POV-Ray : Newsgroups : povray.newusers : problem intersection or difference Server Time
2 May 2026 16:12:42 EDT (-0400)
  problem intersection or difference (Message 1 to 5 of 5)
Subject: problem intersection or difference
Date: 16 Nov 2006 07:20:00
Message: <web.455c56d113f4bbfa6b71dc850@news.povray.org>
Hello!
I have a problem with
using objects I defined.
Thank you very much!
Greetings,
Chris
Code
// create a smooth blobby shape
#declare RadiusVal   = 2.9;  // 1.0; // (0 < RadiusVal) outer sphere of
influence on other components
#declare StrengthVal = 0.4; // (+ or -) strength of component's radiating
density
#declare MyBlob1 = object {
blob {
  // threshold (0.0 < threshold <= StrengthVal) surface falloff threshold #
  threshold 0.6
  sphere { < 0.75,   0,    0>, RadiusVal, StrengthVal }
  sphere { < 3.75,   0,    0>, RadiusVal, StrengthVal }
  sphere { < 0.75,   0,    1.25>, RadiusVal, StrengthVal }
  sphere { < 3.75,   0,    1.25>, RadiusVal, StrengthVal }
  //sphere { <-0.375,  0.65, 0>, RadiusVal, StrengthVal }
  //sphere { <-0.375, -0.65, 0>, RadiusVal, StrengthVal }
  //cylinder { -z, +z, RadiusVal, StrengthVal }
  // [sturm]
  scale 2
      color rgb <0.8,0.8,1.0>
    finish{
      diffuse 0.3
      ambient 0.0
      specular 0.6
      reflection {
        0.8
        metallic
      conserve_energy
rotate <45, 45, 0>
#declare MyBox1 = object { box { <-1, -1, -1>, <1, 1, 1> inverse }  }
// Test
// MyBlob1
// CSG difference, subtract intersections of shapes 2...N from Shape1
intersection  {
  MyBlob1
  MyBox1
Subject: Re: problem intersection or difference
Date: 16 Nov 2006 07:56:23
Message: <455c5ff7@news.povray.org>
"Chrisir" <nomail@nomail> wrote in message
news:web.455c56d113f4bbfa6b71dc850@news.povray.org...
> Chris
Hi Chris,
You're code is doing what you're telling it to do, so what's your problem?
Chris B.
Date: 16 Nov 2006 10:13:32
Message: <7gFtHAA26HXFFwjg@econym.demon.co.uk>
Wasn't it Chrisir who wrote:
>Hello!
>Greetings,
>Chris
The syntax is
intersection  {
  object {MyBlob1}
  object {MyBox1}
Mike Williams
Gentleman of Leisure
Date: 16 Nov 2006 16:00:01
Message: <web.455cd0a49bdb3fe5385164a40@news.povray.org>
> intersection  {
>   object {MyBlob1}
>   object {MyBox1}
That exactly did it for me!
Sorry, I wasn't specific enough.
Those lines produced a syntax error
in my version. That's why I asked,
now it's solved!
Thanks to you and Greetings!
Chrisir
Date: 16 Nov 2006 18:35:00
Message: <web.455cf4799bdb3fe54daddc090@news.povray.org>
You don't need the extra 'object' wrapper around your #declared objects...
could be written as
#declare MyBox1 = box { <-1, -1, -1>, <1, 1, 1> inverse }
It will still work the same when used as
object{MyBox1}
It has nothing to do with your 'problem' though...
