POV-Ray : Newsgroups : povray.newusers : Changing parameters across runs Server Time
4 Mar 2026 14:26:19 EST (-0500)
  Changing parameters across runs (Message 1 to 5 of 5)
Subject: Changing parameters across runs
Date: 8 Nov 2007 00:25:00
Message: <web.47329d00a9b2848111481b6d0@news.povray.org>
I have various "planet" textures that I'm trying to pre-render animations for
for a game.  I've figured out a simple script for rendering a texture that
looks like this:
#declare TextureName = "Planets\\Terran01.png"
camera
    right x //Maintain square aspect ratio
    location <0, 0, 3>
    look_at <0,0,0>
sphere
    <0,0,0> 1
    texture
        pigment
            image_map
                png TextureName
                map_type 1  // Esfera
    rotate <0, -clock 0>  //Rotate so that the sun rises in the west
    finish { ambient 1 }
And the ini that looks like this:
; POV-Ray animation ini file
+ua ;Transparent background
Antialias=On
Antialias_Threshold=0.3
Antialias_Depth=2
Width=256
Height=256
Input_File_Name=Planet.pov
Output_File_Type = N
Output_File_Name = AnimatedPlanet\Planet
Initial_Frame=1
Final_Frame=36 ; 36 frames
Initial_Clock=0
Final_Clock=360
Cyclic_Animation=on
Pause_when_Done=off
What I'm trying to do now is change the texture being used so I can create a
batch file.  Ideally, I'd like something like this to work:
So I could pass parameters in to my ini, and have it change parameters in the
..pov file.  However, if there's a way to do this, I don't see it.  Can anyone
point me in the right direction?
Subject: Re: Changing parameters across runs
Date: 8 Nov 2007 13:01:08
Message: <47334ee4@news.povray.org>
"Numsgil" <Num### [at] yahoocom> wrote in message
news:web.47329d00a9b2848111481b6d0@news.povray.org...
>for
> looks like this:
> camera
>    location <0, 0, 3>
>    look_at <0,0,0>
> sphere
>    <0,0,0> 1
>    texture
>        pigment
>            image_map
>                png TextureName
> Antialias=On
> Antialias_Depth=2
> Width=256
> Height=256
> Initial_Frame=1
> Initial_Clock=0
> Final_Clock=360
> Cyclic_Animation=on
> Pause_when_Done=off
> a
> the
> anyone
So far as I know you can't do quite what you've asked for, but you can
probably get fairly close. If you take a look at the 'declare' 'ini-option'
in the help you'll see that it allows you to declare a float variable which
will be available to your scene file (not the ini file) e.g.
'declare=TextureIndex=5'.
You can define an array within the scene file to hold the list of textures
and index it using the variable that you use on the command-line call. For
example #declare MyTexture[TextureIndex] = "TextureA.png";  You'd need to
change the output file name on the command line from your script rather than
in the ini file so that each successive call doesn't overwrite the same set
of image files.
If you're running under Windows you may have a problem suppressing the
startup screen - I vaguely remember people discussing such problems in the
past.
I hope that helps
Chris B.
Date: 9 Nov 2007 01:30:01
Message: <web.4733fd86c7cd3aaf11481b6d0@news.povray.org>
Ah, I think I see.  Not the greatest solution, but I think it'll do.  Thanks.
Date: 11 Nov 2007 11:17:09
Message: <kurtzlepirate-81B91B.17170411112007@news.povray.org>
In article <web.47329d00a9b2848111481b6d0@news.povray.org>,
just use an array of png files :
  #declare textureArry[5] {"TextureA.png","TextureB.png",... }
then :
    image_map {
      png textureArry[frame_number]
klp
Date: 5 Dec 2007 20:30:00
Message: <web.47575015c7cd3aafa0d81c6b0@news.povray.org>
I'm interested in this kind of problem in a more generic sense.   I've posted
a video showing a different kind of interaction with parameters in POV-Ray.
http://www.youtube.com/watch?v=KOJFM-FOJVg
Could this be useful to you?
Best regards,
Daryl
