POV-Ray : Newsgroups : povray.newusers : Exporting form 3ds max to povray 3.6 Server Time
24 Jan 2025 03:30:05 EST (-0500)
  Exporting form 3ds max to povray 3.6 (Message 1 to 7 of 7)
Subject: Exporting form 3ds max to povray 3.6
Date: 13 Oct 2006 15:05:01
Message: <web.452fe2a663fb067db3ef1e1c0@news.povray.org>
Hello Folks:
I am trying to use pov ray in unix as a renderer of architectural files
created in 3d Studio Viz/3d Studio max.
I've been looking for an exporter/format translator from .ase files (which
3ds MAx exports)  to the .pov format. I found this:
http://www.tb-software.com/products.html
It does work; I can render lights in POV ray using the .ase format from
3dsmax, then importing it in 3dwin and exporting to .pov to render finally
in unix.
The only thing is the render looks cartoonish, I mean like if it was using
the cartoon shader, which I deactivated on 3dwin when doing the exporting
to pov.
Do you know of any converter/exporter that does the transformation form .ase
to .pov effectively?
I already tried Polytrans which exports directly to .pov but POV RAY doesn't
process the results...
Also used polytrans&3dwin to try combinations of formats, the most
satisfactory so far is the .ase which DOES NOT require polytrans only
default 3ds max capabilities.
P.S. If it works in UNIX/linux that would be a significant plus
Many thanks in advance. (y)
Subject: Re: Exporting form 3ds max to povray 3.6
Date: 13 Oct 2006 17:22:18
Message: <4530038a$1@news.povray.org>
einarabelc5 wrote:
> Hello Folks:
> files created in 3d Studio Viz/3d Studio max.
> (which 3ds MAx exports)  to the .pov format. I found this:
> from 3dsmax, then importing it in 3dwin and exporting to .pov to
> render finally in unix.
> using the cartoon shader, which I deactivated on 3dwin when doing the
> exporting to pov.
Can you post an example image of what you mean?  Perhaps you just have to
set up the materials manually?  Perhaps the converter is just not
translating the materials properly (if they are even stored in the .ase
file, I do not remember).
Date: 14 Oct 2006 13:35:01
Message: <web.45311eaf4474c7f5731777170@news.povray.org>
"scott" <sco### [at] scottcom> wrote:
> einarabelc5 wrote:
> > Hello Folks:
> > exporting to pov.
Well the thing is my friend this newsletter wouldn't allow me to do just
that so instead I'm linking to a forum where I posted some images.
There is a comparison between gelato and povray...
http://forums.nvidia.com/index.php?showtopic=19820
Date: 14 Oct 2006 21:42:25
Message: <45319201$1@news.povray.org>
einarabelc5 nous apporta ses lumieres en ce 14/10/2006 13:30:
>> einarabelc5 wrote:
>>> Hello Folks:
>>> exporting to pov.
The gelato image is totaly black.
Believe those who are seeking the truth; doubt those who find it.
Date: 16 Oct 2006 12:50:00
Message: <web.4533b7fa4474c7f579603dca0@news.povray.org>
> >> einarabelc5 wrote:
> >>> Hello Folks:
> >>> exporting to pov.
> Alain
That doesn't make the POV less cartoonish now does it?
Anyway I am fixing it for comparison sake. If anyone has made a succesful
render of a 3ds max (6 or up plz) scene with materials using POV-RAY please
post a link to it.
Thx.
Date: 17 Oct 2006 08:30:00
Message: <web.4534cba94474c7f5731777170@news.povray.org>
> > >> einarabelc5 wrote:
> > >>> Hello Folks:
> > >>> exporting to pov.
> > Alain
> post a link to it.
> Thx.
Check back the link there is a whole secene in 3dsmax .max, .ASE and .POV
in:
http://forums.nvidia.com/index.php?act=ST&f=3&t=19820&st=0#entry120168
Date: 17 Oct 2006 21:20:01
Message: <web.453580854474c7f5731777170@news.povray.org>
> > > >> einarabelc5 wrote:
> > > >>> Hello Folks:
> > > >>> exporting to pov.
> > > Alain
> > post a link to it.
> > Thx.
> in:
It seems to be a problem with the 3dwin Demo Version.
