POV-Ray : Newsgroups : povray.newusers : Emulate browser rendering of png Server Time
2 May 2026 16:12:40 EDT (-0400)
  Emulate browser rendering of png (Message 1 to 4 of 4)
Subject: Emulate browser rendering of png
Date: 9 Oct 2006 15:55:00
Message: <web.452aa8a53de5448e8c9f8c6a0@news.povray.org>
I'm new to povray, and I'm trying to do what I hope is a fairly basic scene.
I'm trying to get povray to help me produce GIF files from the combination
of a PNG and a background color.  The idea is to generate printable
versions of png images I'm displaying on a website.
I've set up povray with the background color, the png viewed from above, and
the ambient light source, and I'm converting the resulting TGA file into
GIF.
And it works, but it's coming out a bit darker than the image as rendered in
my browser, and I'm not sure what to do to get the povray version to look
the same.
Any suggestions would be greatly appreciated.
Thanks,
Jay
Subject: Re: Emulate browser rendering of png
Date: 9 Oct 2006 16:45:29
Message: <452ab4e9@news.povray.org>
web.452aa8a53de5448e8c9f8c6a0@news.povray.org...
scene.
and
> GIF.
in
> the same.
> Thanks,
> Jay
Let ambient light as default, put finish{ambient 1 diffuse 0}to your png
That should do it
Marc
Date: 9 Oct 2006 16:47:43
Message: <452ab56f$1@news.povray.org>
> GIF.
> the same.
> Thanks,
> Jay
Are you using an assumed_gamma in your global_settings block? AFAIK, the
default display_gamma set for POV-Ray is 2.2, if you don't use
assumed_gamma, the images, if used with ambient 1 diffuse 0 and no
lightsource, will look a little different. In any case, assumed_gamma is
probably the cause and looking into it might solve your problem, for me,
using assumed_gamma set at 2.2 often solved that kind of problem when
using POV-Ray as a compositing tool instead of a renderer. :-)
Tim
aka "Tim Nikias"
Date: 10 Oct 2006 15:25:00
Message: <web.452bf2f3e15d36ff8c9f8c6a0@news.povray.org>
Thanks to both of you!
I was already using: ambient 1 diffuse 0
so it was good to know that I was on the right track there.
But I was not setting the assumed_gamma, and that made a big difference.
Playing with it a little, I found that assumed_gamma 2.4 got me about as
close as I can get.
