POV-Ray : Newsgroups : povray.newusers : media setup i don't understand... Server Time
24 Jan 2025 03:29:33 EST (-0500)
  media setup i don't understand... (Message 1 to 7 of 7)
Subject: media setup i don't understand...
Date: 1 Sep 2006 19:20:00
Message: <web.44f8bf5f823370943cba71480@news.povray.org>
Hello all,
I need you help with a scene of mine.
Basically i'm trying to modell a "flared" disc of gaz...
The disc is the surface inside a cylinder and between 2 paraboloids...
I fill it with emitting media...
i wanted to tell the code i want more emmiting media to the center of the
disc...i did it with a cylindrical density pattern.
my problem is that bright part of my media is not centered in the disc...it
seems that it has nothing to do with the cylindrical pattern...
i spent many hours trying to understand what i did wrong...i figure it may
be a silly error of mine, but it can also be something i simply did not
understand so i'm requesting your help! :D
i'm looking forward for your advices
jimmy
here's a paste of my scene file:
#include "functions.inc"
#include "shapes.inc"
//rayons min et max du disque....
#declare r_in = 10;
#declare r_out = 500;
//hauteur min et max du disque
#declare h_min =10;
#declare h_max =80;
//cylinder encompassing the disc
#declare Cube = cylinder{<0,-h_max,0>,<0,h_max,0>,r_out open }  ;
//top and bottom surfaces
#declare top = object{Paraboloid_Y
scale r_out
scale ((h_max-h_min)/r_out)*y
translate h_min*y
#declare bottom=object{top
rotate 180*x
//construction of the flared disc
#declare disque=union{
object{top}
object{bottom}
clipped_by{Cube}
#declare Disque=union{
object{Cube}
object{disque}
//color map
#declare gradient_disque= color_map{
[0.0 rgb<0.002,0.0,0.0>]
[0.05 rgb<0.03,0.0,0.0>]
[0.1 rgb<0.035,0.0,0.0>]
[0.2 rgb<0.04,0.0,0.0>]
[0.3 rgb<0.05,0.0,0.0>]
[0.4 rgb<0.1,0.0,0.0>]
[0.6 rgb<0.2,0.00,0.00>]
[0.7 rgb<0.3,0.00,0.0>]
[0.8 rgb<0.4,0.0,0.0>]
[0.9 rgb<0.5,0.08,0.0>]
[1.0 rgb<1.0,0.2,0.05>]
//object{bottom texture{pigment{color Green}} finish{diffuse 0.6}  }
//object{top texture{pigment{color Green}} finish{diffuse 0.6}  }
//declaration gaz inside the disc
#declare gaz=
interior{
media{
method 3
intervals 1
samples 5
emission 0.01
density{cylindrical scale 500
color_map{gradient_disque}
density{wrinkles scale 50
color_map{
[0.0rgb<0.1,0.1,0.1>]
[0.5rgb<0.5,0.5,0.5>]
[1.0rgb<1,1,1>]
object{Disque
texture {pigment {rgbt 0.5}}
interior{gaz}
hollow}
// perspective (default) camera
camera {location  <000.0, 500.0, -1000.0> look_at   <0.0, 0.0,  0.0>}
//sphere{0,200 pigment{White}}
light_source { <8000,2000,0> rgb 1  }
Subject: Re: media setup i don't understand...
Date: 1 Sep 2006 22:07:12
Message: <44f8e750@news.povray.org>
"jimmy" <nomail@nomail> wrote in message
news:web.44f8bf5f823370943cba71480@news.povray.org...
> Hello all,
> disc...it
> jimmy
Not sure what your problem is, but the density is working as should be
expected.  Try looking from directly above or the side and it is centred
fine.  I think what you see as off-centred is a result of the angle of view.
-tgq
Date: 2 Sep 2006 08:20:01
Message: <web.44f975e1a5ed894c3cba71480@news.povray.org>
> > Hello all,
> > disc...it
> > jimmy
> -tgq
Thanks for your answer Trevor.
Yes i saw that face on and edge on the behavior looked fine.
Also  iknew there would be line of sight effect but i estimated they would
not be that big...
i'm confused especially knowing that with a perfect cylinder (Cube in the
code), the media is nicely centered...playing with h_min value i can
transform my flared disc into a cylinder (or very very close
), YET it shows a complete different behaviour from the cylinder...
jimmy
Date: 2 Sep 2006 10:33:51
Message: <44f9964f$1@news.povray.org>
> not be that big...
> jimmy
I'm also not quite sure how you are constructing your object, especially
with the 'open' in the cylinder and the 'clipped_by'.  What should the
object you are trying to construct look like?
-tgq
Date: 2 Sep 2006 11:15:00
Message: <web.44f99a96a5ed894c3cba71480@news.povray.org>
to sum up, a cylinder where the top and the bottom faces has been
incurved...in the shape of a parabol
i did this by putting together 2 paraboloids and a cylinder...
> > not be that big...
> > jimmy
> -tgq
Date: 2 Sep 2006 18:45:33
Message: <44fa098d$1@news.povray.org>
This seems like some sort of bug to me after running
your code. If you add some other object to the scene
it starts behaving normally. Adding...
sphere {<0,-10000,0>,1 pigment{White}}
and increasing the emission to 0.05 looks OK.
It has something to do with the way you made the
object as well, since...
#declare Disk2 = difference {
   object{Cube}
   object{top}
   object{bottom}
object{ Disk2 //Disque
etc
Also looks ok, as the only object in the scene.
Somehow when a ray is cast at Disque it isn't
finding any other objects so it looks different,
probably exits early out of some calculation.
Date: 2 Sep 2006 21:05:00
Message: <web.44fa26a8a5ed894ca848f9dd0@news.povray.org>
Does replacing
--------code---------
object{top}
object{bottom}
clipped_by{Cube}
object{Cube}
object{disque}
------end code-------
with
#declare Disque=difference{
object{Cube}
object{top}
object{bottom}
produce what you want?
Abe
"jimmy" <nomail@nomail> wrote:
> Hello all,
> jimmy
> #declare r_in = 10;
> #declare h_min =10;
> #declare h_max =80;
> scale r_out
> translate h_min*y
> rotate 180*x
> object{top}
> object{bottom}
> clipped_by{Cube}
> object{Cube}
> object{disque}
> //color map
> #declare gaz=
> interior{
> media{
> method 3
> intervals 1
> samples 5
> emission 0.01
> color_map{
> [1.0rgb<1,1,1>]
> object{Disque
> interior{gaz}
> hollow}
