POV-Ray : Newsgroups : povray.newusers : how to move an object to position <0,0,0> Server Time
19 Mar 2026 06:03:52 EDT (-0400)
  how to move an object to position <0,0,0> (Message 1 to 10 of 12)
Subject: how to move an object to position <0,0,0>
Date: 8 Sep 2006 04:35:00
Message: <web.45012a4161ac9985800aa0230@news.povray.org>
I created a simple object that looks like a Rubics cube (a big cube
consisting of 27 smaller cubes). Then I show this object and want to rotate
it (animation). Unfortunately it doesn't rotate around the middle of the
object (big cube) but one of the corners of the big cube. Because object in
POVray always rotate around the origin it seems, that my object isn't
exactly centerd. But how do I center the object? I tried the function
"Center_Trans" but it didn't work, so it didn't get better. Does anone have
some suggestions what I do wrong or what I can do better?
Thanks in advance.
Subject: Re: how to move an object to position <0,0,0>
Date: 8 Sep 2006 04:51:54
Message: <kurtzlepirate-6F6783.10515508092006@news.povray.org>
In article <web.45012a4161ac9985800aa0230@news.povray.org>,
 "Nostromo" <nomail@nomail> wrote:
> Hi,
> Thanks in advance.
move your "rubrics cube" by adding "translate -0.50*full_cube_size"
klp
Date: 8 Sep 2006 05:25:00
Message: <web.450136bb1e67056d3e732b9a0@news.povray.org>
This applies if your object rotates _exactly_ around that corner. In any
other case the following should work as long as the object is not too
complicated:
translate -0.50*(min_extent(myObject)+max_extent(myObject))
this actually centers the bounding box of the object but that should be
calculated correctly for a cube-ish structure
Hope this helps
Regards Roman
Date: 8 Sep 2006 06:03:35
Message: <45013ff7@news.povray.org>
  Just curious: What's the second 0 for?
Date: 8 Sep 2006 06:05:00
Message: <web.4501400e1e67056d800aa0230@news.povray.org>
> complicated:
> Hope this helps
> Regards Roman
Thanks for your answer. Unfortunately the cube still doesn't rotate around
the middle, maybe the bounding box of my cube is somewhere odd. Any other
suggestions?
Date: 8 Sep 2006 06:41:00
Message: <450148bc@news.povray.org>
> suggestions?
  Well, do you know the actual limits of the cube? If you do, just
substitute them in the given formula.
Date: 8 Sep 2006 06:58:00
Message: <45014cb8@news.povray.org>
Nostromo do a little mistake its in fact
translate      + 0.50*(min_extent(myObject)+max_extent(myObject))
news:web.4501400e1e67056d800aa0230@news.povray.org...
> > complicated:
> > Hope this helps
> > Regards Roman
> suggestions?
Date: 8 Sep 2006 07:00:39
Message: <45014d57@news.povray.org>
Forget it, its not nostromo mistake ,, should be mine
news:45014cb8@news.povray.org...
any
> > > complicated:
be
> > > Hope this helps
> > > Regards Roman
around
other
> > suggestions?
Date: 8 Sep 2006 07:15:00
Message: <web.450150251e67056d800aa0230@news.povray.org>
Thanks for your help, but it still won't rotate around the middle of thebig
cube. Maybe someone can have a look at my code and tell me what's wrong?
Here's the POV file
#include "textures.inc"
#include "shapes.inc"
#include "glass.inc"
#include "metals.inc"
#include "woods.inc"
#include "functions.inc"
#declare Count = 3 ;
#declare Gap = 0.2 ;
global_settings {
                ambient_light rgb <1, 1, 1>
background { rgb <1,1,1> }
#declare Rubics = union {
 #declare z_axis = 0 ;
 #while ( z_axis < Count )
  #declare y_axis = 0 ;
  #while ( y_axis < Count )
   #declare x_axis = 0 ;
   #while (x_axis < Count)
    superellipsoid { <0.25, 0.25>
     translate <(2+Gap)*x_axis, (2+Gap)*y_axis, (2+Gap)*z_axis>
    #declare x_axis = x_axis + 1 ;
   #declare y_axis = y_axis + 1 ;
  #declare z_axis = z_axis + 1 ;
 location <25, 20, -25>
 look_at <8, 6, 0>
light_source {
 <200, 200, -200>
 color rgb <1,1,1>
object { Rubics
         pigment { color Green }   //Col_Glass_Vicksbottle }
  finish {
                        phong 1
                        reflection 0.15
                        ambient 0.2
                        diffuse 0.9
  interior { I_Glass }
  scale <3,3,3>
  rotate <clock, clock*2, clock*4>
  translate +0.50*(min_extent(Rubics)+max_extent(Rubics))
When I animate this I want the cube to rotate around it's center, but it's
rotating around some point near one of the corners.
Thanks a lot in advance.
Date: 8 Sep 2006 08:45:00
Message: <web.4501659b1e67056df1cb1e660@news.povray.org>
> Here's the POV file
[snip]
> object { Rubics
>   finish {
>                         phong 1
>                         reflection 0.15
>                         ambient 0.2
>                         diffuse 0.9
>   scale <3,3,3>
Nostromo
You should translate to the origin before rotating
