POV-Ray : Newsgroups : povray.newusers : Waves on water with cyclic quality Server Time
14 Jul 2025 16:51:34 EDT (-0400)
  Waves on water with cyclic quality (Message 1 to 10 of 10)
Subject: Waves on water with cyclic quality
Date: 12 Dec 2006 08:50:00
Message: <web.457eb3097f4fb8d27201fb850@news.povray.org>
I'm trying to put waves on water that appears random but is in fact
repetitive. What works well is something like this:
plane {<0,1,0>, 0
    pigment { rgb <0.2, 0.2, 0.2> }
    normal { bumps 0.08 turbulence 0.6 }
    finish {
      ambient 0.05
      diffuse 0.55
      brilliance 6.0
      phong 0.8
      phong_size 120
      reflection 0.6
The only problem with this is that "bumps" is a random function. I other
words the waves on my water is random over the entire surface. I want to be
able to do a cyclic animation where I have something like translate
<clock*2*pi, 0, 0> so that it appears as if I'm constantly moving over the
rippled water.
I hope I'm making sense.
Subject: Re: Waves on water with cyclic quality
Date: 12 Dec 2006 10:10:00
Message: <web.457ec52bf7603ccdf1cb1e660@news.povray.org>
> plane {<0,1,0>, 0
>   texture {
>     finish {
>       ambient 0.05
>       diffuse 0.55
>       brilliance 6.0
>       phong 0.8
>       phong_size 120
>       reflection 0.6
> rippled water.
Instead of bumps have you tried the ripples pattern? 3.5.11.29  Ripples. It
has a phase keyword that can be used to move the ripples outwards for
realistic animation.
Date: 12 Dec 2006 11:35:01
Message: <web.457ed945f7603ccd7201fb850@news.povray.org>
> Stephen
Thanks, that is a good idea and I have considered it. In fact, I'm hoping to
still find a way that I can use it. My probem is just that it also is random
across the entire surface.
I am trying to find a surface over which I can move and that will repeat
every so many pixels. In other words, if I move the camera (or the surface
for that matter) with translate <clock*2*pi,0,0> for instance, I need it to
repeat after every iteration of clock*2*pi. It would be great if I could
then adjust the phase of the ripples to also repeat after every clock*2*pi
(at least I know how to do that).
The reason I'm trying to do this is because I am rendering a bird that's
flying over water. The wings are flapping nicely and everything is working
well but, when the animation jumps back to the beginning, even though the
flapping of the wings repeat seamlessly, the waves on the water jumps
because the last fame and the first frame don't follow on each other.
As a sde note, I have tried using bump_map but have not had any good looking
results. Even so, if it did work I'm not convinced that it would have
sufficed because it would look as if the bird is flying over water with
rigid waves that don't change. The phase property of ripples or waves would
be essential - if only I could find a way to cause ripples or waves to
repeat predictably over space.
Date: 12 Dec 2006 11:58:01
Message: <457edf99@news.povray.org>
"deefstes" <nomail@nomail> wrote in message
news:web.457eb3097f4fb8d27201fb850@news.povray.org...
> be
> rippled water.
You may want to consider rotating the texture around a centre some distance
above or below your plane, so the same texture comes round again once every
cycle. So if you use 'rotate 360*clock*x  translate <0,100,-20>' the first
and last frame should turn out the same.
If the rotational centre you use for the texture is held above the camera
then it should look like the waves are coming towards you. If you've got
other items in the scene and you want it to look like you're moving over the
surface you can move the totational centre of the texture along to keep pace
with the camera while still rotating the texture. This should then look like
a constantly changing seascape with waves approaching you but it should get
over the cycle issue.
Hope I've explained this clearly.
Chris B.
Date: 12 Dec 2006 12:00:01
Message: <web.457edf70f7603ccdf1cb1e660@news.povray.org>
> > Stephen
Ah! The joys of cyclic animation. Water really is a difficult thing to do I
tried a cyclic biezier patch years ago and got no where. If ripple does not
Date: 12 Dec 2006 16:41:14
Message: <ie8un21ut26s2oqdoi1dsld75c6s8gaclm@4ax.com>
>Stephen
I did
I've posted an animation in p.b.a (Povray.binary.animations) that uses the waves
normal and phase. I've only changed your texture slightly by reducing the
reflection and the normal modifier.
