POV-Ray : Newsgroups : povray.newusers : Problem with #switch Server Time
14 Jul 2025 07:37:47 EDT (-0400)
  Problem with #switch (Message 1 to 7 of 7)
Subject: Problem with #switch
Date: 11 Feb 2008 18:50:01
Message: <web.47b0ded4bd25e05c9c37dbc40@news.povray.org>
When I try to compile the following code, it says there should be a ) after X+1.
Am I doing this right? It's supposed to return X+1 if Dir = 0 or 1, X if it's 2
or 5, and X-1 if it's 3 or 4.
#macro NextX(X,Dir)
   #switch(Dir)
      #case(0)
      #case(1)
         X+1
      #break
      #case(2)
         X
      #break
      #case(3)
      #case(4)
         X-1
      #break
      #case(5)
         X
      #break
Subject: Re: Problem with #switch
Date: 11 Feb 2008 19:05:01
Message: <web.47b0e2672c0eb44373e406e60@news.povray.org>
> #macro NextX(X,Dir)
>    #switch(Dir)
>       #case(0)
>       #case(1)
>          X+1
>       #break
>       #case(2)
>          X
>       #break
>       #case(3)
>       #case(4)
>          X-1
>       #break
>       #case(5)
>          X
>       #break
>    #end
> #end
I think you need to specify where the returned value is to be stored:
#macro NextX(X,Dir)
   #switch(Dir)
      #case(0)
      #case(1)
         #declare RetXVal = X+1;
      #break
      #case(2)
         #declare RetXVal = X;
      #break
      #case(3)
      #case(4)
         #declare RetXVal = X-1;
      #break
      #case(5)
      #break
Date: 11 Feb 2008 19:48:05
Message: <47b0ecc5$1@news.povray.org>
> after X+1.
> it's 2
#macro NextX(X,Dir)
   #switch(Dir)
      #range(0,1)
         #local result = X+1;
      #break
      #case(2)
         #local result = X;
      #break
      #range(3,4)
         #local result = X-1;
      #break
      #case(5)
         #local result = X;
      #break
   (result)
Date: 11 Feb 2008 19:53:07
Message: <47b0edf3@news.povray.org>
Oh, and #case doesn't need to be in order...
#macro NextX(X,Dir)
   #switch(Dir)
      #range(0,1)
      #break
      #range(3,4)
      #break
      #case(2)
      #case(5)
         #local result = X;
      #break
   (result)
Date: 11 Feb 2008 19:55:01
Message: <web.47b0ee232c0eb4439c37dbc40@news.povray.org>
On http://www.povray.org/documentation/view/3.6.1/243/ , it gives the example
#macro Interpolate(T,T1,T2,P1,P2)
   (P1+(T1+T/(T2-T1))*(P2-P1))
Which essentially replaces Interpolate(T,T1,T2,P1,P2) with
(P1+(T1+T/(T2-T1))*(P2-P1)).
Date: 12 Feb 2008 03:28:46
Message: <47b158be@news.povray.org>
"Archpawn" <nomail@nomail> wrote in message
news:web.47b0ded4bd25e05c9c37dbc40@news.povray.org...
> after X+1.
> it's 2
> #macro NextX(X,Dir)
>   #switch(Dir)
>      #case(0)
>      #case(1)
>         X+1
>      #break
> ... snip ...
I cut and pasted your macro into a new empty file and added the one line
#debug concat("AAAAA: ",str(NextX(1,0),3,0),"\n")
I ran it with a couple of different parameters and it worked as expected
(Black image, but a number returned to the message stream).
Are you sure you don't have an error in the main body of your code?
If you've got an open bracket out of place before any of the macro
invocations, then that would explain the message.
Chris B.
Date: 12 Feb 2008 11:27:06
Message: <47b1c8da@news.povray.org>
Mike the Elder <nomail@nomail> wrote:
> #macro NextX(X,Dir)
>    #switch(Dir)
>       #case(0)
>       #case(1)
>       #break
>       #case(2)
>       #break
>       #case(3)
>       #case(4)
>       #break
>       #case(5)
>       #break
>    #end
> #end
  No, not like that. Use #local and put the identifier name at the end
of the macro.
