POV-Ray : Newsgroups : povray.newusers : Averaged Normal_maps Server Time
14 Jul 2025 18:53:48 EDT (-0400)
  Averaged Normal_maps (Message 1 to 7 of 7)
Subject: Averaged Normal_maps
Date: 12 Dec 2006 18:10:01
Message: <web.457f35b82645b59e9033e1160@news.povray.org>
I'm trying to create a texture that combines multiple normal patterns, so of
course I use "average".  But the resulting pattern is too shallow, and I
want to make it more pronounced.  I've tried various things, but I can't
seem to increase the intensity.  Anybody know what I'm doing wrong?
Subject: Re: Averaged Normal_maps
Date: 13 Dec 2006 00:05:00
Message: <web.457f88ebb76ee1819033e1160@news.povray.org>
Actually, I believe my problem may be with the pattern that I'm using.  I'm
using facets, and after checking the documentation I haven't found a way to
increase the intensity of the facets for a normal.
I'm trying to have a texture that has large facets, but with smaller facets
between.  So I averaged a large facet normal and small facet normal, but in
the result the facets are so faint you can hardly see either of them.
Date: 13 Dec 2006 04:48:56
Message: <457fcc88$1@news.povray.org>
"Kirk Andrews" <kir### [at] hotmailcom> wrote in message
news:web.457f88ebb76ee1819033e1160@news.povray.org...
> facets
> in
I don't know if it would be of any use in your circumstances, but I've found
that for flat surfaces it can be effective to scale the normal in a
direction at right angles to the surface. I've included a simple but extreme
example below.
camera {location <0,1,-1>}
light_source { <1, 20, -20> color rgb 1}
plane {y,0 rotate  z*0.001
    pigment {color rgb 1}
    normal {granite}
plane {y,0 rotate -z*0.001
    normal {granite scale <1,10,1>}
Chris B.
Date: 13 Dec 2006 06:01:47
Message: <457fdd9b$1@news.povray.org>
Kirk Andrews nous apporta ses lumieres en ce 13-12-2006 00:00:
Try increasing the ponderation factor for the large patern.
normal_map{[2 facets][1facets scale 0.1]}
This will double the weight of the large scale pattern.
"The fact that windows is one of the most popular ways to operate a computer
means that evolution has made a general fuckup and our race is doomed."
            -- Anon.
Date: 13 Dec 2006 07:31:56
Message: <457ff2bc$1@news.povray.org>
Well you can do this:
normal {
    average 200 //this scales the bumps a lot, default is 1
    normal_map {
        etc.
Or you can use bump_scale ... anywhere to have the same effect.
Not sure if it affects facets.
Also accuracy is worth tweaking, since normals sometimes appear a but wrong
because it's sampling them inaccurately, so a smaller accuracy value can
produce sharper edges but sometimes makes it look worse. Though again I'm
not sure if this affects facets.
Tek
http://evilsuperbrain.com
> I'm
> to
> facets
> in
Date: 13 Dec 2006 07:32:28
Message: <457ff2dc@news.povray.org>
Correction, I mean bump_size.
Tek
news:457ff2bc$1@news.povray.org...
> normal {
>    normal_map {
>        etc.
> wrong because it's sampling them inaccurately, so a smaller accuracy value
> can produce sharper edges but sometimes makes it look worse. Though again
> I'm not sure if this affects facets.
> Tek
>> I'm
>> to
>> facets
>> in
Date: 13 Dec 2006 09:00:01
Message: <web.45800690b76ee181f2ff13290@news.povray.org>
have you tried
facets coords 2
or something?
the facets pattern has two keywords which control its size, take a look at
the documentation...