#declare deefstes_Texture0 =
    color rgbft <0.200,0.200,0.200,0.413,0.000>
  normal {
    waves, 1.000
    frequency 3.000
    phase -clock
    sine_wave
    noise_generator 3
    scale     <10.000,1.000,3.000>
    translate <-1000.000,0.000,-100.000>
    turbulence <0.600,0.600,0.600>
    octaves 6
    lambda 2.000
    omega 0.500
  finish {
    ambient     rgb <0.050,0.050,0.050>
    brilliance  6.000
    crand       0.000
    diffuse     0.550
    metallic    0.000
    phong       0.800
    phong_size  120.000
    specular    0.000
    roughness   0.050
    reflection {
      rgb <0.200,0.250,0.300>, rgb <0.400,0.500,0.600>
      fresnel   0
      falloff   0.000
      exponent  1.000
      metallic  0.000
plane {  // Sea
  y , 0
  texture{ deefstes_Texture0 }
Regards
Date: 13 Dec 2006 07:25:01
Message: <web.457ff069f7603ccd7201fb850@news.povray.org>
Thanks for the help Stephen. I've had a look at your posting in p.b.a and it
does look good. I've tweaked the normal around a bit (ultimately opted for
ripples as opposed to waves inter alia) and came up with something that I'm
happy with... for now. I've posted my result in p.b.a if you want to have a
look.
What's interesting is that the ripples are still random over the surface of
the water but the way it moves when I clock the phase at least gives some
sort of an appearance of translational movement which is god enough (as I
said, for now).
Chris B, your suggestion sounds intriguing and somehow I think that's going
to be my ultimate sollution. To be honest though, I'm a little confused as
to how to go about rotating the texture around an axis above the surface.
I'll try to figure it out though but if you have more specific suggestions,
I'm all ears.
I had another idea also but, being a POVRay newbie, I'm not sure how to do
that either (or if it is even possible). I was thinking that, if I could
apply the ripples (or waves) function to the normal twice but the one being
offset by some distance horizontally. Then I can adjust their phase at the
same rate (with clock) and adjust their amplitude so that when clock=0, the
first ripple function will be at full amplitude and the second one at zero
and when clock=1 the first ripple function will be at zero amplitude and
the second one at full.
For arguments sake, let's say I render with +KI0 +KF1 +KFI0 +KFF15
now if one ripple is configured as:
   texture { ripples clock phase clock }
and the second one:
   texture { ripples 1-clock phase clock } translate <10, 0, 0>
Now, if I set up the camera to be something like
   location <clock*10, 2, -15>
   look_at <clock*10, 0, 0>
it should work, shouldn't it? Theonly question is, how do I add those two
textures together? My limited understanding of layered textures tells me
that one will always be on top of the other and therefor not really do the
trick.
Oh well, I've spent more time no this already than I really have available.
Date: 13 Dec 2006 08:35:00
Message: <web.4580006cf7603ccdf1cb1e660@news.povray.org>
My pleasure, cyclic animations make you think.
> trick.
Use Average - 3.5.11.2  Average
Join the club :-)
Date: 13 Dec 2006 09:30:00
Message: <web.45800db9f7603ccd7201fb850@news.povray.org>
Sweet! I think this may be just what I need. I'll check it out.
Thanks again for the help.
Date: 13 Dec 2006 18:56:26
Message: <4580932a$1@news.povray.org>
deefstes nous apporta ses lumieres en ce 13-12-2006 07:22:
> look.
> said, for now).
> I'm all ears.
Rotate then translate the texture up some distance.
> and the second one:
> camera {
> trick.
Use the average "pattern". Then, use the clock to modulate the ponderation of
the two texture, one going from 0 to 1, the other from 1 to 0.
> Cheers
The waves and ripples patterns are essencialy identical, differing only by the
wave type. waves give smooth, more rounded, ondulations. ripples give a more
pronounced pattern.
Taoism: Shit happens.
