POV-Ray : Newsgroups : povray.newusers : photons and refraction Server Time
2 May 2026 10:48:12 EDT (-0400)
  photons and refraction (Message 1 to 10 of 10)
Subject: photons and refraction
Date: 17 Aug 2007 12:25:01
Message: <web.46c5caeeadcd499789891a3f0@news.povray.org>
Hi everyone,
I'm new to povray and have recently been playing around with media and
photons.  Below is a little test scene I put together to help me understand
how these things work, but I haven't been able to get it to work as I would
expect.
What is supposed to happen, is a narrow beam of light from a spotlight
enters some scattering media so it shows up, enters a glass block at an
angle, where it is refracted, and then exits at the other side, where it
shows up in the media again.
What actually happens is it shows up before it strikes the block, but then
does not show up again at the other side.  I have been looking at the
source code of other scenes that do something similar (particularly the
advanced/optics.pov scene that comes with povray) but I can't really tell
what I am doing wrong.
Here is what I have so far:
global_settings {
    assumed_gamma 1
    photons {
 count 10000
 jitter 0.2
 media 100, 2
// Fog
box { <-2,-2,-2>, <2,2,2>
    hollow
 pigment { colour rgbf 1 }
    interior {
 media {
     scattering { 1, colour Gray50 extinction 1 }
     method 2
     intervals 10 samples 20
// Glass block
box {<-0.5,-0.5,-2>, <0.5,0.5,2>
    material {
     finish { ambient 0 diffuse 0 reflection 0 }
 interior {
     ior 1.5
    rotate -30*z
    photons {
 target
 refraction on
 reflection off
// Spotlight
light_source { <152, 0, 0>, colour 20*White
    spotlight
    radius 0.01
    falloff 0.02
    point_at <0,0,0>
    photons {
 refraction on
 reflection off
    location <0,0,-8>
    look_at <0,0,0>
    angle 50
// End
Subject: Re: photons and refraction
Date: 17 Aug 2007 13:19:02
Message: <46c5d886@news.povray.org>
Hi
> Hi everyone,
d
understand
would
> expect.
t
an
it
then
he
the
tell
> // Glass block
I think you must make the glass block hollow.
Date: 17 Aug 2007 15:08:12
Message: <46c5f21b@news.povray.org>
  Why would that make a difference?
  Yet another case of "hollow" being a catch-all generic solution to all
problems. (Although this is certainly not the weirdest situation where
it has been (wrongly) suggested as a possible solution, though.)
  People should *try* before suggesting.
Date: 17 Aug 2007 15:18:32
Message: <46c5f487@news.povray.org>
>   all
You are right, sorry. One only needs to make it hollow if it contained
any media (and he does not want to see the photons inside the glass
block). The hollow keyword does not affect refraction and photons
passing through (if there is no media).
Date: 17 Aug 2007 17:52:58
Message: <46c618ba@news.povray.org>
Neither can I, but actually you are not getting any photons at all.
The beam of light you see before the block is not related to photons,
it's the normal interaction of the spotlight with scattering media.
Note that no photons are stored during the render, which probably
implies that the target is blocked. Adding photons {pass_through}
to the box containing the fog at least causes some photons to be
shot and stored, although I'm not sure if this yields the correct
effect and why it should be necessary.
Date: 18 Aug 2007 08:32:23
Message: <46c6e6d7$1@news.povray.org>
Oliver nous apporta ses lumieres en ce 2007/08/17 12:21:
> Hi everyone,
> expect.
> global_settings {
>     assumed_gamma 1
>     photons {
>  count 10000
>  jitter 0.2
>  media 100, 2
> // Fog
>     hollow
>     texture {
>     interior {
>  media {
>      method 2
> // Glass block
>     material {
>  texture {
>  interior {
>      ior 1.5
>     rotate -30*z
>     photons {
>  target
>  refraction on
>  reflection off
> // Spotlight
>     spotlight
>     radius 0.01
>     falloff 0.02
>     point_at <0,0,0>
>     photons {
>  refraction on
>  reflection off
> camera {
>     location <0,0,-8>
>     look_at <0,0,0>
>     angle 50
> // End
Found the problem!
You need to add: photons{pass_through} to the media container.
When shooting photons, if there is anything in the way, the photon is not sent.
Even if that something is perfectly transparent. With pass_through, that object
is ignored.
Look at it as a no_shadow for photons. In fact, any object with pass_through
will automaticaly be made no_shadow.
Just remember - if the world didn't suck, we would all fall off.
Date: 18 Aug 2007 08:45:00
Message: <web.46c6e8c0c9143cf273365c0@news.povray.org>
The solution in the end was to increase the number of photons to 100000 (I
was using 10000 before).  Also, it was necessary (but not sufficient) to
either make the box with the fog in it a target or make the photons
pass_through (thanks, Christian), although making it a target didn't really
make that much difference and only slowed things down.
I have a few other questions about this.  It seems that the number of
photons had to be increased because the beam of light was quite narrow.  Is
this actually the case and if so, why?
For the scattering media, I used in the end 'intervals 3 samples 40' because
this seemed to produce acceptable results, but what is the best advice for
choosing samples and intervals?  I read somewhere that increasing intervals
was slower than increasing samples.
Thanks for everyone's help so far.
Oliver
Date: 18 Aug 2007 10:13:35
Message: <46c6fe8f@news.povray.org>
Oliver nous apporta ses lumieres en ce 2007/08/18 08:40:
It depends on the sampling method used.
Using method 1 or 2, increasing intervals have a medium effect in the speed.
Using method 3, the default, increasing intervals have a huge impact on the
render speed, while increasing samples have a medium to low impact. With method
3, you need to keep intervals at 1 and increase samples as needed.
Also, with method 3, if you use 2 values for samples, the second will be ignored.
> Regards,
> Oliver
I find that the harder I work, the more luck I seem to have.
Thomas Jefferson
Date: 18 Aug 2007 12:44:12
Message: <46c721dc@news.povray.org>
> not sent. Even if that something is perfectly transparent. With
> pass_through, that object is ignored.
That seems to be the behavior, although I think the documentation
should be clearer on this point. The comparison to no_shadow is
misleading, as transparent objects (at least those with ior 1)
don't need that keyword to cast no shadow.
Date: 2 Oct 2007 02:00:05
Message: <web.4701d953c9143cf5dc8ce470@news.povray.org>
I happened to be experimenting with a test scene almost identical to yours,
running into problems, then spotted your post. Glad to see that there
wasn't a problem after all.
BUT...it's interesting to note that ATMOSPHERIC media (i.e., not enclosed in
an object) DOES exhibit this problem: When photons are on, the
light source/media interaction is extinguished at the first glass
surface that the light hits...even with hollow on. There doesn't seem to
be any solution to the problem in this case (I've tried every
trick I can think of.)  Perhaps it's a bug. Of course, the
media/photons example given in the  POV docs involves only
object media--which is, in most cases, a more *efficient* way of
doing things anyway.
It would be useful if atmopheric media worked the same way, though.
Ken W.
