POV-Ray : Newsgroups : povray.newusers : Simple trig question Server Time
2 May 2026 12:30:30 EDT (-0400)
  Simple trig question (Message 1 to 10 of 14)
Subject: Simple trig question
Date: 13 Jun 2007 14:20:01
Message: <web.46703502695d64ebff6e04e90@news.povray.org>
I'm ashamed to have to ask this, but I just can not remember how to
calculate an angle in degrees if I know the opposite and adjacent side of a
right-angled triangle.
My only excuse is that I'm an OAP and school was just years ago and then
radians were not taught!
Help!
Thanks
Zog
Subject: Re: Simple trig question
Date: 13 Jun 2007 14:41:53
Message: <46703a71$1@news.povray.org>
> Help!
> Thanks
> Zog
If it looks like this
        alpha
   h /=|
    /  | o
     a
alpha = atan (a/o)
alpha = acot (o/a)
alpha = asin (a/h)
Is this what you wanted ... POVCODE?
Marc
Date: 13 Jun 2007 15:05:02
Message: <web.46703ec3f87630f4c150d4c10@news.povray.org>
> > Help!
> > Thanks
> > Zog
>         alpha
>    h /=|
>     /  | o
>      a
> alpha = atan (a/o)
> alpha = acot (o/a)
> alpha = asin (a/h)
> Marc
Better to use atan2(a,o).  Handles situation where o is zero.
Also note the results of these is in radians to convert to degrees use
degrees(A) in POV (or A*180/pi by hand).
-tgq
Date: 13 Jun 2007 15:13:40
Message: <467041e4@news.povray.org>
Thank you Marc, but I tried that the following
   rotate<atan(1/2),0,0>
should be the same as
  rotate<30,0,0>
but it is not and atan(1/1) does virtually nothing.
- or am I doing something wrong?
"Marc Schimmler" <mar### [at] webde> wrote in message
news:46703a71$1@news.povray.org...
of a
> > Help!
> > Thanks
> > Zog
>         alpha
>    h /=|
>     /  | o
>      a
> alpha = atan (a/o)
> alpha = acot (o/a)
> alpha = asin (a/h)
> Marc
Date: 13 Jun 2007 15:15:23
Message: <4670424a@news.povray.org>
>   rotate<30,0,0>
  It shouldn't because atan() returns radians while rotate takes degrees.
  Besides, you should really use atan2().
Date: 13 Jun 2007 15:17:28
Message: <467042c8$1@news.povray.org>
> -tgq
You are right with regrad to POV, I explained it more the mathematical
way ...
Marc
Date: 13 Jun 2007 15:18:26
Message: <46704302@news.povray.org>
Thanks tgq, but
   rotate<(degrees(atan2(1,2))),0,0>
is not exactly the same as
  rotate<30,0,0>
 - it is a little off as I suspect it is using the arc of a radian circle
instead of straight lines
"Trevor G Quayle" <Tin### [at] hotmailcom> wrote in message
news:web.46703ec3f87630f4c150d4c10@news.povray.org...
of a
then
> > > Help!
> > > Thanks
> > > Zog
> >         alpha
> >    h /=|
> >     /  | o
> >      a
> > alpha = atan (a/o)
> > alpha = acot (o/a)
> > alpha = asin (a/h)
> > Marc
> -tgq
Date: 13 Jun 2007 15:21:35
Message: <467043bf@news.povray.org>
Thanks Warp, but
or
   rotate<(atan2(1,2)),0,0>
is not the same as
  rotate<30,0,0>
- 'tis a real puzzle!
news:4670424a@news.povray.org...
> >   rotate<30,0,0>
Date: 13 Jun 2007 16:05:01
Message: <web.46704cf6f87630f4c150d4c10@news.povray.org>
"TheMightyZog" <Chr### [at] HotPOPcom> wrote:
> Thanks tgq, but
>   rotate<30,0,0>
Of course this isn't the same.  the arctan of 1/2 is ~28.6 degrees not 30.
I.e., the tan of 30 is not 1/2, it's 0.577, you are thinking of sin(30)
which is O/H not O/A:
rotate<(degrees(asin(1/2))),0,0> = rotate<30,0,0>
-tgq
Date: 13 Jun 2007 16:15:29
Message: <46705061@news.povray.org>
  What does that even mean?
