POV-Ray : Newsgroups : povray.newusers : Newbie - inside/outside colours Server Time
23 Jan 2025 19:28:39 EST (-0500)
  Newbie - inside/outside colours (Message 1 to 5 of 5)
Subject: Newbie - inside/outside colours
Date: 5 Jun 2007 10:00:01
Message: <web.46656b8a194d8e0ff6e04e90@news.povray.org>
This is a fantastic program and I'm really enjoying getting to grips with
ray tracing.
I've searched and can't find out how to colour the inside surface
differently from the outside surface of an object.
The following is a U shaped pipe and I would like the inside to be White and
the outside Yellow.  How can I do it?
Thanks
Zog
#include  "colors.inc"
background { color White }
light_source { < -100, 100, -100 > color White}
light_source { <    0,   0, -100 > color Red}
light_source { <  100,   0,    0 > color Blue}
cylinder{
     < -2, 0, 0 >, < 1, 0, 0 >,1
     clipped_by { // open length ways
          box { <-1, 0 ,-1>, <1.1 ,1, 1> inverse }
     clipped_by { // cut off the end
          box { <0.99, -1.1, -1>, <1.1 ,1, 1> inverse }
     pigment { color Yellow
     rotate <-45, 0, 0>
sphere{ // this is the colour the inside should be
        <0, -0.1, 0>, 0.2
     pigment { color  White
     location  <3, 3, -3>
     look_at   <0, 0, 0>
Subject: Re: Newbie - inside/outside colours
Date: 5 Jun 2007 10:20:01
Message: <web.466570706feb66cec150d4c10@news.povray.org>
"TheMightyZog" <Chr### [at] HotPOPcom> wrote:
> Hi,
> ray tracing.
> Thanks
> Zog
> cylinder{
>      rotate <-45, 0, 0>
>         <0, -0.1, 0>, 0.2
> camera {
>      location  <3, 3, -3>
>      look_at   <0, 0, 0>
Have a look at "3.5.9  Interior Texture" for what you are asking for
specifically.
-tgq
Date: 5 Jun 2007 10:21:39
Message: <46657173@news.povray.org>
Model the geometry both for the inside and the outside (your
pipe is bound to have some physical thickness), and make the
actual object the "difference" of outside - inside. To avoid
numeric problems (coincident surfaces), the "inside" pipe
should a bit longer than the "outside" pipe.
Depending on your geometry, you can often get away with using
a scaled down copy of the outer shape for the inner shape.
Date: 5 Jun 2007 10:50:02
Message: <web.466577246feb66ce726bd13c0@news.povray.org>
You forgot to say that the outside should have one texture and the object
that you are differencing it with, should have another texture.
Date: 5 Jun 2007 12:30:01
Message: <web.46658ec96feb66ceff6e04e90@news.povray.org>
> Stephen
Thank you all very much - all obvious, I was just searching Google with the
wrong words and forgot about texture - was just thinking of pigment!
