POV-Ray : Newsgroups : povray.newusers : threshold df3 media Server Time
2 May 2026 07:35:48 EDT (-0400)
  threshold df3 media (Message 1 to 5 of 5)
Subject: threshold df3 media
Date: 26 Feb 2008 08:25:01
Message: <web.47c412976ea871fc7597f0180@news.povray.org>
I have a large .df3 file I visualize by using it as a media density. I want to
postprocess that density after loading it into povray. For example, set
everything in the density that is smaller (or larger) than a threshold to zero
and rescale the rest.
Effectively, I want to visualize only density values in the interval from
[0.2,0.3], say. Of course, I could do this outside and save a scaled .df3 right
away, but since this is part of a movie and the interval changes (it is used as
a lens to let you go through the materials in the volume), it would mean a lot
of wasted diskspace - the .df3 is really big.
Ideally, I would like to specify a transfer function that maps a density value
in a voxel to an emission value in that voxel. Any ideas how I can do this in
povray? I'm using the latest beta.
Frank
Subject: Re: threshold df3 media
Date: 26 Feb 2008 09:34:53
Message: <NBjIykCNHCxHFwus@econym.demon.co.uk>
Wasn't it Frank who wrote:
>Hi,
That should all work.
The clue is that anything that can be used as a density pattern for
media can also be used as a function; and any function cam be used as a
media density pattern.
So create a function from your density file
#declare F=function{ pattern{
     density_file df3 "foo.df3"
     interpolate 1 }
Then consider a transfer function of that pattern function
  select( abs(F(x,y,z)-0.25)-0.05, 1, 0)
That transfer function returns 1 if F(x,y,z) is between 0.2 and 0.3, and
0 otherwise.
Then use that transfer function to control your media
media {
  scattering {1, 0.7}
  density {
    function {
You can add select clauses together.
    + select( abs(F(x,y,z)-0.35)-0.05, 0.5, 0)
    + select( abs(F(x,y,z)-0.45)-0.05, 0.2, 0)
Or you can use any mathematical operators that are allowed for pattern
expressions to write a transfer function.
Hints: Pattern values outside the range 0.0 to 1.0 behave like mod(p,1)
Patterns derived from df3 files behave as if centred around <.5,.5,.5>
Mike Williams
Gentleman of Leisure
Date: 26 Feb 2008 10:15:00
Message: <web.47c42bb62190f9b2863570b30@news.povray.org>
YES! It does!
Thank you very much, worked out of the box, and makes everything much easier.
Since I don't want to keep asking: Is there a book you can recommend that
describes techniques like this for volume rendering with PovRay?
Thanks again,
Frank
Date: 26 Feb 2008 10:16:57
Message: <47c42d69$1@news.povray.org>
Frank napsal(a):
> Hi,
> Frank
use a waveform for the density
You know you've been raytracing too long when...
you start thinking up your own "You know you've been raytracing too long
when..." sigs (I did).
-Johnny D
Date: 26 Feb 2008 13:03:08
Message: <47c4545c@news.povray.org>
Frank nous apporta ses lumieres en ce 2008/02/26 08:23:
> Hi,
> Frank
Very simple, and without ever altering your data.
Just add a color_map like:
color_map{[clock rgb 0][clock rgb 1][clock+0.1 rgb 1][clock+0.1 rgb 0]}
The media is now only visible in the range of clock to clock + 0.1. Everywhere
else, it's density will be zero, whitch is equivalent to no media.
I used "clock" as you mentioned an animation, but you can use any variable you want.
You can use another variable to set the width of the visible part. You can also
use a colour of your choice instead of white as in my example.
The tree of liberty must be refreshed from time to time with the blood of
patriots and tyrants.
Thomas Jefferson
