POV-Ray : Newsgroups : povray.newusers : A ghostly transparent sphere Server Time
2 May 2026 14:22:29 EDT (-0400)
  A ghostly transparent sphere (Message 1 to 5 of 5)
Subject: A ghostly transparent sphere
Date: 22 Mar 2007 06:30:02
Message: <web.460267ad8ef3907b41254bd10@news.povray.org>
I am really new at this and struggling a bit, so would appreciate any help !
I need a transparent translucent ghostly sphere - just visible - with no
reflections, no refraction and no specular high-lights.
I think this must be really easy to do, but whatever I try is just too
glass-like.....
Thanks in advance for any help.
Kevin
Subject: Re: A ghostly transparent sphere
Date: 22 Mar 2007 07:30:02
Message: <web.460275e97dff850dc150d4c10@news.povray.org>
> glass-like.....
> Kevin
There are several ways to do the sphere material depending on whether you
want it as a shell or solid.  You can use a surface material on it using
filter or transmit, or you could use an internal (volumetric) material
using media.  To make sure it isn't reflective, remove any reflective
properties from the surface finish and to make sure it isn't refractive,
remove any ior settings from the interior.
-tgq
Date: 22 Mar 2007 07:55:01
Message: <web.46027bca7dff850d41254bd10@news.povray.org>
Trevor
Thank you so much. I knew it would be easy....
Kevin
> > glass-like.....
> > Kevin
> -tgq
Date: 22 Mar 2007 10:40:02
Message: <web.4602a2807dff850dc1d5d88c0@news.povray.org>
Hi Kevin,
if you want to be sure to have no specular high-lights, set specular to zero
in the finish block.
You have to decide if you want the sphere transparent or translucent,
example:
// put this in the insert scene template "Checkered floor"
//instead of the reflective sphere.
sphere {
  0.0, 1
      color rgb <1,0,0>
      filter 0.85
    finish{
      diffuse 0.6
      ambient 0.1
      specular 0.0
    no_shadow
    #declare milky = true;
    // true -> translucent, false -> transparent
    #if (milky)
     hollow // turns media on
    interior {
          ior 1.000
          media {
               scattering {
                    4,   // scattering type 1=isotropic; 2=Mie haze; 3=Mie
murky
                         // 4=Rayleigh; 5=Henyey-Greenstein
                    0.8  // color and/or media density
With milky=true it is translucent (with scattering medium), with milky=false
it is transparent (without medium).
Also check which one is better for you:
filter (0-100%, 85% here) or transmit.
"transmit" fades out the color, "filter" just makes the objects transparent
without loosing the color.
ior is set to 1, so no refraction.
Yours,
Bu.
Date: 22 Mar 2007 16:43:16
Message: <4602f874$1@news.povray.org>
Burki nous apporta ses lumieres en ce 22-03-2007 11:36:
> Hi Kevin,
> example:
> sphere {
>   0.0, 1
>     pigment {
>       color rgb <1,0,0>
>       filter 0.85
>     finish{
>       diffuse 0.6
>       ambient 0.1
>       specular 0.0
If you don't specify any specular, it default to disabled, or no specular
highlighting. Same thing with phong.
>     no_shadow
>     #if (milky)
>     #end
>     interior {
>           ior 1.000
>           media {
>                scattering {
> murky
If you don't set any ior value, it default to 1 or NO refraction.
> Yours,
> Bu.
Another way, faster than using a media, is to use fading. Here's how it's done:
interior{fade_color Your_Color fade_distance Some_distance fade_power 1}
You need to adjust fade_distance to suit your situation. A large object, or one
you want only lightly coloured, needs a larger value, while small ones, or
strongly coloured, need small value.
This give "substance" to the interior of your sphere. The longer you travel
inside it, the more the fade colour will apears. It's a LOT faster than
scattering media.
A key difference: if a beam of light goes trough your object, the one filled
with media will make the beam visible, while the fading one won't.
Depending on your need, you chose one, the other, or both as they are compatible.
Wouldn't it be nice if whenever we messed up our life we could simply press
'Ctrl Alt Delete' and start all over?
