POV-Ray : Newsgroups : povray.newusers : <no subject> Server Time
2 May 2026 14:21:12 EDT (-0400)
  <no subject> (Message 1 to 10 of 13)
Subject: <no subject>
Date: 7 Feb 2007 15:55:01
Message: <web.45ca3bdcc23a6d93dc296c80@news.povray.org>
I'm an absolute beginner, so please bear with me.
I'm trying to create a snow globe, based on a hollow glass sphere. This
works as expected. However, when I place an additional object (sphere)
inside the globe, it turns out black, as if it's not lit. When I give the
additional sphere a reflective finish, it does come out as expected.
I'm using no lights in my scene, all light comes from HDRI lighting. When I
do place some lights, the second sphere does show its color, but still too
dark.
BTW, increasing max_trace_level doesn't help. The code for both objects is
stated below.
//glass globe
object{
 difference{
  sphere {
   <0, 0, 0> // center of sphere <X Y Z>
   500/65    // radius of sphere
  sphere {
   (500/65)-0.15    // radius of sphere
 material{
    texture{
      pigment { color rgbf <0.98, 0.98, 0.98, 0.925> }
     finish { F_Glass3 }
    normal{bumps .1 scale 4}
   finish{reflection{.01,.9 fresnel} conserve_energy}
  interior{I_Glass}
//additional sphere
sphere {
  <0, 0, 0>, 2
  pigment { color rgb <1,0,0>}
  finish {
   ambient 0
   diffuse 1
Subject: Re: <no subject>
Date: 7 Feb 2007 21:23:38
Message: <45ca89aa$1@news.povray.org>
> I
> dark.
Do you have a radiosity block?
With radiosity ambient 0 means an object doesn't emit light,
do you have other objects with higher abmbient as a light source,
with an HDRI image map?
Background and sky_sphere are an infinite distance so you'd
be better off using a large inverted sphere to provide a light.
> stated below.
max_trace_level 5 should be fine for this.
Date: 8 Feb 2007 07:35:00
Message: <web.45cb18aa6f92e856f7c2da9e0@news.povray.org>
Yes.
Ambient 0 is recommended when using radiosity, no?
I'm already using a large sphere with an HDRI image map instead of
sky_sphere. This shpere has ambient >0, hence it functions as a light
source.
BWT, I'm using MegaPov, since Povray 3.6 doesn't support HDRI.
Date: 8 Feb 2007 09:54:01
Message: <45cb3989@news.povray.org>
  The reflection of light on surfaces is controlled by the diffuse term
(as it should). The ambient component can be bumped up to artificially
make a surface emit more light than it normally would, but ambient is
not necessary, and in fact for "realistic" results should be turned off.
(After all, the ambient component is only a cheap radiosity substitute.)
Date: 8 Feb 2007 10:50:00
Message: <web.45cb468f6f92e856731f01d10@news.povray.org>
> source.
Aha. Try adding the no_radiosity keyword to your glass dome.
Bill
Date: 9 Feb 2007 07:10:01
Message: <web.45cc63f36f92e856f7c2da9e0@news.povray.org>
> > source.
> Bill
Thanks! That did the trick.
Can anybody explain why this is needed here? I don't understand it.
Date: 9 Feb 2007 07:35:00
Message: <web.45cc69d56f92e856731f01d10@news.povray.org>
I think it's just because the radiosity sampling ignores transparency.
Presumably, diffuse and ambient contributions to the illumination are taken
from the first object encountered along the sampling ray regardless of other
surface characteristics; as a side effect, transparent objects block
radiosity lighting. I'm sure others can expand on this if I have it wrong!
I'm not sure how one would reliably avoid this issue in standard POV-Ray
versions though - I think no_radiosity is indigenous to MegaPOV.
Bill
Date: 9 Feb 2007 22:34:54
Message: <45cd3d5e$1@news.povray.org>
Bill Pragnell nous apporta ses lumieres en ce 09-02-2007 07:32:
It get's thru transparent objects in standard POV-Ray.
> Bill
Radiosity do work trough transparent objects, you can even have a lense or globe
project an image on a surface. That image becomes crude if the focal lenght gets
to long, but it's there.
WARNING: the crumsumpten of alcohol may Mack you tink you kan tpye reel gode
Date: 13 Feb 2007 06:05:02
Message: <web.45d19a7b6f92e856f7c2da9e0@news.povray.org>
Yes, I guessed it should be possible. Is there anything I can do to 'fix'
this problem except for adding the no_radiosity keyword?
Date: 13 Feb 2007 18:06:46
Message: <45d24486$1@news.povray.org>
Render it as a 2 frame animation and use save_file to save the
radiosity data witout the glass, then load the data back in and
do a final frame with the glass.
global_settings {
  assumed_gamma 1.0
  max_trace_level 10
#switch (frame_number)
#case (1)
   radiosity {
      save_file "bidirectional.dat"
#break
#case (2)
   radiosity {
      load_file "bidirectional.dat"
   object {globe}
#break
