POV-Ray : Newsgroups : povray.newusers : Transparent text Server Time
14 Jul 2025 16:46:16 EDT (-0400)
  Transparent text (Message 1 to 6 of 6)
Subject: Transparent text
Date: 16 Jan 2007 10:10:00
Message: <web.45ace9bbfe7718bfca24f7610@news.povray.org>
Hi!
I want to to make a text string semi transparent.  Tried to use pigment with
rgbf but it does not work as I thought it would.  Any help appreciated.  The
code I thought would work below.
TIA
, Espen
text {
   ttf "impact.ttf" "Text String" 0, 0
   pigment { rgbf < 1.0, 1.0, 1.0, 0.5 > }
   finish { ambient 1 diffuse 0 }
Subject: Re: Transparent text
Date: 16 Jan 2007 11:05:00
Message: <web.45acf737182cb103c150d4c10@news.povray.org>
"Espen" <nomail@nomail> wrote:
> Hi!
> TIA
> , Espen
> text {
Works fine for me.  Perhaps, you expect something different?
//START
camera{
  up y
  angle 30
  location <0,0,-10>
  look_at  0
text {
  translate -x*2
cylinder{-x*3,x*3,0.1 pigment{rgb <1,0,0>}finish { ambient 1 diffuse 0 }
translate <0,0.3,1>}
//END
-tgq
Date: 16 Jan 2007 16:50:00
Message: <web.45ad477f182cb103ca24f7610@news.povray.org>
Ah.  I found out what was wrong.  Though now it puzzles me more.
This line works:
This is white colored text.  But in my scene the text is not white but dark
grey.  I use this line:
   pigment { rgbf < 0.2, 0.2, 0.2, 0.5 > }
And now there is hardly any translucency.  How do I fix this?  It seems like
a bug or something.  Can't see why black or dark colored text shouldn't be
transparent.
Sorry for not correctly giving the actual problem the first time.
, Espen
Date: 16 Jan 2007 18:20:43
Message: <45ad5dcb$1@news.povray.org>
> This line works:
> transparent.
> , Espen
Try rgbt instead of rgbf. Section 3.2.1.5 in the documentation explains
the difference between filter and transmit better then I could.
Date: 17 Jan 2007 05:10:00
Message: <web.45adf59a182cb103ca24f7610@news.povray.org>
Thanx!  Putting in rgbt instead of rgbf worked right away.
, Espen
Date: 17 Jan 2007 06:06:38
Message: <45ae033d@news.povray.org>
  I'm actually not 100% sure about the functions used for the filter
and transmit channels, but as far as I can tell, the filter channel
is a substractive channel while the transmit channel is a kind of
"alpha" channel (in the same way as eg. in a png).
  Substractive means in practice that the color of the surface will
block any light going through it which is not of the color of the
surface. In other words, it will *filter* the light.
  So for example, if the color of the surface is rgbf <1, 1, 0, 1>
then it will let all red and green components pass, but will block
any blue component, and thus no blue light will pass through.
  The values of the filter between 0 and 1 means, AFAIK, how much
of the filtered light is shown and how much of the surface's own color.
In other words, if you had rgbf <1, 1, 0, 0.5> then half of the color
will be from the surface's own color (ie. <1, 1, 0>) and half of it
will be of the light going through (which is filtered by <1, 1, 0>).
  The transmit is basically the same, but it doesn't block anything.
It thus works like an alpha channel. If transmit is 0 then only the
surface color is shown. If transmit is 1, then only the light passing
through is shown. If it's eg. 0.5 then half and half are shown (or in
other words, their average).
