org>
> transparent,
> that
>  #ifndef (Quick)
>  #end
This media is intended to be around a unit sphere.
If you wish to use a different size, scale it after union...
#declare PlanetSurface = sphere { <0,0,0>, 1
      image_map {
         jpeg "earth02.jpg"
         map_type 1
      rotate <0,-150,0>
   object {PlanetAtmosphere}
   object {PlanetSurface}
object {
   Planet
   scale 2
   translate <-1.5,-0.5,0>
Date: 17 May 2008 01:14:48
Message: <482e69c8$1@news.povray.org>
Tim Attwood napsal(a):
>> transparent,
>> that
>>  #ifndef (Quick)
>>  #end
scaling an object doesn't reduce its density. Eight thousand times a
piece of steel is a piece of steel, not a piece of super-sparse steel.
you start thinking up your own "You know you've been raytracing too long
when..." sigs (I did).
		-Johnny D
Johnny D
