POV-Ray : Newsgroups : povray.newusers : How to run POV-Ray from command line Server Time
2 May 2026 09:05:49 EDT (-0400)
  How to run POV-Ray from command line (Message 1 to 8 of 8)
Subject: How to run POV-Ray from command line
Date: 5 Oct 2007 00:30:01
Message: <web.4705bd7114b847653ccd3f470@news.povray.org>
I can't seem to find the most elementary info on how to run POV-Ray from
command line in Windows.
I have finally figure out that I can do something like:
"C:Program FilesPOV-Ray for Windows v3.6binpvengine.exe" +W160 +H90
"C:pgpavraybox.pov"  /EXIT
....but I stumbled across the +W160 type options by accident, the /EXIT
options in the documentation, not sure how I solved the "I/O restictions"
issue and don't know how to suppress the display window and produce PNG
output, and many other options.
Is there a coherent source on this? (My guess is that I am terrible at
looking for stuff.)
Many thanks in advance.
Pahidla
Subject: Re: How to run POV-Ray from command line
Date: 5 Oct 2007 03:55:42
Message: <4705edfe$1@news.povray.org>
"Pahidla" <dol### [at] yahoocom> wrote in message
news:web.4705bd7114b847653ccd3f470@news.povray.org...
> Hi,
> looking for stuff.)
> Pahidla
Hi Pahidla,
The POV-Ray help file has a section on Command Line Options (Section 3.1.2
in the Windows version that I have).
This is also covered in the online help starting at
http://www.povray.org/documentation/view/3.6.1/215/
Chris B.
Date: 5 Oct 2007 15:42:51
Message: <470693bb$1@news.povray.org>
Pahidla nous apporta ses lumieres en ce 2007/10/05 00:28:
> Hi,
> looking for stuff.)
> Pahidla
The Windows version is not meant to run from the command line alone.
You can add a /minimized switch to start it minimized.
You can add "-d" to suppress the display window.
If you never want the display window, you can add this to povray.ini on a
separate line.
To output as PNG, add "+fn" to the command line.
To always output as PNG, add "+fn" to povray.ini. You can add this alone on any
line.
Easy way to do it: In the menu line, look for "Tools" and select "Edid master
POVRAY.INI"
You can set the image resolution to any size and proportion you want. Don't
forget to also set the camera aspect ratio acordingly if you use an aspect ratio
other than 4:3. If you regularly use particular resolutions and some other
settings, you can add them to the "quickres.ini" file.
No matter how much you do, you never do enough.
Date: 28 Aug 2009 13:10:00
Message: <web.4a980ecb333786ed64c007780@news.povray.org>
This may be a silly question, but I just want to be sure. Can both POV files and
INI files be run through the command line (with POV-Ray loaded and minimized of
course).
Date: 29 Aug 2009 15:51:35
Message: <4a9986c7@news.povray.org>
> course).
Yes
Date: 2 Sep 2009 17:55:00
Message: <web.4a9ee8fd333786ed3756a7220@news.povray.org>
When adding the /minimized switch I get the following message: "/minimized is
not a recognized command-line option"
POVRAY /RENDER "C:\Test.ini" -d /EXIT
I tried adding the /minimized switch both before and after rendering begins and
got the same result. Any thoughts?
Date: 3 Sep 2009 20:22:35
Message: <4aa05dcb$1@news.povray.org>
If you want to do several renders, you don't need the /exit switch.
Instead of calling POV-Ray directly, you can pass through a shortcut
that will launch it minimised. You should set "only keep a single
instance" in your preferences.
povray.lnk /renderer "C:\Test.ini" -d
Date: 4 Sep 2009 14:15:00
Message: <web.4aa15812333786ed64c007780@news.povray.org>
> Alain
I tried your suggestion and passed a shortcut that launches the application
minimized but no luck, it still shows the window same as before. I guess it's
fine as long as the app runs, does the renders, and then exits when it's done.
Thanks anyways.
