POV-Ray : Newsgroups : povray.newusers : Defining colors from an image Server Time
23 Jan 2025 16:31:33 EST (-0500)
  Defining colors from an image (Message 1 to 7 of 7)
Subject: Defining colors from an image
Date: 3 Jul 2007 16:15:02
Message: <web.468aad2d14dc5f2d39928d3a0@news.povray.org>
Hi all -
It's been a few days since my last random question, so here we go -
Is there any way to take the color of a certain area of an image (jpeg, png,
etc.) and find out its values in rgb? Someting along the lines of the
"eyedropper" tool in Photoshop for defining custom colors?
Thanks
OpalPlanet
Subject: Re: Defining colors from an image
Date: 3 Jul 2007 17:18:09
Message: <468abd11@news.povray.org>
  Perhaps a bit surprisingly, there is:
// The image will extend from <0, 0, 0> to <1, 1, 0>:
#declare Image = function { pigment { image_map { jpeg "SomeImage" } } };
#declare Pixel = Image(.5, .5, 0);
#debug concat("The value at <.5, .5> is <", vstr(3, Pixel, ", ", 0, 3), ">\n")
Date: 3 Jul 2007 18:22:29
Message: <468acc25@news.povray.org>
As an alternative to Warp's suggestion, you may want to try using
eval_pigment. It doesn't require you to make the pigment into a function
beforehand, but you must still pre-declare it. Here's an example:
#include "functions.inc" // Required. Include this or transforms.inc
#declare img=     // our image to test
  pigment{
   image_map{
    //sys"fish.bmp"
    tga"gold_nugget.tga"
  translate -(x+y)/2   // center the image
  scale<1.33,1,1>*10   // scale the centered image
#declare test_color=
  eval_pigment(
   img,     // the pigment we are testing
   <0,0,0>  // The point in 3d space to test at.
            // It will test AFTER the above transformations
sphere{0,.5  // a sphere to show tested color
  pigment{
   test_color                                       // this is legal
   //rgb test_color                                 // so is this
   //rgb <test_color.x, test_color.y, test_color.z> // this also works
  finish{ambient 1}
plane{z,.5 // plane to show entire pigment
  pigment{img}
  finish{ambient 1}
I hope this is helpful~
~Sam
Date: 3 Jul 2007 18:30:02
Message: <web.468acd0fad49873139928d3a0@news.povray.org>
That's awesome, thanks Warp!
-OpPl
> #debug concat("The value at <.5, .5> is <", vstr(3, Pixel, ", ", 0, 3), ">n")
Date: 3 Jul 2007 19:44:52
Message: <468adf74@news.povray.org>
> eval_pigment.
  Internally eval_pigment does exactly what my example, but it does it
every time you call it, and thus it's much slower. If you define a
pigment function yourself you only have to do it once and call the
same function repeatedly, which is much faster.
Date: 4 Jul 2007 01:30:24
Message: <468b3070@news.povray.org>
>> eval_pigment.
Again, you teach me something I did not know. I have a certain file
which is badly in need of this information. Thanks!
Now, to the docs! To see if I have no excuse for my ignorance :)
~Sam
Date: 5 Jul 2007 22:20:55
Message: <468da707@news.povray.org>
Wow, that is cool.  I was mass-measuring some images with povray for a work
application and went to the trouble in my first case of converting each one
to ASCII-format PPM's.
>> png, etc.) and find out its values in rgb?
> #">\n")
