POV-Ray : Newsgroups : povray.newusers : PNG not produced in command line mode Server Time
14 Jul 2025 09:38:38 EDT (-0400)
  PNG not produced in command line mode (Message 1 to 4 of 4)
Subject: PNG not produced in command line mode
Date: 5 Oct 2007 09:00:00
Message: <web.470634a9b1bc15bef75836c20@news.povray.org>
Below I included my bathroom.pov file. I render with the command
"C:Program FilesPOV-Ray for Windows v3.6binpvengine.exe" +W360 +H540 +FN
+O"C:mepovraybathroom.png" "C:mepovraybathroom.pov"  /EXIT
However, when I uncomment the commented out line, ***no PNG is created***.
When I option the same file in the GUI, it does create the .bmp (I'm not
sure how to create .png out of the GUI).
Thanks for your help!
Here's bathroom.pov:
box { < -0.5, 0.0, 0.0 > < 0.0, 8.0, 9.0 > texture {pigment { color < 1.0,
1.0, 0.8 > }}}
box { < -0.5, 0.0, -0.5 > < 7.5, 9.0, 0.0 > texture {pigment { image_map {
jpeg "terracotta5.jpg"} }}}
light_source {< 3.5, 4.0, 7.0 > color < 1.0, 1.0, 1.0 >}
camera { perspective right x*-2/3 sky z angle 50 location < 3.0, -8.0, 6.0 >
look_at < 3.0, 7.0, 6.0 >}
Subject: Re: PNG not produced in command line mode
Date: 5 Oct 2007 10:10:00
Message: <web.470644e652f8916d726bd13c0@news.povray.org>
"Pahidla" <dol### [at] yahoocom> wrote:
> Hi,
> 1.0, 0.8 > }}}
In the GUI open POVRAY.INI (Tools > Edit Master POVRAY.INI) and add the
line:
Output_File_Type=N
See the help 3.1.2.4.1  Output File Type
Date: 5 Oct 2007 11:25:00
Message: <web.4706567e52f8916df75836c20@news.povray.org>
Thanks for the info, but I botched the original post because I forgot to
comment out the culprit line. The .pov file is
1.0, 0.8 > }}}
//box { < -0.5, 0.0, -0.5 > < 7.5, 9.0, 0.0 > texture {pigment { image_map {
and what I'm asking is why does the presence of the commented out line
affect the generation of the png. Thanks!
Date: 6 Oct 2007 17:16:25
Message: <4707fb29$1@news.povray.org>
> 1.0, 0.8 > }}}
If you try to render from the command line, be sure that the jpeg file
is indeed in the directory where you launch the command. Normally povray
should give an explicit error message if this is not the case... And
obviously no output image can be generated.
You did not give your working directory, but if your command line looks
like this:
C:\> "C:\Program Files\POV-Ray for Windows v3.6\bin\pvengine.exe" +W360
+H540 +FN +O"C:\me\povray\bathroom.png" "C:\me\povray\bathroom.pov" /EXIT
then povray will try to find "terracotta5.jpg" in C:\.
With the GUI it works, because it always starts povray in the directory
where the pov file resides (I'm not sure since I don't have a windows
machine at hand, but I think it does).
Perhaps you can try to remove the /EXIT option, and look at the error
log within the GUI. If it complains about not finding the jpeg image,
then you should change your working directory to where the image is
located, with this command:
cd "C:\me\povray\"
Hope this helps,
Vincent
